Recovering RAW disk via TestDisk
eric78
#1 Post by eric78 »
Hi there
Not sure,but my 3TB Toshiba become RAW,Windows wants to run on this chkdsk which I don't want to do as I've lost in past several files with chkdsk which I've never recovered
Here is attached output from Testdisk 7.0,I'm using 32bit on 64bit Windows 7
What is best way to convert the RAW to NTFS as I don't want to loose files and don't want to format HDD etc
Please if you could let me know what is best way to convert to NTFS I would be very appreciated
Thanks
Re: Recovering RAW disk via TestDisk
Run TestDisk, Advanced, select the partition, Boot, RebuildBS, List. If you can see your files, choose Write, confirm, Quit, restart your computer. If needed, run "cmd" (right click "run as administrator") and "chkdsk /f d:" (replace d: by the correct drive letter)
eric78
#3 Post by eric78 »
Here is attached output from TestDisk
TestDisk
TestDisk
Testdisk res.jpg (235.28 KiB) Viewed 3116 times
Yes I've run TestDisk via Advanced,but didn't manage to RebuildBS as I've got BSOD :oops:
HDD is 3TB and took quite while to analyze HDD
Thanks
