MicroSD lost partition
x46x
#1 Post by x46x »
Hi, my card lost partition when I insert it from HTC to Samsung phone, in phone and windows it say that the card must be formated. Testdisk say there are no partition, before it I hade one extFAT partition around 50GB and 1 ext4 partition around 14GB, I want only recover the extFAT partition but dont know what I must to do. Can anyone help me please? PhotoRec recover some data, but only few percent.. I want recover whole disk if it is possible-there are lot of memmories.. :-( Thank you
There is a log:
Tue Aug 18 09:27:42 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=640135028736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=63864569856
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=104752742400
filewin32_getfilesize(\\.\D:) GetFileSize err Nesprávná funkce.
filewin32_setfilepointer(\\.\D:) SetFilePointer err Nesprávná funkce.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2891005952
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000364240896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=500096991744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=53689188352
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\X:)=535273930752
Disk /dev/sda - 640 GB / 596 GiB - CHS 82689 240 63, sector size=512
Disk /dev/sdb - 63 GB / 59 GiB - CHS 7764 255 63, sector size=512
Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 104 GB / 97 GiB - CHS 13531 240 63, sector size=512
Drive E: - 2891 MB / 2757 MiB - CHS 689 64 32, sector size=2048
Drive G: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive H: - 500 GB / 465 GiB - CHS 60799 255 63, sector size=512
Drive I: - 53 GB / 50 GiB - CHS 6527 255 63, sector size=512
Drive X: - 535 GB / 498 GiB - CHS 69143 240 63, sector size=512
check_part_i386 1 type FF: no test
check_part_i386 2 type FF: no test
check_part_i386 3 type FF: no test
check_part_i386 4 type FF: no test
 3 * Xenix bad block      267346 209  1 534696  43  3 4294967295
 4 * Xenix bad block      267349  89  4 267349  93  6        255
 1 * Xenix bad block      267349  89  4 534698 178  6 4294967295
Image created successfully but read errors have occured.
New options :
 Dump : No
 Align partition: Yes
 Expert mode : No
Analyse Drive I: - 53 GB / 50 GiB - CHS 6527 255 63
Warning: Bad starting head (CHS and LBA don't match)
 2 * Xenix bad block      267349  89  4 534698 178  6 4294967295
interface_load
Re: MicroSD lost partition
First of all, I'd like to check your current partition table (current partition structure).
Can you select your microSD card as disk instead of a drive?
Would probably in your disk selection here:
You'll find your current partition structure at TestDisk / Analyse.
Unfortunately testdisk doesn't support exfat boot sector recovery.
But if your partition would be available in your partition table, you can run testdisk / Advanced / Boot and have a try to list your files using the menu List.
If your partition is not in your partition table, you can run Quick and Deeper Search to have a try to find it by the boot sector or its backup.
If your exfat partition would be found, you can select it and press p to have a try to list your files.
Otherwise you can try to run PhotoRec to recover your files.
x46x
#3 Post by x46x »
So there is another log, maybe i'm wrong there is NTFS partition but I can't read from it.. From ext4 partition i can read normally.
Tue Aug 18 10:47:58 2015
Analyse Disk /dev/sdb - 63 GB / 59 GiB - CHS 7764 255 63
Invalid NTFS or EXFAT boot
 1 P HPFS - NTFS              0  32 33  6527 118 55  104861696
 2 P Linux                 6527 151 25  7763 233 22   19861504
recover_EXT2: s_block_group_nr=0/75, s_mnt_count=10/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 2482688
recover_EXT2: part_size 19861504
     ext4 blocksize=4096 Large_file Sparse_SB, 10169 MB / 9698 MiB
file_pread(5,2,buffer,124735488(7764/108/25)) ReadFile Chyba dat (cyklická redundantní kontrola).
file_pread(5,1,buffer,124735488(7764/108/25)) ReadFile Chyba dat (cyklická redundantní kontrola).
file_pread(5,14,buffer,124735489(7764/108/26)) lseek err Invalid argument
file_pread(5,1,buffer,124735489(7764/108/26)) lseek err Invalid argument
file_pread(5,8,buffer,124735495(7764/108/32)) lseek err Invalid argument
file_pread(5,3,buffer,124735503(7764/108/40)) lseek err Invalid argument
file_pread(5,3,buffer,124735550(7764/109/24)) lseek err Invalid argument
file_pread(5,8,buffer,124735566(7764/109/40)) lseek err Invalid argument
file_pread(5,11,buffer,124735613(7764/110/24)) lseek err Invalid argument
file_pread(5,2,buffer,124737535(7764/140/56)) lseek err Invalid argument
file_pread(5,8,buffer,124735488(7764/108/25)) ReadFile Chyba dat (cyklická redundantní kontrola).
file_pread(5,1,buffer,124735506(7764/108/43)) lseek err Invalid argument
file_pread(5,1,buffer,124735553(7764/109/27)) lseek err Invalid argument
file_pread(5,1,buffer,124735574(7764/109/48)) lseek err Invalid argument
file_pread(5,1,buffer,124735624(7764/110/35)) lseek err Invalid argument
file_pread(5,1,buffer,124737537(7764/140/58)) lseek err Invalid argument
   * Linux                 6527 151 25  7763 233 22   19861504
 1 * Linux                 6527 151 25  7763 233 22   19861504
block_group_nr 1
recover_EXT2: s_block_group_nr=1/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 10169 MB / 9698 MiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 25
recover_EXT2: s_block_group_nr=25/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/75, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
dir_partition inode=2
       2 drwxr-xr-x     0      0      4096 24-Jul-2015 10:31 .
       2 drwxr-xr-x     0      0      4096 24-Jul-2015 10:31 ..
  343393 drwxrwx---     0      0      4096 24-Jul-2015 10:31 lost+found
dir_partition inode=343393
Directory /lost+found
  343393 drwxrwx---     0      0      4096 24-Jul-2015 10:31 .
Not an exFAT boot sector.
ntfs_boot_sector
filesystem size           1 3752333508279412924
sectors_per_cluster       0 51
mft_lcn                   0 3890141541
mftmirr_lcn               0 4163224220
clusters_per_mft_record   0 -82
clusters_per_index_record 0 -73
Status: Bad
Status: Bad
Sectors are not identical.
#4 Post by Fiona »
Exfat is a bit different.
It's an NTFS partition but the boot sector and the file system is exfat.
That's why a NTFS partition is displayed and the boot sector is exfat.
Example:
The partition is displayed as NTFS but in the last line at the bottom of the display you'll see info about the boot sector.
It's exfat!
I've checked your log file.
The problem is, the boot sector and its backup are either not valid or not available.
That's why I'd recommend to use PhotoRec:
Info:
x46x
#5 Post by x46x »
Thank you, but PhotoRec restore my backup's of programs with a different name so my backup program (titanium backup) can't restore them ( beause there is two files fo each apps and it must have a same name for restore). So is there any other chance for restore partition?
