Heya all,
I'm trying to recover some mysql files and have some difficulties to tell photorec to search only for mysql files. I tried the following:
photorec /d /<backup_folder> /cmd <backup_image> partition_none,options,mode_ext2,fileopt,everything,disable,mysql,enable,search
PhotoRec syntax error: mysql,enable,search
myi,enable,search
MySQL,enable,search
SQL,enable,search
sql,enable,search
It all gives me syntax error.
When I try frm,enable,search then it starts.
What is the switch for all mysql files, and does this frm search for mysql or for Pro/ENGINEER Drawing Form. Because on http://www.cgsecurity.org/wiki/File_For ... y_PhotoRec both frm links point to the Drawing Form.
Regards,
Daniel
photorec fileopt explained
Re: photorec fileopt explained
Instead of Mysql, you should use "MYI".
