Corrupt NTFS partition, testdisk shows Mac HFS
tomatpasser
#1 Post by tomatpasser »
Hello
I have a Seagate external harddrive which I can't mount or anything. I am fairly certain it is NTFS formatted, but testdisk shows a lot of lines with "Mac HFS". It has been used with a macbook with the paragon ntfs driver. It should only have one partition.
I have analysed it with testdisk both quick scan and deep scan. It shows a lot of partitions, one of which looks like the one I want:
MS Data 63 1953520064 1953520002
When I try to list files it says "Can't open filesystem. Filesystem seems damaged."
What should I do to repair the filesystem? I am fairly new to disk recovery.
I have made a backup of the disk with the command "dd if=/dev/sdc of=/mnt/storage/image.img conv=sync,noerror bs=64k"
testdisk.log attached. Any help is much appreciated!
testdisk.log.zip
(6.41 KiB) Downloaded 556 times
