I need help with testdisk.
I've had two 2000 gb disks mounted in a NAS mode RAID Filesystem: ext4
One day there appeared a NTFS partition on both disks. The ext4 Partition was not accessible anymore.
I tried testdisk deeper search. Test disk does not find any ext4 partitions just several hsf+ besides the NTFS one. Unfortunately i do not have the log of the deeper search anymore. One search routine lasts 2 days. I ca do a new one if it helps.
Testdisk can not access the HSF+ partiotions for file listing.
I now tried to restore the mbr but testdisk was not able to do it. This operation also took 2 days. Please find the Log attached.
can anybody help me how I can recover the partition? I also tried photorec, but recovering the stored 1,5 tb would last 200h and the whole folder structure is gone. I am very despered at the moment
Wed Sep 30 14:35:25 2015
OS: Linux, kernel 3.16.0-49-generic (#65~14.04.1-Ubuntu SMP Wed Sep 9 10:03:48 UTC 2015) i686
Compiler: GCC 4.8
Compilation date: 2013-10-29T01:29:29
ext2fs lib: 1.42.9, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none
/dev/sda: size 312581808 sectors
/dev/sda: user_max 312581808 sectors
/dev/sda: native_max 312581808 sectors
/dev/sda: dco 312581808 sectors
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - Hitachi HTS545016B9A300, S/N:100618PBPB03ECDXVEJL, FW:PBBOC66G
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 30400 255 63, sector size=4096 - ST2000DM 001-9YN164
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - WDC WD10 EFRX-68PJCN0
Disk /dev/sdb - 2000 GB / 1863 GiB - ST2000DM 001-9YN164
Analyse Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 30400 255 63
BAD_RS LBA=2048 63
Invalid NTFS or EXFAT boot
1 P HPFS - NTFS 0 32 33 243194 237 51 3906924544
Bad relative sector.
NTFS signature is missing.
HPFS - NTFS 0 1 1 30399 96 34 488365954
exFAT, 2000 GB / 1862 GiB
* HPFS - NTFS 0 1 1 30399 254 63 488375937
exFAT, 2000 GB / 1863 GiB
dir_partition inode=0
1 * HPFS - NTFS 0 1 1 30399 254 63 488375937
HPFS - NTFS 0 4 5 243194 209 23 3906924544
exFAT, 16 TB / 14 TiB
This partition ends after the disk limits. (start=256, size=3906924544, end=3906924799, disk end=488378646)
The harddisk (2000 GB / 1863 GiB) seems too small! (< 16 TB / 14 TiB)
BAD_RS LBA=2048 63
Not an exFAT boot sector.
ntfs_boot_sector
filesystem size 6755455277203469 1
sectors_per_cluster 0 0
mft_lcn 1572878 0
mftmirr_lcn 1572880 0
clusters_per_mft_record 18 0
clusters_per_index_record 19 0
Status: Bad
ntfs_boot_sector: Can't read backup boot sector.
Status: Bad
Sectors are not identical.
rebuild_NTFS_BS
ntfs_boot_sector
mft_lcn 1572878 0
Status: Bad
Status: Bad
rebuild_NTFS_BS
Search mft stopped: 196608/3906924544
ntfs_boot_sector
mft_lcn 1572878 0
Status: Bad
Status: Bad
Boot sector Backup boot sector
0000 02001800 03001800 ........ 00000000 00000000 ........
0008 04001800 05001800 ........ 00000000 00000000 ........
0010 06001800 07001800 ........ 00000000 00000000 ........
0018 08001800 09001800 ........ 00000000 00000000 ........
0020 0a001800 0b001800 ........ 00000000 00000000 ........
0028 0c001800 0d001800 ........ 00000000 00000000 ........
0030 0e001800 0f001800 ........ 00000000 00000000 ........
0038 10001800 11001800 ........ 00000000 00000000 ........
0040 12001800 13001800 ........ 00000000 00000000 ........
0048 14001800 15001800 ........ 00000000 00000000 ........
0050 16001800 17001800 ........ 00000000 00000000 ........
0058 18001800 19001800 ........ 00000000 00000000 ........
0060 1a001800 1b001800 ........ 00000000 00000000 ........
0068 1c001800 1d001800 ........ 00000000 00000000 ........
0070 1e001800 1f001800 ........ 00000000 00000000 ........
0078 20001800 21001800 ...!... 00000000 00000000 ........
0080 22001800 23001800 "...#... 00000000 00000000 ........
0088 24001800 25001800 $...%... 00000000 00000000 ........
0090 26001800 27001800 &...'... 00000000 00000000 ........
0098 28001800 29001800 (...)... 00000000 00000000 ........
00A0 2a001800 2b001800 *...+... 00000000 00000000 ........
00A8 2c001800 2d001800 ,...-... 00000000 00000000 ........
00B0 2e001800 2f001800 ..../... 00000000 00000000 ........
00B8 30001800 31001800 0...1... 00000000 00000000 ........
00C0 32001800 33001800 2...3... 00000000 00000000 ........
00C8 34001800 35001800 4...5... 00000000 00000000 ........
00D0 36001800 37001800 6...7... 00000000 00000000 ........
00D8 38001800 39001800 8...9... 00000000 00000000 ........
00E0 3a001800 3b001800 :...;... 00000000 00000000 ........
00E8 3c001800 3d001800 <...=... 00000000 00000000 ........
00F0 3e001800 3f001800 >...?... 00000000 00000000 ........
00F8 40001800 41001800 @...A... 00000000 00000000 ........
0100 42001800 43001800 B...C... 00000000 00000000 ........
0108 44001800 45001800 D...E... 00000000 00000000 ........
0110 46001800 47001800 F...G... 00000000 00000000 ........
0118 48001800 49001800 H...I... 00000000 00000000 ........
0120 4a001800 4b001800 J...K... 00000000 00000000 ........
0128 4c001800 4d001800 L...M... 00000000 00000000 ........
0130 4e001800 4f001800 N...O... 00000000 00000000 ........
0138 50001800 51001800 P...Q... 00000000 00000000 ........
0140 52001800 53001800 R...S... 00000000 00000000 ........
0148 54001800 55001800 T...U... 00000000 00000000 ........
0150 56001800 57001800 V...W... 00000000 00000000 ........
0158 58001800 59001800 X...Y... 00000000 00000000 ........
0160 5a001800 5b001800 Z...[... 00000000 00000000 ........
0168 5c001800 5d001800 \...]... 00000000 00000000 ........
0170 5e001800 5f001800 ^..._... 00000000 00000000 ........
0178 60001800 61001800 `...a... 00000000 00000000 ........
0180 62001800 63001800 b...c... 00000000 00000000 ........
0188 64001800 65001800 d...e... 00000000 00000000 ........
0190 66001800 67001800 f...g... 00000000 00000000 ........
0198 68001800 69001800 h...i... 00000000 00000000 ........
01A0 6a001800 6b001800 j...k... 00000000 00000000 ........
01A8 6c001800 6d001800 l...m... 00000000 00000000 ........
01B0 6e001800 6f001800 n...o... 00000000 00000000 ........
01B8 70001800 71001800 p...q... 00000000 00000000 ........
01C0 72001800 73001800 r...s... 00000000 00000000 ........
01C8 74001800 75001800 t...u... 00000000 00000000 ........
01D0 76001800 77001800 v...w... 00000000 00000000 ........
01D8 78001800 79001800 x...y... 00000000 00000000 ........
01E0 7a001800 7b001800 z...{... 00000000 00000000 ........
01E8 7c001800 7d001800 |...}... 00000000 00000000 ........
01F0 7e001800 7f001800 ~....... 00000000 00000000 ........
01F8 80001800 81001800 ........ 00000000 00000000 ........
ntfs_boot_sector
mft_lcn 1572878 0
Status: Bad
Status: Bad
Thu Oct 1 11:46:09 2015
Compiler: GCC 4.8
BAD_RS LBA=2048 63
