Not sure how to proceed
junga
#1 Post by junga »
I would like to have a much needed help if possible, I run test disk analysis and it showed a space conflict, at this point I am not exactly sure how to proceed to hopefully recuperate the family pictures. :cry:
windows indicates that the drive is not accessible, the parameter is incorrect.
Things I tried: changing the drive letter, try to boot from a linux live OS hoping to see the files, but unfortunately without success.
Thank you for reading.
Michel
Re: Not sure how to proceed
Can you repeat your diagnose and selecting disk instead of a drive.
Disk looks like:
Disk /dev/sdc - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Disk \\.\PhysicalDrive2 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096
Drive C: - 981 GB / 913 GiB - CHS 119300 255 63, sector size=512
Drive E: - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Drive F: - 3000 GB / 2794 GiB - CHS 45598 255 63, sector size=4096
TestDisk 7.1WIP 32bit is recommended.
junga
#3 Post by junga »
Yes of course,
Thank you.
Michel
junga
#4 Post by junga »
a shy bump. :)
#5 Post by Fiona »
You already have a partition in your partition table.
If this partition would be correct, you can have a try to run a boot sector diagnose.
Can you run testdisk, Advanced and Boot and upload another snapshot?
Can you use the menu List and have a try to list your files?
Until yet, don't use Write nor RepairMFT!
It's intended to avoid any changes to your file system.
junga
#6 Post by junga »
Thank you Fiona,
here are the screenshots:
Boot:
List:
Regards,
Michel
#7 Post by Fiona »
Can you try to run on your current partition a RebuildBS and if the boot sector is different, you can have another try to list your files, using the menu List.
If it wouldn't help:
Can you run TestDisk Deeper Search?
The intention is, to find another partition by the backup of the boot sector.
junga
#8 Post by junga »
Thank you Fiona,
RebuildBS:
Boot sectors identical could not list:
Deep scan result:
I could not see the back up of the boot sector.
Regards,
Michel
#9 Post by Fiona »
Your current message displays only not recoverable partitions which end after disk limit.
Fat12 and FAT16 partitions are probably wrong.
At this display, when you press enter, you'll get to the results.
Did testdisk find another partition?
If not, you'll probably need datarecovery software which reads underlying data.
Can you copy and paste the content of your testdisk.log into your next post?
PhotoRec could help.
Info will follow.
junga
#10 Post by junga »
Thank you Fiona,
After continue on Fat12:
seems like a boot partition found.
Log:
Tue Aug 4 12:20:43 2015
OS: Windows 8 (9200)
Compiler: GCC 4.9, Cygwin 2000.4
Compilation date: 2015-07-30T21:13:54
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=64421363712
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=55055966208
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396746752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=2000396321280
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - Samsung SSD 840 Series, S/N:*************, FW:DXT09B0Q
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - ST2000DM 001-9YN164, S/N:**********
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20 EARS-00MVWB0, S/N:************
Disk /dev/sdb - 2000 GB / 1863 GiB - ST2000DM 001-9YN164
Geometry from i386 MBR: head=16 sector=63
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 243201 0 63 3907024065
NTFS at 0/1/1
filesystem size 3907024065
mftmirr_lcn 244189004
file_pread(5,2,buffer,3907031040(243201/110/46)) lseek err Invalid argument
file_pread(5,8,buffer,3907029183(243201/81/16)) lseek err Invalid argument
file_pread(5,8,buffer,3907029311(243201/83/18)) lseek err Invalid argument
file_pread(5,8,buffer,3907029439(243201/85/20)) lseek err Invalid argument
file_pread(5,8,buffer,3907029567(243201/87/22)) lseek err Invalid argument
file_pread(5,8,buffer,3907029695(243201/89/24)) lseek err Invalid argument
file_pread(5,8,buffer,3907029823(243201/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,3907029951(243201/93/28)) lseek err Invalid argument
file_pread(5,8,buffer,3907030079(243201/95/30)) lseek err Invalid argument
file_pread(5,8,buffer,3907030207(243201/97/32)) lseek err Invalid argument
file_pread(5,8,buffer,3907030335(243201/99/34)) lseek err Invalid argument
file_pread(5,8,buffer,3907030463(243201/101/36)) lseek err Invalid argument
file_pread(5,8,buffer,3907030591(243201/103/38)) lseek err Invalid argument
file_pread(5,8,buffer,3907030719(243201/105/40)) lseek err Invalid argument
file_pread(5,8,buffer,3907030847(243201/107/42)) lseek err Invalid argument
file_pread(5,8,buffer,3907030975(243201/109/44)) lseek err Invalid argument
file_pread(5,14,buffer,3907031041(243201/110/47)) lseek err Invalid argument
file_pread(5,3,buffer,3907031055(243201/110/61)) lseek err Invalid argument
file_pread(5,3,buffer,3907031102(243201/111/45)) lseek err Invalid argument
file_pread(5,8,buffer,3907031118(243201/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,3907031165(243201/112/45)) lseek err Invalid argument
file_pread(5,2,buffer,3907033087(243201/143/14)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 255 but the correct value may be 128.
* HPFS - NTFS 0 1 1 243201 254 63 3907040067
1 * HPFS - NTFS 0 1 1 243201 254 63 3907040067
***end of log***
Regards,
Michel
