I have a laptop with the following drive..
Toshiba MQ01ABD075 8455MB (CYL 16383, H16, S63)
750GB (LBA 1,465,149,168 Sectors)
It has been failing to boot recently, and ran testdisk 7.0 to check and fix any errors. Unfortunately, I seem to have made a mistake in this process and the PC will not boot at all 'A required drive partition is missing'. I have tried all recovery options, without success..
testdisk reports Current partition structure:
1 P MS Data 2048 534527 532480 [SONYSYS]
2 P MS Data 534528 3553279 3018752
3 P MS Data 3553280 4085759 532480 [NO NAME]
4 P MS Data 4347904 1406246911 1401899008
Partition 4 contains Windows (8.1). When I select [Analyse]..[Quick Search] Partition 4 is always reported as Deleted. I guess I need to make this Partition bootable .. how do I do this?
The testdisk.log file (attached) contains a number of 'read err: read after end of file'.. what causes this, and can I fix it using testdisk?
Can anyone help?
Cant make Partition bootable
- testdisk.zip
- testdisk.log file
- (1.87 KiB) Downloaded 543 times
