Any help is appreciated!!!
binakajs
#1 Post by binakajs »
Hello there,
I am having a problem with my "converted" external hard drive. After upgrading my harddrive to solid state hard drive. I started needing the space in the computer to run the programs. Then I converted my old hard drive and made it external (with one of those small portable cases). I used that for all my documents. But recently I decided to get a dock for it. After doing so I lost one of the partitions. The hard drive had two partitions the "recovery" and the "F" (where I had everything stored). Now every time I try to open "F" it says the the drive must be formatted before use.
So now I am trying to recover it with TestDisk. Here is a snapshot of how windows sees it.
Eventhough "F" is broken, I can still access the recovery partition.
By the way, I had windows 7 installed in the hard drive. And now I have windows 10 on my computer.
Things I have tried;
I tried different usb ports of my computer.
I tried the dock connection and the hard drive enclosure.
With TestDisk, I ran the analysis. But I am running it again and this is what its showing so far.
and on the TestDrive.log this is the information displayed.
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=34359738368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=715792580608
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk /dev/sdb - 750 GB / 698 GiB - CHS 91201 255 63, sector size=512
Drive C: - 119 GB / 111 GiB - CHS 14580 255 63, sector size=512
Drive E: - 34 GB / 32 GiB - CHS 4177 255 63, sector size=512
Drive F: - 715 GB / 666 GiB - CHS 87023 255 63, sector size=512
Analyse Drive F: - 715 GB / 666 GiB - CHS 87023 255 63
I will Update when TestDrive its done.
If someone knows that this is a dead end for me trying to recover the partition please let me know. Than I will run photorec and save as much data I can. I cant describe how important this data its to me.
Any help or hints are really appreciated!
THANKS!
