One of my main (non-system) 3TB SATA disks got very slow over the past week. A basic CHKDSK /r /f revealed alot of bad sectors. I got lucky and was able to backup about 99,9% of data.
- subsequently I used Win7's disk management to delete the (sole) partition and create a new partition + normal NTFS format.
So the disk is empty and 'free to play' so to say.
- Right now TestDisk runs an advanced scan and so far it has found
0 D FAT16 >32M : Invalid FAT boot sector
0 D FAT32 LBA: Invalid FAT boot sector
0 D FAT12: Invalid NTFS or EXFAT boot
0 D HPFS - NTFS: check_FAT: Can't read FAT boot sector - Invalid FAT boot sector
0 D FAT32 (still analyzing)
I'll add the log to this post as soon as its done, but any clue at this time?
Again: No important data of importance on the disk.
Edit: seems like there's no running log file. Heres a screenshot of the analysis so far:
and logfile for quick search:
Fri Oct 09 02:18:45 2015
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=1500301910016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255953207296
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1500299395072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000194015744
filewin32_getfilesize(\\.\H:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\H:) SetFilePointer err Incorrect function.
Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Drive C: - 255 GB / 238 GiB - CHS 31117 255 63, sector size=512
Drive D: - 3000 GB / 2794 GiB - CHS 364784 255 63, sector size=512
Drive F: - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Drive G: - 1000 GB / 931 GiB - CHS 121599 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive0 - 3000 GB / 2794 GiB - CHS 364801 255 63
NTFS at 16/113/34
filesystem size 5860268032
mftmirr_lcn 2
HPFS - NTFS 16 113 34 364801 66 1 5860268032
* HPFS - NTFS 16 113 34 364801 66 1 5860268032
1 * HPFS - NTFS 16 113 34 364801 66 1 5860268032
