File system RAW
Re: File system RAW
Currently you are using PhotoRec.
Have you been able to reciver files?
Thumb drives often are not Intel MBR standard.
Geometry is determined by manufacturer.
Despite that I would need infos from Analyse (your current partition table) Quick and Deeper Search.
If it doesn't help, you should do a diagnose using partition table type none.
Infos will follow.
Infos will follow.
Re: File system RAW
i would still like to rebuild the filesystem structure any suggestions on how to go about this?
________________________________________________________
android smart phone Dropad A10 A70
Who is online
Users browsing this forum: Google Adsense [Bot] and 0 guests
