HELP!!!
RedeyeDog
HELP!!!
#1 Post by RedeyeDog »
Nothing after analize..
Screenshot - 8_3_2015 , 11_16_29 PM.jpg (29.61 KiB) Viewed 3922 times
Re: HELP!!!
Do you still have a partition in your partition table?
When nothing was found, you can run Deeper Search too.
Can you copy and paste the content of your testdisk.log?
RedeyeDog
Re: HELP!!!
#3 Post by RedeyeDog »
Nothing was found even after a deeper search. I don't know if I still have a partition, honestly but device manager reports the drive is working properly. I haven't made any writes since the incident so I can't imagine why it wouldn't be there. Perhaps Bitlocker is hiding it?
EDIT: Here is the top and bottom of the log file. Hope you can make heads or tails of it..
RedeyeDog
Re: HELP!!!
#4 Post by RedeyeDog »
Bump. I edited instead of posting. Sorry...
Re: HELP!!!
#5 Post by Fiona »
Did you encrypt your Disk or partition with Bitlocker?
A better solution to read your testdisk.log would be, if you open it, for example with wordpad and copy and paste the content into your next post.
At least I could watch your current partition structure (partition table) at Analyse and the results after Quick Search too.
RedeyeDog
Re: HELP!!!
#6 Post by RedeyeDog »
Yes. This is 1 of 2 drives which were encrypted with Bitlocker when the laptop died. I'll copy & paste the log information as you described as soon as I can. Thank you Fiona. I'm on pins & needles.
RedeyeDog
Re: HELP!!!
#7 Post by RedeyeDog »
Here's the latest log file info but I had to edit out some of the "i/O" error lines because the post has a limit of 60K characters.. TIA
Thu Aug 6 07:55:41 2015
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=18612224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=18612224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255691063296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=10487808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=18612224
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk /dev/sdd - 18 MB / 17 MiB - CHS 2 255 63, sector size=512
Drive C: - 255 GB / 238 GiB - CHS 31086 255 63, sector size=512
Drive D: - 10 MB / 10 MiB - CHS 2 64 32, sector size=2048
Disk /dev/sdb - 1000 GB / 931 GiB
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,48(0/0/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,95(0/1/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,111(0/1/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,158(0/2/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2080(0/33/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,51(0/0/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,98(0/1/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,119(0/1/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,169(0/2/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2082(0/33/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,63(0/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,79(0/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,126(0/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,142(0/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,4098(0/65/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,4112(0/65/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,4159(0/66/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,4175(0/66/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,4222(0/67/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,6144(0/97/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,6146(0/97/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,6160(0/97/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,6207(0/98/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,6223(0/98/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,6270(0/99/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,1953520066(121601/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1953520080(121601/0/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1953520127(121601/0/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1953520143(121601/1/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1953520190(121601/1/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,1953522112(121601/32/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,1953525761(121601/90/27)) lseek err Invalid argument
file_pread(5,3,buffer,1953525775(121601/90/41)) lseek err Invalid argument
file_pread(5,3,buffer,1953525822(121601/91/25)) lseek err Invalid argument
file_pread(5,8,buffer,1953525838(121601/91/41)) lseek err Invalid argument
file_pread(5,11,buffer,1953525885(121601/92/25)) lseek err Invalid argument
file_pread(5,2,buffer,1953527807(121601/122/57)) lseek err Invalid argument
file_pread(5,1,buffer,6(0/0/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,189(0/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,2111(0/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,132(0/2/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,1008(0/16/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1024(0/16/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1071(0/17/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1087(0/17/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1134(0/18/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,3056(0/48/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,1074(0/17/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1150(0/18/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1197(0/19/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,3119(0/49/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,2047(0/32/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,2048(0/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,2049(0/32/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,2064(0/32/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,2113(0/33/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,2127(0/33/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,2174(0/34/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,4096(0/65/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,4095(0/65/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,6143(0/97/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,8192(0/130/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,8191(0/130/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,8194(0/130/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,8208(0/130/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,8255(0/131/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,8271(0/131/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,8318(0/132/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,10240(0/162/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,10239(0/162/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,10242(0/162/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,10256(0/162/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,10303(0/163/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,10319(0/163/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,10366(0/164/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,12288(0/195/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,12287(0/195/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,12290(0/195/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,12304(0/195/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,12351(0/196/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,12367(0/196/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,12414(0/197/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,14336(0/227/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,14335(0/227/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,14338(0/227/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,14352(0/227/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,14399(0/228/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,14415(0/228/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,14462(0/229/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,16384(1/5/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,16,buffer,15120(0/240/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,15136(0/240/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,15183(0/241/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,15199(0/241/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,15246(0/242/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,17168(1/17/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,15186(0/241/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,15262(0/242/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,15309(0/243/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,17231(1/18/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,16064(0/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,16065(1/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,16066(1/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16081(1/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16128(1/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,16144(1/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,16191(1/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,18113(1/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,16131(1/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,16207(1/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,16254(1/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,18176(1/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,16383(1/5/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,16384(1/5/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,16385(1/5/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16400(1/5/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,16447(1/6/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,16463(1/6/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,16510(1/7/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,18432(1/37/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,18431(1/37/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,18434(1/37/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,18448(1/37/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,18495(1/38/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,18511(1/38/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,18558(1/39/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,20480(1/70/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,20479(1/70/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,20482(1/70/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,20496(1/70/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,20543(1/71/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,20559(1/71/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,20606(1/72/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,22528(1/102/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,22527(1/102/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,22530(1/102/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,22544(1/102/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,22591(1/103/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,22607(1/103/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,22654(1/104/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,24576(1/135/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,24575(1/135/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,24578(1/135/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,24592(1/135/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,24639(1/136/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,24655(1/136/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,24702(1/137/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,26624(1/167/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,26623(1/167/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,26626(1/167/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,26640(1/167/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,26687(1/168/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,26703(1/168/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,26750(1/169/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,28672(1/200/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,28671(1/200/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,28674(1/200/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,28688(1/200/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,28735(1/201/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,28751(1/201/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,28798(1/202/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,30720(1/232/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,30719(1/232/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,30722(1/232/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,30736(1/232/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,30783(1/233/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,30799(1/233/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,30846(1/234/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,32768(2/10/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,32129(1/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,32130(2/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,32131(2/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,32146(2/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,32193(2/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,32209(2/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,32256(2/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,34178(2/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,32196(2/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,32272(2/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,32319(2/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,34241(2/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,32767(2/10/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,32770(2/10/11)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,32784(2/10/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,32831(2/11/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,32847(2/11/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,32894(2/12/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,34816(2/42/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,34815(2/42/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,34818(2/42/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,34832(2/42/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,34879(2/43/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,34895(2/43/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,34942(2/44/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,36864(2/75/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,36863(2/75/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,36866(2/75/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,36880(2/75/26)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,36927(2/76/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,36943(2/76/26)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,36990(2/77/10)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,38912(2/107/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,38911(2/107/41)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,38914(2/107/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,38928(2/107/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,38975(2/108/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,38991(2/108/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,39038(2/109/42)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,40960(2/140/11)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,45058(2/205/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,45072(2/205/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,45119(2/206/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,45135(2/206/28)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,45182(2/207/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,47104(2/237/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,47103(2/237/43)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,47106(2/237/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,47120(2/237/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,47167(2/238/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,47183(2/238/60)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,47230(2/239/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,49152(3/15/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,48194(2/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,48195(3/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,48196(3/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,48211(3/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,48258(3/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,48274(3/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,48321(3/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,50243(3/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,48261(3/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,48337(3/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,48384(3/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,50306(3/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,49151(3/15/12)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,49154(3/15/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,49168(3/15/29)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,49215(3/16/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,49231(3/16/29)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,49278(3/17/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,51200(3/47/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,49218(3/16/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,51199(3/47/44)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,51202(3/47/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,51216(3/47/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,51263(3/48/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,51279(3/48/61)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,51326(3/49/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,53248(3/80/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,53247(3/80/13)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,53250(3/80/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,53264(3/80/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,53311(3/81/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,53327(3/81/30)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,53374(3/82/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,55296(3/112/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,55295(3/112/45)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,55298(3/112/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,55312(3/112/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,55359(3/113/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,55375(3/113/62)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,55422(3/114/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,57344(3/145/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,57343(3/145/14)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,57346(3/145/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,57360(3/145/31)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,57407(3/146/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,57423(3/146/31)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,57470(3/147/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,59392(3/177/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,59391(3/177/46)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,59394(3/177/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,59408(3/177/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,59455(3/178/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,59471(3/178/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,59518(3/179/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,61440(3/210/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,61439(3/210/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,61442(3/210/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,61456(3/210/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,61503(3/211/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,61519(3/211/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,61566(3/212/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,63488(3/242/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,63487(3/242/47)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,63490(3/242/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,63504(3/243/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,63551(3/243/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,63567(3/244/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,63614(3/244/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,65536(4/20/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,64259(3/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,64260(4/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,64261(4/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,64276(4/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,64323(4/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,64339(4/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,64386(4/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,66308(4/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,64326(4/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,64402(4/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,64449(4/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,66371(4/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,65219(4/15/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,65282(4/16/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,65345(4/17/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,65535(4/20/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,65536(4/20/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,65537(4/20/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,65552(4/20/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,65599(4/21/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,65615(4/21/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,65662(4/22/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,67584(4/52/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,67583(4/52/48)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,67586(4/52/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,67600(4/53/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,67647(4/53/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,67663(4/54/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,67710(4/54/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,69632(4/85/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,69631(4/85/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,69634(4/85/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,69648(4/85/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,69695(4/86/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,69711(4/86/34)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,69758(4/87/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,71680(4/117/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,71679(4/117/49)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,71682(4/117/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,71696(4/118/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,71743(4/118/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,71759(4/119/3)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,71806(4/119/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,73728(4/150/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,73727(4/150/18)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,73730(4/150/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,73744(4/150/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,73791(4/151/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,73807(4/151/35)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,73854(4/152/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,75776(4/182/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,75775(4/182/50)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,75778(4/182/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,75792(4/183/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,75839(4/183/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,75855(4/184/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,75902(4/184/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,77824(4/215/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,77823(4/215/19)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,77826(4/215/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,77840(4/215/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,77887(4/216/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,77903(4/216/36)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,77950(4/217/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,79872(4/247/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,79871(4/247/51)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,79874(4/247/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,79888(4/248/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,79935(4/248/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,79951(4/249/5)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,79998(4/249/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,81920(5/25/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,80324(4/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,80325(5/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,80326(5/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,80341(5/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,80388(5/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,80404(5/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,80451(5/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,82373(5/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,80391(5/1/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,80467(5/2/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,80514(5/3/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,82436(5/33/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,81284(5/15/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,81347(5/16/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,81410(5/17/15)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,81919(5/25/20)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,81920(5/25/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,15,buffer,81921(5/25/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,81936(5/25/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,81983(5/26/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,81999(5/26/37)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,82046(5/27/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,83968(5/57/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,83967(5/57/52)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,83970(5/57/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,83984(5/58/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,84031(5/58/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,84047(5/59/6)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,84094(5/59/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,86016(5/90/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,86015(5/90/21)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,86018(5/90/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,86032(5/90/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,86079(5/91/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,86095(5/91/38)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,86142(5/92/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,88064(5/122/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,88063(5/122/53)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,88066(5/122/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,88080(5/123/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,88127(5/123/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,88143(5/124/7)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,88190(5/124/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,90112(5/155/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,90111(5/155/22)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,90114(5/155/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,90128(5/155/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,90175(5/156/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,90191(5/156/39)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,90238(5/157/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,92160(5/187/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,92159(5/187/54)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,92162(5/187/57)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,92176(5/188/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,92223(5/188/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,92239(5/189/8)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,92286(5/189/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,94208(5/220/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,94207(5/220/23)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,94210(5/220/26)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,94224(5/220/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,94271(5/221/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,94287(5/221/40)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,94334(5/222/24)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,96256(5/252/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,96255(5/252/55)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,96258(5/252/58)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,96272(5/253/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,96319(5/253/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,96335(5/254/9)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,96382(5/254/56)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,98304(6/30/25)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,13,buffer,96393(6/0/4)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,96406(6/0/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,96453(6/1/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,96469(6/1/17)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,96516(6/2/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,98438(6/32/33)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953503999(121599/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953504000(121600/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,14,buffer,1953504001(121600/0/2)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1953504015(121600/0/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,3,buffer,1953504062(121600/0/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,8,buffer,1953504078(121600/1/16)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,11,buffer,1953504125(121600/1/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,2,buffer,1953506047(121600/32/32)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953520064(121600/254/63)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,1953520065(121601/0/1)) ReadFile The request could not be performed because of an I/O device error.
file_pread(5,1,buffer,0(0/0/1)) ReadFile The request could not be performed because of an I/O device error.
Store new MBR code
RedeyeDog
Re: HELP!!!
#8 Post by RedeyeDog »
I finally got a chance to get back to the compter with the 1TB HDD and ran Crystaldiskinfo64:
Here's what it shows for my drive, drive 3.
CrystalDiskInfo 6.5.2 (C) 2008-2015 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 8.1 Pro [6.3 Build 9600] (x64)
Date : 2015/08/14 21:12:52
-- Controller Map ----------------------------------------------------------
+ ATA Channel 0 (0) [ATA]
- MKNSSDCR120GB ATA Device
- HL-DT-ST DVDRAM GH24NSB0 ATA Device
+ ATA Channel 1 (1) [ATA]
- TOSHIBA DT01ACA100 ATA Device
+ Standard Dual Channel PCI IDE Controller [ATA]
+ ATA Channel 0 (0)
- ST1000LM024 HN-M101MBB ATA Device
- ATA Channel 1 (1)
- ATA Channel 0 (0)
- ATA Channel 1 (1)
- Microsoft Storage Spaces Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(1) MKNSSDCR120GB : 120.0 GB [0/0/0, pd1] - sf
(2) TOSHIBA DT01ACA100 : 1000.2 GB [1/1/0, pd1]
(3) ST1000LM024 HN-M101MBB : 1000.2 GB [2/2/0, pd1] - st
Model : ST1000LM024 HN-M101MBB
Firmware : 2AR20002
Serial Number : xxxxxxxxxxxxx
Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
Buffer Size : 16384 KB
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : 5400 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 6
Transfer Mode : SATA/300 | SATA/300
Power On Hours : 10048 hours
Power On Count : 2729 count
Temperature : 28 C (82 F)
Health Status : Good
Features : S.M.A.R.T., APM, AAM, 48bit LBA, NCQ
APM Level : 0080h [OFF]
AAM Level : FE00h [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _51 000000000000 Read Error Rate
02 252 252 __0 000000000000 Throughput Performance
03 _89 _88 _25 000000000D4A Spin-Up Time
04 _98 _98 __0 0000000008DE Start/Stop Count
05 252 252 _10 000000000000 Reallocated Sectors Count
07 252 252 _51 000000000000 Seek Error Rate
08 252 252 _15 000000000000 Seek Time Performance
09 100 100 __0 000000002740 Power-On Hours
0A 252 252 _51 000000000000 Spin Retry Count
0C _98 _98 __0 000000000AA9 Power Cycle Count
BF 100 100 __0 0000000000BC G-Sense Error Rate
C0 252 252 __0 000000000000 Power-off Retract Count
C2 _64 _60 __0 00280009001C Temperature
C3 100 100 __0 000000000000 Hardware ECC recovered
C4 252 252 __0 000000000000 Reallocation Event Count
C5 252 252 __0 000000000000 Current Pending Sector Count
C6 252 252 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 100 100 __0 000000000129 Write Error Rate
DF 100 100 __0 000000000032 Load/Unload Retry Count
E1 _61 _61 __0 000000061457 Load/Unload Cycle Count
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 5332 5934 4A39 4644 3530 3033 3330 2020 2020 2020
020: 0000 8000 0004 3241 5232 3030 3032 5354 3130 3030
030: 4C4D 3032 3420 484E 2D4D 3130 314D 4242 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0407 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 1D06 0004 004C 0040
080: 01FF 0028 746B 7F69 6123 746B BC41 6123 007F 006D
090: 006D 0080 1043 0000 FE00 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5000 4CF2
110: 0A47 82B0 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0027 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 003F 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 103F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0400 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 CFA5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 64 64 00 00 00 00 00 00 00 02 26
010: 00 FC FC 00 00 00 00 00 00 00 03 23 00 59 58 4A
020: 0D 00 00 00 00 00 04 32 00 62 62 DE 08 00 00 00
030: 00 00 05 33 00 FC FC 00 00 00 00 00 00 00 07 2E
040: 00 FC FC 00 00 00 00 00 00 00 08 24 00 FC FC 00
050: 00 00 00 00 00 00 09 32 00 64 64 40 27 00 00 00
060: 00 00 0A 32 00 FC FC 00 00 00 00 00 00 00 0C 32
070: 00 62 62 A9 0A 00 00 00 00 00 BF 22 00 64 64 BC
080: 00 00 00 00 00 00 C0 22 00 FC FC 00 00 00 00 00
090: 00 00 C2 02 00 40 3C 1C 00 09 00 28 00 00 C3 3A
0A0: 00 64 64 00 00 00 00 00 00 00 C4 32 00 FC FC 00
0B0: 00 00 00 00 00 00 C5 32 00 FC FC 00 00 00 00 00
0C0: 00 00 C6 30 00 FC FC 00 00 00 00 00 00 00 C7 36
0D0: 00 C8 C8 00 00 00 00 00 00 00 C8 2A 00 64 64 29
0E0: 01 00 00 00 00 00 DF 32 00 64 64 32 00 00 00 00
0F0: 00 00 E1 32 00 3D 3D 57 14 06 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 70 35 00 5B
170: 03 00 01 00 02 E4 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 36
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 00 00 00 00 00 00 00 00 00 00 02 00
010: 00 00 00 00 00 00 00 00 00 00 03 19 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 07 33
040: 00 00 00 00 00 00 00 00 00 00 08 0F 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 33 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
080: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
090: 00 00 C2 00 00 00 00 00 00 00 00 00 00 00 C3 00
0A0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 C8 00 00 00 00 00
0E0: 00 00 00 00 00 00 DF 00 00 00 00 00 00 00 00 00
0F0: 00 00 E1 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 46
