Linux Mint 17.2 Cinnamon 64-bit 2.6.13 Linux Kernel 3.13.0-37 generic Processor AMD A8-5500 APU with Radeon HD Graphics x 2 Memory 7.7 GiB Hard Drives 450.2 GB Graphics Card AMD Seymour (Radeon HD 6400M/7400 M series VGA controller).
WD My Passport 2 TByte formatted with GParted for Linux as a single partition after removing WD's material since the single purpose was for storage.
What happened:
Tried to retrieve (copy) a file to the main drive but while a filename was present there was nothing behind it (no file). I tried again with another file with the same result. I opened as many directories as I could until the system froze. Except for maybe 4 directories the result was the same. Restarted the system and the external drive. Managed to copy a few more until it froze again. Restarted.
I read Gparted's help file which led me to TestDisk. Ran it and saved the attached log file.
Problem:
Apparently one of the problems is the Backup drive has corrupted files and directories. 45% into the TestDrive run about cylinger 103,000 out of 243,196 showed the following message:
Check_FAT: can't read FAT boot sector.
Invalid FAT BOOT sector.
0 D FAT32 257577 183 38 296757 80 52 629420222
Finished:
The harddisk (2000GB / 1862 GiB) seems too small (<2440 GB /2273 GiB)
Check the harddisk size: HD jumpers settings, BIOS detection.
The following partitions can't be recovered.
> FAT32 257577183 38 296757 88 52 629428226
Continue: 322GB / 300GiB
At which time I had a finger-mouse spasm which ended the operation.
Question:
If this external drive was partitioned for Linux as a single storage repository, why does it have a FAT32 partition?
Thanks, all.
Mist
Unable to upload attachments so...
Backup.log
#1442612239 Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63
1 : start= 1985, size=3906957375, Id=0F, E
5 : start= 2048, size=3906957312, Id=07, L
Test Drive.log
Fri Sep 18 14:34:00 2015
OS: Linux, kernel 3.13.0-37-generic (#64-Ubuntu SMP Mon Sep 22 21:28:38 UTC 2014) x86_64
Compiler: GCC 4.8
Compilation date: 2013-10-29T01:29:29
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 976773168 sectors
/dev/sda: user_max 976773168 sectors
/dev/sdb: size 1953525168 sectors
/dev/sdb: user_max 1953525168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500DM002-1BD142, S/N:W2APD70L, FW:KC45
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000524AS, S/N:9VPFW8QH, FW:JC45
Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512 - WD My Passport 0748, FW:1019
Disk /dev/sdc - 2000 GB / 1862 GiB - WD My Passport 0748
Analyse Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63
NTFS at 0/32/33
1 E extended LBA 0 31 33 243196 247 59 3906957375
5 L HPFS - NTFS 0 32 33 243196 247 59 3906957312 [My Passport]
Backup partition structure
partition_save
NTFS at 0/32/33
filesystem size 3906957312
mft_lcn 90114
mftmirr_lcn 90113
NTFS, blocksize=4096, 2000 GB / 1862 GiB
NTFS at 243197/57/60
filesystem size 3906961408
mftmirr_lcn 2
HPFS - NTFS 0 32 33 243197 57 60 3906961408
NTFS found using backup sector, blocksize=4096, 2000 GB / 1862 GiB
1 P HPFS - NTFS 0 32 33 243196 247 59 3906957312 [My Passport]
ntfs_mst_post_read_fixup_warn: magic: 0x6ce8f4ab size: 1024 usa_ofs: 49267 usa_count: 22959: Invalid argument
Record 0 has no FILE magic (0x6ce8f4ab)
