Partition recovery after windows installation
boobytrap
#1 Post by boobytrap »
For some reason after i tried to install windows on another partition my entire partition table got deleted and instead of i 1TB disk it showed just a 137gb empty space. WIth testdisk i was able to recover all except one 50-60gb NTFS partition (i don't remember the exact size) which is now shown as 39gb unallocated along with some 1mb to 6mb chunks. I run the whole deeper search for about 5 hours which gave me some errors you'll se below in the log. When i clicked list files it wouldn't show saying it's to corrupted.
fdisk -l output
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: dos
Disk identifier: 0x69205244
Device     Boot     Start        End    Sectors   Size Id Type
/dev/sda1  *     81920000  169768959   87848960  41.9G 83 Linux
/dev/sda2       169771008  171724799    1953792   954M 82 Linux swap / Solaris
/dev/sda3       171726848  172023807     296960   145M 83 Linux
/dev/sda4       172023808 1953523711 1781499904 849.5G  f W95 Ext'd (LBA)
/dev/sda5       172036096 1953519615 1781483520 849.5G  7 HPFS/NTFS/exFAT
gparted:
testdisk.log
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 121601 255 63
NTFS at 10708/191/44
 1 * Linux                 5099  72 30 10567 160 25   87848960 [kali]
 2 P Linux Swap           10567 192 58 10689  95 30    1953792
 3 P Linux                10689 127 63 10707 251 40     296960
 4 E extended LBA         10707 251 41 121601  57 56 1781499904
 5 L HPFS - NTFS          10708 191 44 121600 247 55 1781483520
Backup partition structure
partition_save
recover_EXT2: s_block_group_nr=0/335, s_mnt_count=525/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
recover_EXT2: s_blocks_count 10981120
recover_EXT2: part_size 87848960
     ext4 blocksize=4096 Large file Sparse superblock Recover, 44 GB / 41 GiB
     Linux Swap           10567 192 58 10689  95 14    1953776
     SWAP2 version 1, pagesize=4096, 1000 MB / 953 MiB
recover_EXT2: s_block_group_nr=0/18, s_mnt_count=679/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1960
recover_EXT2: s_blocks_count 148480
recover_EXT2: part_size 296960
     ext4 blocksize=1024 Sparse superblock, 152 MB / 145 MiB
filesystem size           1781483520
sectors_per_cluster       8
mft_lcn                   4
mftmirr_lcn               111342719
clusters_per_mft_record   -10
     NTFS, blocksize=4096, 912 GB / 849 GiB
     SWAP2 version 1, pagesize=4096, 1000 MB / 954 MiB
add_ext_part_i386: max
NTFS at 5099/72/29
filesystem size           81917952
mft_lcn                   4
mftmirr_lcn               5119871
     HPFS - NTFS              0  32 33  5099  72 29   81917952
     NTFS found using backup sector, blocksize=4096, 41 GB / 39 GiB
block_group_nr 1
recover_EXT2: s_block_group_nr=1/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     ext4 blocksize=4096 Large file Sparse superblock Backup superblock, 44 GB / 41 GiB
block_group_nr 3
recover_EXT2: s_block_group_nr=3/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 5
recover_EXT2: "e2fsck -b 163840 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=5/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 9
recover_EXT2: "e2fsck -b 294912 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=9/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 25
recover_EXT2: s_block_group_nr=25/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 27
recover_EXT2: "e2fsck -b 884736 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=27/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 49
recover_EXT2: "e2fsck -b 1605632 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=49/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 81
recover_EXT2: "e2fsck -b 2654208 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=81/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
NTFS at 7139/31/60
filesystem size           114688000
mftmirr_lcn               2
     HPFS - NTFS              0  32 33  7139  31 60  114688000
     NTFS found using backup sector, blocksize=4096, 58 GB / 54 GiB
recover_EXT2: s_block_group_nr=0/210, s_mnt_count=681/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8160
recover_EXT2: s_blocks_count 6884864
recover_EXT2: part_size 55078912
     Linux                 7139  31 61 10567 160 25   55078912
     ext4 blocksize=4096 Large file Sparse superblock, 28 GB / 26 GiB
recover_EXT2: s_block_group_nr=0/335, s_mnt_count=524/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
     Linux                 7728 218 43 13197  51 38   87848960 [kali]
     Linux                 7732 173 58 13201   6 53   87848960 [kali]
FAT16 at 7942/164/31
FAT1 : 1-156
FAT2 : 157-312
start_rootdir : 313
Data : 345-159548
sectors : 159552
cluster_size : 4
no_of_cluster : 39801 (2 - 39802)
fat_length 156 calculated 156
heads/cylinder 64 (FAT) != 255 (HD)
     FAT16 LBA             7942 164 31  7952 147  3     159552 [NO NAME]
     FAT16, blocksize=2048, 81 MB / 77 MiB
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/335, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8176
block_group_nr 1
recover_EXT2: "e2fsck -b 8193 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=1/18, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1960
     Linux                10689 127 61 10707 251 38     296960
     ext4 blocksize=1024 Sparse superblock Backup superblock, 152 MB / 145 MiB
block_group_nr 3
recover_EXT2: "e2fsck -b 24577 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=3/18, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1960
block_group_nr 5
recover_EXT2: "e2fsck -b 40961 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=5/18, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1960
block_group_nr 7
recover_EXT2: "e2fsck -b 57345 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=7/18, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1960
block_group_nr 9
recover_EXT2: "e2fsck -b 73729 -B 1024 device" may be needed
recover_EXT2: s_block_group_nr=9/18, s_mnt_count=0/4294967295, s_blocks_per_group=8192, s_inodes_per_group=1960
mft_lcn                   4
BAD_RS LBA=3069233919 749725
     FAT16 >32M           191050 248 46 208745 229 46  284268979
This partition ends after the disk limits. (start=3069233919, size=284268979, end=3353502897, disk end=1953525168)
BAD_RS LBA=3120452955 12220473
     FAT32                194239  54 19 277054 223 55 1330433659
This partition ends after the disk limits. (start=3120452955, size=1330433659, end=155919317, disk end=1953525168)
NTFS at 121600/247/55
mft_lcn                   4
     NTFS found using backup sector, blocksize=4096, 912 GB / 849 GiB
The harddisk (1000 GB / 931 GiB) seems too small! (< 2278 GB / 2122 GiB)
     Linux                 7139  31 61 10567ntfs_mst_post_read_fixup_warn: magic: 0x00000000  size: 1024   usa_ofs: 0  usa_count: 65535: Invalid argument
Record 0 has no FILE magic (0x0)
ntfs_mst_post_read_fixup_warn: magic: 0xd1cbae36  size: 1024   usa_ofs: 18343  usa_count: 6173: Invalid argument
Record 0 has no FILE magic (0xd1cbae36)
 160 25   55078912
     FAT16 LBA             7942 164 31  7952 150  6     159744 [NO NAME]
     FAT16, blocksize=2048, 81 MB / 78 MiB
Not an exFAT boot sector.
As you can shee it shows a 58gb but it is not recoverable, and also a NTFS 41gb which i don't know what it is. I wonder if i have other options or i should just reformat the partition and consider the data lost. Thanks in advance!
Re: Partition recovery after windows installation
Old OS (Windows 2000 before SP4, XP before SP1...) are limited to 128 GB/137GB. Are you in this case ?
boobytrap
#3 Post by boobytrap »
Yes, i forgot to mention it was Windows Xp i was trying to install. Wish i'd known about this limitation, that's probably what messed up everything.
Btw, this is what gparted show, which is not visible in the original post for some reason:
http://www.fastpic.info/image/1d280eae2a
