In over my head! Hitachi 500GB Deskstar
pilotwerrie
#1 Post by pilotwerrie »
Good day all!
I have a Hitachi Deskstar drive I haven't used in a while and now I need some files on it.
When I plugged it in Windows (7) gave the error message: E:\ is not accessible. The file or directory is corrupted or unreadable. And it then asks me if I want to format ... Which I don't!
I googled a bit and found this software and forum! Youtube Tutorials were not very helpful either ...
However I am a bit unsure on what exactly I should do - I just feel a little out of my depth on this level of hardware technicality! And I certainly don't want to damage my drive any further!
I believe my problem is with the partition tables being damaged? correct?
How can I fix this? I also get an error message in Testdisk about cylinder and heads mismatch?? I attached a photo of drive showing info relating to it.
I can use some advice please ... I also dont know why it is listed as a seagate drive??
Logfile:
Thu Oct 29 14:10:45 2015
TestDisk 7.0-WIP, Data Recovery Utility, March 2015
Compilation date: 2015-03-02T17:26:57
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=500106779648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500106779648
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=319965626368
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=500105249280
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - Hitachi HTS725032A9A364, S/N:3131333032304350334b34304b475a4835444b54, FW:PC3OCH0A
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Seagate Expansion Desk, S/N:2HC015KJ, FW:0319
Disk /dev/sdb - 500 GB / 465 GiB - Seagate Expansion Desk
Geometry from i386 MBR: head=16 sector=63
NTFS at 0/1/1
Warning: number of heads/cylinder mismatches 16 (NTFS) != 255 (HD)
1 * HPFS - NTFS 0 1 1 60801 0 63 976768065
$MFTMirr location mismatch or first 4 records are fragmented. Run chkdsk.
Failed to load $MFTMirr: Input/output error.
