WD Passport 500GB Not Detected on PC
StarD3
#1 Post by StarD3 »
Hi! I am trying to access my ext HD. There is no letter associated with it. It says unallocated.
I ran TestDisk and it shows The following:
P Unknown 0 0 1 60797 59 62 976707584
The Ext HD is still flashing so it is communicating with the drive but nothing else is happening.
I have so much valuable data on this drive and hope I can retrieve it. :(
Any help would be appreciated..
Thanks!
Re: WD Passport 500GB Not Detected on PC
Choose PC/Intel or GPT EFI partition table type.
will007
#3 Post by will007 »
Hi StarD3, you may have the same issue as me, see my post
StarD3
#4 Post by StarD3 »
cgrenier wrote:Choose PC/Intel or GPT EFI partition table type.
Thank you for your help!!
I chose GPT ETFI Partition Table Type and this is what came up:
Disk /dev/sdb - 500 GB / 465 GiB - CHS
Partition Start
Trying alternate GPT
I brought my drive to a PC repair shop the other day. He said just format it then run a recovery program. He tried to format it (no charge) and said he couldn't because "it has bad sectors" and it's a "hardware issue" and "there is no way to get anything off this drive."
Not sure if that's true.
#5 Post by Fiona »
What partition table type did TestDisk autodetect?
In TestDisk under disk selection, did you select your disk as Disk, PhysicalDrive or Drive?
Did you use TestDisk 32bit or TestDisk 34bit?
StarD3
#6 Post by StarD3 »
Fiona wrote:What partition table type did TestDisk autodetect?
I chose Choose >Disk /dev/sdb - 500 GB / 465 GiB
I tried both of these: PC/Intel and GPT EFI partition table type.
Here's what showed:
CHS 60797 255 63 - sector size=512
>[ Analyse ] Analyse current partition structure and search for lost partitions
[ Advanced ] Filesystem Utils
[ Options ] Modify options
[ MBR Code ] Write TestDisk MBR code to first sector
[ Delete ] Delete all data in the partition table
[ Quit ] Return to disk selection
I chose Analyse and this is what showed:
Partition: Read error
>[Quick Search]
Try to locate partition
I hit enter and see the drive LED flashes but nothing happens
StarD3
#7 Post by StarD3 »
Okay... I was able to see the drive but when I went to look at the files I got this:
"Can't open filesystem. Filesystem seems damaged."
The only option on the bottom is to "quit"
StarD3
#8 Post by StarD3 »
"Can't open filesystem. Filesystem seems damaged." The only option on the bottom is to "quit" I hit quit and was able to get this far:
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60797 255 63
1 * HPFS - NTFS 0 32 33 60797 59 62 976705536
ntfs_boot_sector: Can't read boot sector.
Status: Bad
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are identical.
[ Quit ] >[Rebuild BS] [ Dump ]
Rebuild boot sector
StarD3
#9 Post by StarD3 »
Status: Bad
Status: Bad
Rebuild boot sector
I hit Rebuild Boot sector and the drive is flashing so I hope I did the right thing. Not sure if it takes long or not.
#10 Post by Fiona »
Partition read error often indicate some problems with bad sectors.
Can you check your disk using CrystalDiskInfo?
Please use the portable version without ads.
Your current partition structure (partition table) displayed a read error.
If you have no partition in your partition table, I wonder how TestDisk lists one under Advanced?
Watch here:
Looks like that's only an unformatted partition?
A partition only has no filesystem nor boot sector.
Only formatting creates a boot sector and file system , on NTFS would be a MFT.
That's why a message appears like:
Status: Bad
Status: Bad
This message means, that your boot sector is bad (not valid) or you have no boot sector.
Also, "can't read boot sector" can make aware of a bad sector?
Until yet, formatting should be avoided, because it'll override your lost file system.
Datarecovery software would be an idea.
PhotoRec could help.
Info will follow.
But bad sectors can cause that datarecovery software will hang, reading bad sectors.
If you have not as many bad sectors, cloning might help?
First of all, crystaldiskinfo would be important.
Don't remove your disk out of its enclosure.
