RAID6 partition Lost
Franck67
#1 Post by Franck67 »
after a RAID6 reconstruction, my system can't see my partition anymore, tho its finding some stuffs with testdisk
I have 12 disks, on a 20Tb array.
I ran testdisk with partition type "INTEL", and after a deeper search : i could see my LVM partition with this message :
Disk /dev/sda - 19 TB / 18 TiB - CHS 2431514 255 63
The harddisk (19 TB / 18 TiB) seems too small! (< 37 TB / 34 TiB)
Partition    Start               End                 Size in sectors
> Linux LVM     2138794 202 33  4570309 103 34   39062282240
[ Continue ]
LVM2, 19 TB / 18 Tib
if i seach the partition with type none,
i find a
>   P Linux LVM2    0 0 1      2431514 156 2   39062282240
it comes in a middle of many (~30) crappy partitions, that i never heard about.. (NTFS/HFS/Linux swap 3 /FAT12/XFS4
but the only option left i have is to quit, cause i cant write when i selected "none".
someone has an idea ?
thx a lot
Re: RAID6 partition Lost
Are you certain the device was partioned ?
Franck67
#3 Post by Franck67 »
no im not.
its part of a NAS server. it came like this when i bought it
the system (open E) is on a flash drive. i was dealing with my shares from that system only.
i never did or touch a partition myself.
but according to the open E support there should be a LVM linux partition
im also french, we could skype or i couldvopen u a ssh access if u want to try yourself
