I'm begging for expert help! I don't want to lose my 177 recordings of TV shows and movies.
I need to fix the partition on a 2TB external hard drive I'm using with an Arris HDPVR 630 (Canadian Shaw satellite TV).
The drive is only a few months old and has been working great with the PVR until I did something incredibly stupid.
I disconnected the external HD from the PVR and connected it to my Windows computer. I just wanted to take a look. Before I could think, I had "initialized" the drive in Windows. At that point I realized how stupid I am, and stopped.
I reconnected the external HD to the Arris HDPVR 630, and it now says it needs to format the drive to use it.
So the 177 recordings are still there, but the partition needs to be fixed. I don't know what file system the HDPVR 630 uses.
I downloaded and burned "SystemRescueCD" to a CD then booted from it. At the moment I've got TestDisk scanning the drive, but it looks like it's going to take a very long time.
PVR external hard drive partition fix?
Re: PVR external hard drive partition fix?
I don't know the filesystem used on your PVR.
You can always try PhotoRec to see if it recovers your videos.
