Thank you in advance for any help.
None partition.
LohmanDude
None partition.
Hello. I have an ADATA 8Gb USB in RAW format. Tried the TestDisk Step by Step but after a "Deeper Search" I get no Partitions. I'm not familiar with programming so do not nknow what else to do. I tried to follow some suggestion I found around in comments but when I try to follow the commands, some option is always missing.
Re: None partition.
Please post the testdisk.log file content
