Hi.
I'm trying to recover data from a Micro SD card. Windows 10 recognized the card, but Photorec don't listed the card as disk (Listed a StickPro like a diskm but the Micro SD not).
Exist some way to make that Photorec recognize the Micro Sd?.
Thanks.
Arcadio
Micro SD don't recognized
Re: Micro SD don't recognized
If you start Windows Disk manager, do you see it ? Is the size correct ?
If you try another MicroSD in your card reader, does PhotoRec detect it ?
Hi.
Yes, Disk Manager recognize the disc, but the Icon shows a SD card.
The size is correct. For the case I formated the card at the shown size, bur Photorec still don't recognize the card.
I conneted another card, a Sony camera card (MS) and photorec recongized it well.
The Micro SD is a Nokia card.
Thanks for your response.
Arcadio.
Arcadio.
Strange...
If you run "photorec_win /all", do you see the missing Micro SD ?
I'll try later and write to you what happends.
Thank you.
Thank you.
Hi.
I tried using the command photorec_win /all, but still does not recognize the memory card.
Using 64-bit Windows 10 on a HP laptop with AMD processor. It could be that the problem?
I tried with my phone, connected to the laptop, and the File manager shows the discs like a phone. I can surf the discs, but photorec don't recognizes them.
Actually just recognize hard discs and USB drives.
