I used Test Disk to copy files from a bad disk (RAW partition - external WD 1TB Elements). Is there a way to know if all the files were copied? During the copy process, Test disk was always reporting "0 failed", however judging by the size of copied files, a lot is missing. Disk is 1TB, it was almost full, the size of all the files that were copied is 750GB.
The Log does shows errors, for example:
file_pread(5,1,buffer,1450689712(90301/65/53)) ReadFile Data error (cyclic redundancy check).
ERROR: Couldn't read filefile_pread(5,16,buffer,6466306(402/129/50)) ReadFile Data error (cyclic redundancy check).
Here's the entire log, except folder and file names:
Mon Oct 26 15:52:58 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000202043392
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=2000365289472
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=26213935104
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=93817543680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000200994816
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2000364240896
Disk /dev/sda - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Disk /dev/sdc - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Drive C: - 26 GB / 24 GiB - CHS 3186 255 63, sector size=512
Drive D: - 93 GB / 87 GiB - CHS 11406 255 63, sector size=512
Drive F: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Drive G: - 2000 GB / 1862 GiB - CHS 243197 255 63, sector size=512
Analyse Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121600 255 63
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 121600 247 55 1953517568
pread: Input/output error
Failed to calculate number of free MFTs: Input/output error.
Error reading $Mft record(s): Input/output error.
NTFS at 0/32/33
filesystem size 1953517568
mftmirr_lcn 122094847
file_pread(5,8,buffer,1953519616(121600/247/56)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1953519616(121600/247/56)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,1953519617(121600/247/57)) lseek err Invalid argument
file_pread(5,14,buffer,1953519618(121600/247/58)) lseek err Invalid argument
file_pread(5,3,buffer,1953519632(121600/248/9)) lseek err Invalid argument
file_pread(5,3,buffer,1953519679(121600/248/56)) lseek err Invalid argument
file_pread(5,8,buffer,1953519695(121600/249/9)) lseek err Invalid argument
file_pread(5,11,buffer,1953519742(121600/249/56)) lseek err Invalid argument
file_pread(5,2,buffer,1953521664(121601/25/25)) lseek err Invalid argument
file_pread(5,16,buffer,1749533936(108903/114/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1749533944(108903/115/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1749533944(108903/115/5)) ReadFile Data error (cyclic redundancy check).
dir_partition inode=5
file_pread(5,16,buffer,6466308(402/129/52)) ReadFile Data error (cyclic redundancy check).
5 dr-xr-xr-x 0 0 0 27-May-2015 15:30 .
5 dr-xr-xr-x 0 0 0 27-May-2015 15:30 ..
172918 dr-xr-xr-x 0 0 0 15-Nov-2011 14:50 $RECYCLE.BIN
228217 dr-xr-xr-x 0 0 0 17-Apr-2012 22:36 29cab0db7943dcff4404
255497 dr-xr-xr-x 0 0 0 16-May-2012 23:21 863e48d432bc635f1bf0e78e98b2ba
57591 dr-xr-xr-x 0 0 0 8-Jun-2014 20:50
file_pread(5,16,buffer,6466314(402/129/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6466318(402/129/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1739328864(108268/54/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6464666(402/103/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6464666(402/103/48)) ReadFile Data error (cyclic redundancy check).
ntfs_readdir failed for cluster 255380: Input/output error
file_pread(5,16,buffer,6463500(402/85/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6463490(402/85/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6463492(402/85/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6463494(402/85/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6463496(402/85/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6463498(402/85/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6463502(402/85/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6466310(402/129/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,6466312(402/129/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1449873392(90250/113/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1450689712(90301/65/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1756677184(109348/24/53)) ReadFile Data error (cyclic redundancy check).
dir_partition inode=369488
