I am trying to run Photorec Marvelll editiom on my Qnap, but says that
Terminfo files is missing
Extract all files and subdirectories before running the program.
I have extractet it using Winrar and copied it to my Nas, and then I did a chmod 777 * but I cannot see that I am missing some files during extract. I have tried the beta version as well, same result.
Any ideas?
Terminfo file is missing
Re: Terminfo file is missing
There should be a file named testdisk-7.1-WIP/l/linux
If it's missing or not in the subdirectory named "l", you will get this error message.
