No such File or Directory Error for Encase images
gguan
#1 Post by gguan »
Hi All,
I have a problem trying to recover encase images from a path through command line, for example:
photorec_win /log /debug /d recupdir /cmd C:\Image\FTK.E01 search
It throws "No such file or directory" error
If i run from photorec root folder
photorec_win /log /debug /d recupdir /cmd FTK.E01 search
it does run well
But if I try to recover from a Raw image (.dd)
photorec_win /log /debug /d recupdir /cmd C:\Image\Raw.dd search
it does run and start recovering the deleted files.
My question is, Does recovering from encase images, the image needs to be in photorec_win folder or i could use a path?? if i could use a path then why im getting nO such file or directory error?
Thank you in advance.
Re: No such File or Directory Error for Encase images
Instead of
try
photorec_win /log /debug /d recupdir /cmd /cygdrive/C/Image/FTK.E01 search
gguan
#3 Post by gguan »
Yes it worked!!
Thank you so much cgrenier!!
gguan
#4 Post by gguan »
Another question does photorec works with a shared path like //user/shared/ftk.e01???
If it does how would be the syntax?
Thanks in advance.
