sda Installation
1 BIOS_RVY
2 System Reserved
3 Windows XP Pro SP3
5 Puppy Slacko 5.7
6 Linux Lite 2.0
7 Xubuntu 12.04.3
8 Tiny Core 5.3
9 antiX 13.2
10 Slackware 14.1
11 Knoppix 7.2.0
12 linux swap
13 Xubuntu 14.04.1
14 Linux Mint 17 Qiano
15 PC Linux OS 2014
16 Vector Linux 7.0
17 Zorin OS 5
18 Fedora 20.1
19 PC Linux OS Installer
20 PC Linux OS 2014
21 Zorin OS 9
22 Puppy 6.0
23 MX-14
24 Xubuntu 14.04.1
cfdisk (util-linux 2.21.2)
Disk Drive: /dev/sda
Size: 320072933376 bytes, 320.0 GB
Heads: 255 Sectors per Track: 63 Cylinders: 38913
Name Flags Part Type FS Type [Label] Size (MB)
Unusable 1.05 *
sda1 Primary ntfs [BIOS_RVY] 10737.42 *
sda2 Primary ntfs [System Reserved] 104.86 *
sda3 Primary ntfs [($) ONYX XP Pro ] 10001.95 *
sda5 Logical ext4 [Puppy Slacko 5.7] 5000.98 *
sda6 Logical ext4 [Linux Lite 2.0] 5000.98 *
sda7 Logical ext4 [Xubuntu 12.04.3] 5000.98 *
sda8 Logical ext4 [Tiny Core 5.3] 5000.98 *
sda9 Logical ext4 [antiX 13.2] 5000.98 *
sda10 Logical ext4 [Slackware 14.1] 10001.95 *
Logical Free Space 1.34 *
sda11 NC Logical reiserfs [Knoppix 7.2.0] 4194.37 *
Logical Free Space 1.02 *
sda12 Logical swap 1048.61 *
sda13 Logical ext4 [Xubuntu 14.04.1] 8003.20 *
Logical Free Space 0.01 *
sda14 Logical Linux 8003.20
sda15 Logical Linux 8003.20
sda16 Logical Linux 8003.20
sda17 Logical Linux 8003.20
sda18 Logical Linux 8003.20
sda19 Logical ext4 [PClos Installer] 8381.57
sda20 Logical ext4 [PC Linux OS 2014] 8381.57
sda21 Logical ext4 [Zorin OS 9] 8003.20
sda22 Logical ext4 [Puppy Slacko 6.0] 1003.49
sda23 Logical ext4 [antiX 14.2-MX PA] 8003.20
sda24 Logical ext4 [Xubuntu 14.04.1] 8003.20
Logical Free Space 169180.18 *
Here is the output from testdisk 7.0:
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
1 P HPFS - NTFS 0 32 33 1305 138 49 20971520
Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD)
2 P HPFS - NTFS 1305 138 50 1318 74 36 204800
3 P HPFS - NTFS 1318 74 37 2534 74 36 19535040
4 E extended LBA 2534 74 37 38912 254 63 584423937
5 L Linux 2534 75 37 3142 74 36 9767457 [Puppy Slacko 5.7]
X extended 3142 74 37 3750 74 36 9767520
6 L Linux 3142 75 37 3750 74 36 9767457 [Linux Lite 2.0]
X extended 3750 74 37 4358 74 36 9767520
7 L Linux 3750 75 37 4358 74 36 9767457 [Xubuntu 12.04.3]
X extended 4358 74 37 4966 74 36 9767520
8 L Linux 4358 75 37 4966 74 36 9767457 [Tiny Core 5.3]
X extended 4966 74 37 5574 74 36 9767520
9 L Linux 4966 75 37 5574 74 36 9767457 [antiX 13.2]
X extended 5574 74 37 6790 74 36 19535040
10 L Linux 5574 75 37 6790 74 36 19534977 [Slackware 14.1]
X extended 6790 116 1 7300 99 31 8192110
11 L Linux 6790 117 48 7300 99 31 8192000 [Knoppix 7.2.0]
X extended 7300 131 1 7427 254 59 2048063
12 L Linux Swap 7300 132 1 7427 254 59 2048000
X extended 7427 254 60 8400 254 59 15631245
13 L Linux 7428 0 60 8400 254 59 15631182 [Xubuntu 14.04.1]
X extended 8401 0 1 9373 254 63 15631245
14 L Linux 8401 1 1 9373 254 63 15631182
X extended 9374 0 1 10346 254 63 15631245
15 L Linux 9374 1 1 10346 254 63 15631182
X extended 10347 0 1 11319 254 63 15631245
16 L Linux 10347 1 1 11319 254 63 15631182
X extended 11320 0 1 12292 254 63 15631245
17 L Linux 11320 1 1 12292 254 63 15631182
X extended 12293 0 1 13265 254 63 15631245
18 L Linux 12293 1 1 13265 254 63 15631182
X extended 13266 0 1 14284 254 63 16370235
19 L Linux 13266 1 1 14284 254 63 16370172 [PClos Installer]
X extended 14285 0 1 15303 254 63 16370235
20 L Linux 14285 1 1 15303 254 63 16370172 [PC Linux OS 2014]
X extended 15304 0 1 16276 254 63 15631245
At this point, I should add that I guessed at the sizes of partition sda13-18 - basically, after recovering the other partitions cfdisk said I had 48019.19MB free space between the linux swap (sda12) and the PC Linux OS Installer (sda19) partitions, which - as can be seen - almost exactly equates to 6 x 8000MB partitions created with cfdisk (they get created at 8003.20MB in size). I initially tried creating them contiguously (leaving the remaining 0.01MB free space between sda18 and sda19) but that didn't work, so I tried creating them starting at the end of that free space (as per current configuration) but that hasn't worked either. I should also add that Puppy Slacko 6.0 (at sda22) is the only recovered install which won't boot (complains about a missing "init", Ithink).
I have used testdisk 7.0 (both Quick Search and Deeper Scan) to try to identify these missing sda13-18 partitions but to no avail. I'm now out of ideas so hoping somebody more expert can suggest some new approaches.
Thanks for any help,
3g
