Shared Path folder
gguan
Shared Path folder
#1 Post by gguan »
Im trying to recover from an encase image using photorec but the image is located in a shared path, wonder if this is possible or photorec doesnt accept this kind of path, also the recovered files path can be a shared path? If it is possible what could be the syntax for the path to make photorec work?
Also I've been trying to recover from an external drive using /cygdrive/e and photorec doesn't do anything unless i use /dev/sdb
Thanks,
Best regards.
GGuan
