I've been reading the forum for three days and I can't find my solution, and everything I tried doesn't work...
My problem:
I have an HDD (Seagate Barracuda, 1TB) full of data. The Hard disk is used via USB in an external case with windows. One day, the disk seems corrupted and windows doesn't detect it. The hard disk belongs to my father and I'm trying to recover the data.
I'm trying to recover the data with my laptop (macbook pro, osx yosemite) and with the HDD connected via USB because my father lives in another city and I can't access his windows computer. So, this is what I tried:
- When I connect the HDD, mac tells me that "The disk you inserted was not readable by this computer."
- In terminal -> If I type: "diskutil list"
/dev/disk0
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *251.0 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_CoreStorage 250.1 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
/dev/disk1
0: Apple_HFS Macintosh HD *249.8 GB disk1
Logical Volume on disk0s2
47730EEF-CE97-41BD-99C0-17DB442B5EA8
Unencrypted
/dev/disk2
0: FDisk_partition_scheme *33.3 MB disk2
1: Windows_NTFS 32.3 MB disk2s1Code: Select all
/dev/disk2
1: Windows_NTFS 32.3 MB disk2s1After try with the recovery of mac ( diskutil repairDisk /dev/disk2) with no success, I've tried with TestDisk. Select the correct disk (recognized as 33Mb), with "Intel/PC partition" (TestDisk recomends that), and then analyse, quick search and deep search.
Apparently, TestDist found 1 partition, but it says that this partition can't be recovered...This is the full log of TestDisk:
Tue Sep 15 23:22:44 2015
OS: Darwin, kernel 14.5.0 (Darwin Kernel Version 14.5.0: Wed Jul 29 02:26:53 PDT 2015; root:xnu-2782.4
Compiler: GCC 4.0
Compilation date: 2015-04-18T13:01:34
Disk /dev/disk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/disk2 - 33 MB / 31 MiB - 65134 sectors, sector size=512
Disk /dev/rdisk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/rdisk1 - 249 GB / 232 GiB - 487830528 sectors, sector size=512
Disk /dev/rdisk2 - 33 MB / 31 MiB - 65134 sectors, sector size=512
New options :
Dump : No
Align partition: Yes
Expert mode : No
Analyse Disk /dev/disk2 - 33 MB / 31 MiB - 65134 sectors
NTFS at 2048/0/1
NTFS: Can't read MFT
get_geometry_from_list_part_aux head=1 nbr=2
Warning: number of heads/cylinder mismatches 255 (NTFS) != 1 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 1 (HD)
1 P HPFS - NTFS 2048 1953519615 1953517568
file_pread(5,16,buffer,2368(2368/0/1)) read err: Input/output error
file_pread(5,16,buffer,2369(2369/0/1)) read err: Input/output error
file_pread(5,16,buffer,2370(2370/0/1)) read err: Input/output error
file_pread(5,16,buffer,2371(2371/0/1)) read err: Input/output error
file_pread(5,16,buffer,2372(2372/0/1)) read err: Input/output error
file_pread(5,16,buffer,2373(2373/0/1)) read err: Input/output error
file_pread(5,16,buffer,2374(2374/0/1)) read err: Input/output error
file_pread(5,16,buffer,2375(2375/0/1)) read err: Input/output error
file_pread(5,16,buffer,2376(2376/0/1)) read err: Input/output error
file_pread(5,1,buffer,2376(2376/0/1)) read err: Input/output error
file_pread(5,1,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,1,buffer,2378(2378/0/1)) read err: Input/output error
file_pread(5,1,buffer,2379(2379/0/1)) read err: Input/output error
file_pread(5,1,buffer,2380(2380/0/1)) read err: Input/output error
file_pread(5,16,buffer,2381(2381/0/1)) read err: Input/output error
file_pread(5,1,buffer,2381(2381/0/1)) read err: Input/output error
file_pread(5,16,buffer,2382(2382/0/1)) read err: Input/output error
file_pread(5,1,buffer,2382(2382/0/1)) read err: Input/output error
file_pread(5,16,buffer,2383(2383/0/1)) read err: Input/output error
file_pread(5,1,buffer,2383(2383/0/1)) read err: Input/output error
file_pread(5,16,buffer,1196(1196/0/1)) read err: Input/output error
file_pread(5,16,buffer,1197(1197/0/1)) read err: Input/output error
file_pread(5,16,buffer,1198(1198/0/1)) read err: Input/output error
file_pread(5,16,buffer,1199(1199/0/1)) read err: Input/output error
file_pread(5,16,buffer,1264(1264/0/1)) read err: Input/output error
NTFS at 2048/0/1
filesystem size 1953517568
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=1000200994816, sector_size=512
NTFS at 2048/0/1
mftmirr_lcn 2
This partition ends after the disk limits. (start=2048, size=1953517568, end=1953519615, disk end=65134)
file_pread(5,16,buffer,2365(2365/0/1)) read err: Input/output error
file_pread(5,16,buffer,2367(2367/0/1)) read err: Input/output error
file_pread(5,16,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,3,buffer,2378(2378/0/1)) read err: Input/output error
file_pread(5,9,buffer,2375(2375/0/1)) read err: Input/output error
file_pread(5,5,buffer,2373(2373/0/1)) read err: Input/output error
file_pread(5,16,buffer,2378(2378/0/1)) read err: Input/output error
file_pread(5,16,buffer,2363(2363/0/1)) read err: Input/output error
file_pread(5,16,buffer,2379(2379/0/1)) read err: Input/output error
file_pread(5,16,buffer,2366(2366/0/1)) read err: Input/output error
file_pread(5,16,buffer,2380(2380/0/1)) read err: Input/output error
file_pread(5,16,buffer,2364(2364/0/1)) read err: Input/output error
file_pread(5,2,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,3,buffer,2379(2379/0/1)) read err: Input/output error
file_pread(5,3,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,3,buffer,2380(2380/0/1)) read err: Input/output error
file_pread(5,4,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,3,buffer,2381(2381/0/1)) read err: Input/output error
file_pread(5,5,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,3,buffer,2382(2382/0/1)) read err: Input/output error
file_pread(5,6,buffer,2377(2377/0/1)) read err: Input/output error
file_pread(5,3,buffer,2383(2383/0/1)) read err: Input/output error
file_pread(5,16,buffer,4687(4687/0/1)) read err: Input/output error
file_pread(5,16,buffer,4688(4688/0/1)) read err: Input/output error
file_pread(5,1,buffer,4688(4688/0/1)) read err: Input/output error
file_pread(5,16,buffer,4689(4689/0/1)) read err: Input/output error
file_pread(5,1,buffer,4689(4689/0/1)) read err: Input/output error
file_pread(5,16,buffer,4690(4690/0/1)) read err: Input/output error
file_pread(5,1,buffer,4690(4690/0/1)) read err: Input/output error
file_pread(5,16,buffer,4691(4691/0/1)) read err: Input/output error
file_pread(5,1,buffer,4691(4691/0/1)) read err: Input/output error
file_pread(5,16,buffer,4692(4692/0/1)) read err: Input/output error
file_pread(5,1,buffer,4692(4692/0/1)) read err: Input/output error
file_pread(5,16,buffer,4693(4693/0/1)) read err: Input/output error
file_pread(5,1,buffer,4693(4693/0/1)) read err: Input/output error
The harddisk (33 MB / 31 MiB) seems too small! (< 1000 GB / 931 GiB)
NTFS at 2048/0/1
mftmirr_lcn 2
NTFS at 2048/0/1
mftmirr_lcn 2
file_pread(5,7,buffer,2375(2375/0/1)) read err: Input/output error
file_pread(5,16,buffer,2362(2362/0/1)) read err: Input/output error
After that, I've tried with photorec, and seems to work but only recover files of the 33Mb "part"... only a few photos.
Anyone can help me to recover the disk and it´s data?
Thanks!!!
