No partition found; RebuildBS takes too long
JayZon
#1 Post by JayZon »
Hi.
At first Ive been trying to recover the lost partition,by running the quicksearch but after 5days of waiting testdisk found no partition..and I also run the deep search and waited for a week..but still there is no partition found .. its been a month looking for solutions to recover and i also tried some other partition recovery softwares..most of the forum said testdisk is a good software.now im trying to ReBuild BS but I dont know if its worth waiting, its been 12hours..it takes too long..please help..all of my important files are there..Its a 500gb hard drive..im thinking of recovering data by using photorec but it will rename all of my files with no folders,unsorted..and another thing is that i dont have much bigger hard drive for the recovery.any suggestion will be so much appreciated.
Testdisk progress.12hrs
Re: No partition found; RebuildBS takes too long
Running testdisk / Adanced and Rebuid BS requires a correct partition in your partition table.
Looks like that testdisk doesn't find your MFT, its mirror or might corrupt.
Also it's unusual that a scan of a 500 GB disk takes so long?
Did you get read erorrs?
Read errors can cause that testdisk hangs.
Can you check your disk using crystaldiskinfo?
Please use the portable version.
Please run TestDisk / Analyse.
I'd like to see your current partition structure.
At Analyse and your current partition structure, you can close TestDisk.
Within your testdisk folder, you'll find your testdisk.log.
JayZon
#3 Post by JayZon »
Sat Nov 21 02:33:15 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=500107860480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500107860480
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=142341046272
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=107611160576
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=104857600
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512
Drive C: - 142 GB / 132 GiB - CHS 17305 255 63, sector size=512
Drive D: - 107 GB / 100 GiB - CHS 13082 255 63, sector size=512
Drive N: - 104 MB / 100 MiB - CHS 12 255 63, sector size=512
Partition: Read error
file_pread(5,16,buffer,32(0/0/33)) ReadFile Incorrect function.
file_pread(5,3,buffer,48(0/0/49)) ReadFile Incorrect function.
file_pread(5,3,buffer,95(0/1/33)) ReadFile Incorrect function.
file_pread(5,8,buffer,111(0/1/49)) ReadFile Incorrect function.
file_pread(5,11,buffer,158(0/2/33)) ReadFile Incorrect function.
file_pread(5,2,buffer,2080(0/33/2)) ReadFile Incorrect function.
file_pread(5,2,buffer,51(0/0/52)) ReadFile Incorrect function.
file_pread(5,2,buffer,98(0/1/36)) ReadFile Incorrect function.
file_pread(5,2,buffer,119(0/1/57)) ReadFile Incorrect function.
file_pread(5,2,buffer,169(0/2/44)) ReadFile Incorrect function.
file_pread(5,2,buffer,2082(0/33/4)) ReadFile Incorrect function.
file_pread(5,16,buffer,63(0/1/1)) ReadFile Incorrect function.
file_pread(5,3,buffer,79(0/1/17)) ReadFile Incorrect function.
file_pread(5,3,buffer,126(0/2/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,142(0/2/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,189(0/3/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,2111(0/33/33)) ReadFile Incorrect function.
file_pread(5,16,buffer,1008(0/16/1)) ReadFile Incorrect function.
file_pread(5,3,buffer,1024(0/16/17)) ReadFile Incorrect function.
file_pread(5,3,buffer,1071(0/17/1)) ReadFile Incorrect function.
file_pread(5,8,buffer,1087(0/17/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,1134(0/18/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,3056(0/48/33)) ReadFile Incorrect function.
file_pread(5,13,buffer,1074(0/17/4)) ReadFile Incorrect function.
file_pread(5,8,buffer,1150(0/18/17)) ReadFile Incorrect function.
file_pread(5,11,buffer,1197(0/19/1)) ReadFile Incorrect function.
file_pread(5,2,buffer,3119(0/49/33)) ReadFile Incorrect function.
file_pread(5,16,buffer,2048(0/32/33)) ReadFile Incorrect function.
file_pread(5,3,buffer,2064(0/32/49)) ReadFile Incorrect function.
file_pread(5,1,buffer,2113(0/33/35)) ReadFile Incorrect function.
file_pread(5,8,buffer,2127(0/33/49)) ReadFile Incorrect function.
file_pread(5,11,buffer,2174(0/34/33)) ReadFile Incorrect function.
file_pread(5,2,buffer,4096(0/65/2)) ReadFile Incorrect function.
file_pread(5,14,buffer,4098(0/65/4)) ReadFile Incorrect function.
file_pread(5,3,buffer,4112(0/65/18)) ReadFile Incorrect function.
file_pread(5,3,buffer,4159(0/66/2)) ReadFile Incorrect function.
file_pread(5,8,buffer,4175(0/66/18)) ReadFile Incorrect function.
file_pread(5,11,buffer,4222(0/67/2)) ReadFile Incorrect function.
file_pread(5,2,buffer,6144(0/97/34)) ReadFile Incorrect function.
file_pread(5,14,buffer,6146(0/97/36)) ReadFile Incorrect function.
file_pread(5,3,buffer,6160(0/97/50)) ReadFile Incorrect function.
file_pread(5,3,buffer,6207(0/98/34)) ReadFile Incorrect function.
file_pread(5,8,buffer,6223(0/98/50)) ReadFile Incorrect function.
JayZon
#4 Post by JayZon »
The crystaldiskinfo health status is good though..
CrystalDiskInfo 6.5.2 (C) 2008-2015 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate SP1 [6.1 Build 7601] (x64)
Date : 2015/11/21 3:18:26
-- Controller Map ----------------------------------------------------------
+ Intel(R) ICH9M-E/M SATA AHCI Controller [ATA]
- ATA Hitachi HTS54322 SCSI Disk Device
- Optiarc DVD RW AD-7580S SCSI CdRom Device
-- Disk List ---------------------------------------------------------------
(1) Hitachi HTS543225L9A300 : 250.0 GB [0/0/0, pd1]
(2) TOSHIBA MQ01ABD050 : 500.1 GB [1/X/X, sa1] (V=0480, P=A006)
Enclosure : TOSHIBA External USB 3.0 USB Device (V=0480, P=A006, sa1)
Model : TOSHIBA MQ01ABD050
Firmware : AXF01U
Serial Number : X2CIC5FQT
Disk Size : 500.1 GB (8.4/137.4/500.1/500.1)
Buffer Size : 8192 KB
Queue Depth : 32
# of Sectors : 976773168
Rotation Rate : 5400 RPM
Interface : USB (Serial ATA)
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : SATA/300 | SATA/300
Power On Hours : 1438 hours
Power On Count : 487 count
Temperature : 39 C (102 F)
Health Status : Good
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 0001h [ON]
AAM Level : ----
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 100 100 _50 000000000000 Read Error Rate
02 100 100 _50 000000000000 Throughput Performance
03 100 100 __1 000000000A6A Spin-Up Time
04 100 100 __0 0000000019C0 Start/Stop Count
05 100 100 _50 000000000000 Reallocated Sectors Count
07 100 100 _50 000000000000 Seek Error Rate
08 100 100 _50 000000000000 Seek Time Performance
09 _97 _97 __0 00000000059E Power-On Hours
0A 230 100 _30 000000000000 Spin Retry Count
0C 100 100 __0 0000000001E7 Power Cycle Count
BF 100 100 __0 000000000005 G-Sense Error Rate
C0 100 100 __0 0000000000E2 Power-off Retract Count
C1 100 100 __0 000000002564 Load/Unload Cycle Count
C2 100 100 __0 003300180027 Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 253 __0 000000000024 UltraDMA CRC Error Count
DC 100 100 __0 000000000000 Disk Shift
DE _99 _99 __0 000000000287 Loaded Hours
DF 100 100 __0 000000000000 Load/Unload Retry Count
E0 100 100 __0 000000000000 Load Friction
E2 100 100 __0 0000000000AB Load 'In'-time
F0 100 100 __1 000000000000 Head Flying Hours
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2058 3243 4943 3546 5154
020: 0000 4000 0000 4158 4630 3155 2020 544F 5348 4942
030: 4120 4D51 3031 4142 4430 3530 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4000 0200 0000 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0007 0407 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 0F06 0004 004C 0040
080: 01F8 0000 746B 7D09 6163 7469 BC09 6163 003F 0036
090: 0036 0001 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 6030 3A38 0000 0000 0000 0000 6003 0000 5000 0394
110: 53B8 2DC4 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0001 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 101F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0080 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 77A5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 0B 00 64 64 00 00 00 00 00 00 00 02 05
010: 00 64 64 00 00 00 00 00 00 00 03 27 00 64 64 6A
020: 0A 00 00 00 00 00 04 32 00 64 64 C0 19 00 00 00
030: 00 00 05 33 00 64 64 00 00 00 00 00 00 00 07 0B
040: 00 64 64 00 00 00 00 00 00 00 08 05 00 64 64 00
050: 00 00 00 00 00 00 09 32 00 61 61 9E 05 00 00 00
060: 00 00 0A 33 00 E6 64 00 00 00 00 00 00 00 0C 32
070: 00 64 64 E7 01 00 00 00 00 00 BF 32 00 64 64 05
080: 00 00 00 00 00 00 C0 32 00 64 64 E2 00 00 00 00
090: 00 00 C1 32 00 64 64 64 25 00 00 00 00 00 C2 22
0A0: 00 64 64 27 00 18 00 33 00 00 C4 32 00 64 64 00
0B0: 00 00 00 00 00 00 C5 32 00 64 64 00 00 00 00 00
0C0: 00 00 C6 30 00 64 64 00 00 00 00 00 00 00 C7 32
0D0: 00 C8 FD 24 00 00 00 00 00 00 DC 02 00 64 64 00
0E0: 00 00 00 00 00 00 DE 32 00 63 63 87 02 00 00 00
0F0: 00 00 DF 32 00 64 64 00 00 00 00 00 00 00 E0 22
100: 00 64 64 00 00 00 00 00 00 00 E2 26 00 64 64 AB
110: 00 00 00 00 00 00 F0 01 00 64 64 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 78 00 00 5B
170: 03 00 01 00 02 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 BE
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 32 00 00 00 00 00 00 00 00 00 00 02 32
010: 00 00 00 00 00 00 00 00 00 00 03 01 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 32 00 00 00 00 00 00 00 00 00 00 07 32
040: 00 00 00 00 00 00 00 00 00 00 08 32 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 1E 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 BF 00 00 00 00 00
080: 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00 00
090: 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C4 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 DC 00 00 00 00 00
0E0: 00 00 00 00 00 00 DE 00 00 00 00 00 00 00 00 00
0F0: 00 00 DF 00 00 00 00 00 00 00 00 00 00 00 E0 00
100: 00 00 00 00 00 00 00 00 00 00 E2 00 00 00 00 00
110: 00 00 00 00 00 00 F0 01 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 36
JayZon
#5 Post by JayZon »
Fiona wrote:Running testdisk / Adanced and Rebuid BS requires a correct partition in your partition table.
What should I do? I bought another 1Tb HD to recover files using photorec..Based on the testdisk log I gave,will I recover the data or it is totally gone??? Im running photorec now and will take a long time to read sectors again..
