Wrote the partition table thinking I'd fix it...
tomtailford
#1 Post by tomtailford »
UH OH...
I have a GRAID disk (EXFAT striped raid) which was showing up as RAW in windows and asked for a format. On the Mac the device showed, but the single partition didn't - and first aid didn't do anything.
Ran Testdisk and after analysing I could see the partition and all the files
I wrote the partition structure to disk and now I can't access the files (I thought this would fix it, but should have read the manual!)
Now I can't see the files as it says "support for this filesystem hasn't been implemented"
Also, it's saying the filesystem is Mac HFS, but pretty sure I set it up as EXFAT.
Hopefully I've not managed to destroy all my data :(
Re: Wrote the partition table thinking I'd fix it...
If you have the testdisk.log file where TestDisk recorded what you have done, please post it.
If TestDisk has managed to find your exfat partition once, it will find it again.
tomtailford
#3 Post by tomtailford »
Thanks again for your help!
I was using a mac at the time and there doesn't appear to be a testdisk.log file in the folder where I ran the application from. Any suggestions?
Thanks,
Tom
whitmell
#4 Post by whitmell »
If you get this resolved, please post here as I have done the same thing and haven't yet found a solution. If I fix mine I will post my solution here.
#5 Post by cgrenier »
Go in testdisk directory, sort the file by date/time, the log file is probably the most recent.
tomtailford
#6 Post by tomtailford »
Thu Nov 12 19:59:43 2015
OS: Darwin, kernel 14.3.0 (Darwin Kernel Version 14.3.0: Mon Mar 23 11:59:05 PDT 2015; root:xnu-2782.2
Compiler: GCC 4.0
Compilation date: 2015-04-18T13:01:34
Disk /dev/disk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/disk1 - 8001 GB / 7451 GiB - 15627911168 sectors, sector size=512
Disk /dev/rdisk0 - 251 GB / 233 GiB - 490234752 sectors (RO), sector size=512
Disk /dev/rdisk1 - 8001 GB / 7451 GiB - 15627911168 sectors, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/disk1 - 8001 GB / 7451 GiB - 15627911168 sectors
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=15627911167 (expected 15627911167)
hdr_lba_start=34
hdr_lba_end=15627911134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P EFI System                    40     409639     409600
 2 P Mac HFS                   409640 15627648983 15627239344
s
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
sect/track 32 (FAT) != 1 (HD)
FAT32 at 40/0/1
     EFI System                    40     409639     409600 [EFI]
part_size 2742337456
     HFS+ blocksize=8192 + Backup, 8001 GB / 7451 GiB
   P EFI System                    40     409639     409600 [EFI]
Support for this filesystem hasn't been implemented.
gpt_change_part_type
Change partition type:
     40     409639     409600
 2 P Unknown                   411648 2743007231 2742595584
Invalid partition structure.
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
interface_load
Disk /dev/disk1 - 8001 GB / 7451 GiB - 15627911168 sectors Thu Nov 12 19:31:44 2015
 1 P Unknown                       40     409639     409600
Disk /dev/disk1 - 8001 GB / 7451 GiB - 15627911168 sectors Thu Nov 12 19:47:46 2015
 2 P Unknow
FAT32 at 40/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 40/0/1
FAT32 at 46/0/1
FAT1 : 32-3182
FAT2 : 3183-6333
Data : 6334-409599
sectors : 409600
cluster_size : 1
FAT32 at 46/0/1
     EFI System                    46     409645     409600 [EFI]
NTFS at 264192/0/1
filesystem size           2048000
sectors_per_cluster       8
mft_lcn                   85333
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=135266304, part_size=1048576000, sector_size=512
NTFS at 264192/0/1
mft_lcn                   85333
mftmirr_lcn               2
     MS Data                   264192    2312191    2048000
     NTFS, blocksize=4096, 1048 MB / 1000 MiB
HFS+ magic value at 409642/0/1
     MS Data                   411648 15627909119 15627497472
     exFAT, blocksize=262144, 8001 GB / 7451 GiB
     MS Data                   411660 15627909131 15627497472
tomtailford
#7 Post by tomtailford »
Does this log help at all?
Just wondering if I have any chance of recovering my files?
Test disk did show me my files before I screwed it up somehow!
Thanks,
Tom
#8 Post by Fiona »
I'm not as much an Apple tech savvy.
But as far as I know, TestDisk can't list files of a HFS+-partition.
Currently you have a an HFS+-partition in your partition table.
Did you already search for your EXFAT-Partition again?
tomtailford
#9 Post by tomtailford »
Testdisk sees disk, I choose EFI GPT partition table type, Analyse, Quick Search:
Quick search result
Quick search result
Now conducting a deeper search... I have a feeling it didn't let me do this before?
tomtailford
#10 Post by tomtailford »
Fingers crossed it will find something...
