I have a 2TB drive, formatted to ext4 which has begun to fail and taken the initial sectors of the drive with it (meaning I can't read any partition information for the first partition (ext4). I've run photoRec on it to try to recover my (cr2) raw photo files from a Canon 40D but all the files found are corrupted, while jpegs found are not.
All the files that are recovered appear to be somewhat corrupted. Corel AfterShot Pro loads them with bars on part of the each file and other software crashes on load (eg RawTherapee). All jpeg files that are recovered can be viewed without any problems and are not corrupted. I was using the 64-bit build of PhotoRec 6.13 (from Ubuntu 12.04's repositories), but have also tried the 32-bit build developer of 6.14.
I have read these two threads (1, 2), but they did not help.
I have most of the photos backed up on a separate drive (only a fraction are not backed up...) and I may be able to do comparisons between the original and recovered files if that will help.
Any help would be muchly appreciated
