NTSF on external drive shown as "No partition"
ozshots
#1 Post by ozshots »
Hi All,
I have external WD Passort HDD with 3 paritions:
1 pretend to be CD drive with WD installation software
2 Nintendo Wii
3 NTFS partition
Drive E: - 700 MB / 668 MiB - CHS 167 64 32, sector size=2048 - pretend to be CD drive with WD installation software - works fine
Drive G: - 134 GB / 124 GiB - CHS 16308 255 63, sector size=512 - Nintendo WiiBrew partition - long unused - don't care
Drive P: - 365 GB / 340 GiB - CHS 44405 255 63, sector size=512 - NTFS partition I'm trying to recover
Something went wrong and drive P: with NTFS is not readable. On first run TestDisk reported damaged boot and I've replaced it with backup. Unfortunately this didnt help. TestDisk reports "Bad relative sector", "Space conflict between the following two partitions" and lots of "read err: read after end of file".
I'm now lost; Please help....
MBR Recovery attempt:
Tue Nov 17 18:02:17 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=700448768
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=134146059264
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\P:)=365250735104
Partition table type: None
NTFS at 44405/222/31
filesystem size 713380342
mftmirr_lcn 60962431
P NTFS 0 0 1 44405 222 31 713380342
NTFS found using backup sector, blocksize=4096, 365 GB / 340 GiB
NTFS Volume is dirty.
dir_partition inode=5
ntfs_readdir failed for cluster 5: Input/output error
5 dr-xr-xr-x 0 0 0 6-Nov-2015 21:20 .
5 dr-xr-xr-x 0 0 0 6-Nov-2015 21:20 ..
9534 dr-xr-xr-x 0 0 0 6-Nov-2015 17:35 Movies new
4740 dr-xr-xr-x 0 0 0 3-Apr-2012 04:10 RECYCLER
dir_partition inode=4740
Directory /RECYCLER
4740 dr-xr-xr-x 0 0 0 3-Apr-2012 04:10 .
9389 dr-xr-xr-x 0 0 0 31-Oct-2013 15:27 S-1-5-21-1659004503-1417001333-81469195-1003
9295 dr-xr-xr-x 0 0 0 19-May-2012 10:09 S-1-5-21-200950944-1112911032-3483883798-56432
4931 dr-xr-xr-x 0 0 0 29-Oct-2010 21:26 S-1-5-21-3410288154-681764103-101265881-1004
14940 dr-xr-xr-x 0 0 0 3-Apr-2012 04:10 S-1-5-21-796845957-1958367476-682003330-1003
4741 dr-xr-xr-x 0 0 0 8-Aug-2010 20:36 S-1-5-21-842925246-1303643608-839522115-1003
Directory /RECYCLER
dir_partition inode=9534
Directory /Movies new
9534 dr-xr-xr-x 0 0 0 6-Nov-2015 17:35 .
9750 dr-xr-xr-x 0 0 0 25-Jul-2013 23:01 Rus
107497 dr-xr-xr-x 0 0 0 3-Apr-2012 06:48 new2
9815 -r--r--r-- 0 0 1573281792 11-Oct-2010 04:14 Dobro.pozhalovat.v.Zombilend.2009.HDRip.Xvid.AC3.avi
9821 -r--r--r-- 0 0 2409 11-Oct-2010 00:29 Dobro.pozhalovat.v.Zombilend.2009.HDRip.Xvid.AC3.avi.2.srt
4372 -r--r--r-- 0 0 5632 8-Oct-2013 22:07 Thumbs.db
Directory /RECYCLER
ntfs_boot_sector
NTFS at 0/0/1
filesystem size 320881733296173847 713380342
sectors_per_cluster 124 8
mft_lcn 128910856 786432
mftmirr_lcn 2431677416 60962431
clusters_per_mft_record -112 -10
clusters_per_index_record -112 1
Status: Bad
Status: OK
Sectors are not identical.
copy backup boot sector over boot sector
ntfs_boot_sector
NTFS at 0/0/1
NTFS at 0/0/1
Status: OK
Status: OK
Sectors are identical.
Re: NTSF on external drive shown as "No partition"
There may be a bad sector (at least in cluster 5). You should clone the disk using gnu ddrescue to a new empty disk.
Here is an old tutorial: http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
ozshots
#3 Post by ozshots »
Wow! Christophe thank you so much for your reply and fantastic tool!!!
I've done a quick scan and there are errors... does that means disk is physically damaged?
Tue Nov 17 21:56:06 2015
Geometry from i386 MBR: head=116 sector=52
BAD_RS LBA=218129509 5918957
check_part_i386 1 type 72: no test
BAD_RS LBA=729050177 1083631
check_part_i386 2 type 74: no test
BAD_RS LBA=168653938 1838434
3 * NetWare 3.11+ 10498 56 41 10498 56 40 0
1 * Sys=72 13577 238 11 119521 238 60 1701990410
2 * Sys=74 45381 70 3 79242 34 29 543974724
Analyse Drive P: - 365 GB / 340 GiB - CHS 44405 255 63
Bad relative sector.
Change partition type:
No partition 0 0 1 44404 254 63 713366325
Partition table type (auto): Mac
Analyse Drive E: - 700 MB / 668 MiB - CHS 167 64 32
file_win32_pread(544,4,buffer,314880(153/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,314880(153/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,314884(153/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,314895(153/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,314899(153/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,314911(153/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,315392(154/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,315392(154/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,315396(154/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,315407(154/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,315411(154/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,315423(154/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,315904(154/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,315426(154/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,315428(154/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,315439(154/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,315443(154/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,315455(154/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,315936(154/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,315904(154/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,315908(154/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,315919(154/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,315923(154/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,315935(154/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,316416(154/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,316416(154/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,316420(154/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,316431(154/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,316435(154/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,316447(154/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,316928(154/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,316928(154/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,316932(154/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,316943(154/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,316947(154/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,316959(154/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,317440(155/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,317440(155/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,317444(155/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,317455(155/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,317459(155/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,317471(155/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,317952(155/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,317474(155/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,317476(155/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,317487(155/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,317491(155/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,317503(155/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,317984(155/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,317952(155/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,317956(155/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,317967(155/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,317971(155/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,317983(155/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,318464(155/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,318464(155/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,318468(155/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,318479(155/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,318483(155/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,318495(155/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,318976(155/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,318976(155/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,318980(155/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,318991(155/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,318995(155/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,319007(155/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,319488(156/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,319488(156/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,319492(156/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,319503(156/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,319507(156/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,319519(156/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,320000(156/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,319522(156/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,319524(156/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,319535(156/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,319539(156/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,319551(156/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,320032(156/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,320000(156/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,320004(156/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,320015(156/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,320019(156/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,320031(156/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,320512(156/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,320512(156/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,320516(156/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,320527(156/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,320531(156/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,320543(156/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,321024(156/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,321024(156/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,321028(156/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,321039(156/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,321043(156/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,321055(156/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,321536(157/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,321536(157/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,321540(157/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,321551(157/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,321555(157/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,321567(157/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,322048(157/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,321570(157/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,321572(157/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,321583(157/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,321587(157/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,321599(157/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,322080(157/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,322048(157/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,322052(157/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,322063(157/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,322067(157/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,322079(157/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,322560(157/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,322560(157/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,322564(157/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,322575(157/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,322579(157/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,322591(157/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,323072(157/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,323072(157/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,323076(157/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,323087(157/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,323091(157/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,323103(157/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,323584(158/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,323584(158/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,323588(158/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,323599(158/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,323603(158/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,323615(158/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,324096(158/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,323618(158/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,323620(158/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,323631(158/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,323635(158/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,323647(158/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,324128(158/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,324096(158/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,324100(158/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,324111(158/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,324115(158/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,324127(158/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,324608(158/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,324608(158/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,324612(158/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,324623(158/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,324627(158/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,324639(158/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,325120(158/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,325120(158/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,325124(158/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,325135(158/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,325139(158/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,325151(158/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,325632(159/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,325632(159/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,325636(159/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,325647(159/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,325651(159/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,325663(159/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,326144(159/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,325666(159/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,325668(159/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,325679(159/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,325683(159/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,325695(159/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,326176(159/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,326144(159/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,326148(159/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,326159(159/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,326163(159/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,326175(159/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,326656(159/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,326656(159/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,326660(159/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,326671(159/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,326675(159/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,326687(159/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,327168(159/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,327168(159/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,327172(159/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,327183(159/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,327187(159/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,327199(159/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,327680(160/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,327680(160/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,327684(160/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,327695(160/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,327699(160/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,327711(160/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,328192(160/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,327714(160/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,327716(160/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,327727(160/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,327731(160/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,327743(160/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,328224(160/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,328192(160/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,328196(160/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,328207(160/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,328211(160/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,328223(160/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,328704(160/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,328704(160/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,328708(160/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,328719(160/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,328723(160/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,328735(160/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,329216(160/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,329216(160/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,329220(160/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,329231(160/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,329235(160/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,329247(160/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,329728(161/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,329728(161/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,329732(161/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,329743(161/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,329747(161/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,329759(161/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,330240(161/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,329762(161/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,329764(161/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,329775(161/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,329779(161/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,329791(161/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,330272(161/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,330240(161/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,330244(161/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,330255(161/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,330259(161/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,330271(161/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,330752(161/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,330752(161/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,330756(161/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,330767(161/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,330771(161/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,330783(161/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,331264(161/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,331264(161/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,331268(161/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,331279(161/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,331283(161/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,331295(161/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,331776(162/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,331776(162/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,331780(162/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,331791(162/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,331795(162/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,331807(162/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,332288(162/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,331810(162/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,331812(162/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,331823(162/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,331827(162/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,331839(162/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,332320(162/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,332288(162/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,332292(162/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,332303(162/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,332307(162/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,332319(162/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,332800(162/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,332800(162/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,332804(162/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,332815(162/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,332819(162/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,332831(162/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,333312(162/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,333312(162/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,333316(162/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,333327(162/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,333331(162/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,333343(162/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,333824(163/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,333824(163/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,333828(163/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,333839(163/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,333843(163/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,333855(163/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,334336(163/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,333858(163/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,333860(163/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,333871(163/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,333875(163/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,333887(163/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,334368(163/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,334336(163/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,334340(163/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,334351(163/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,334355(163/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,334367(163/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,334848(163/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,334848(163/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,334852(163/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,334863(163/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,334867(163/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,334879(163/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,335360(163/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,335360(163/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,335364(163/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,335375(163/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,335379(163/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,335391(163/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,335872(164/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,335872(164/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,335876(164/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,335887(164/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,335891(164/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,335903(164/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,336384(164/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,335906(164/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,335908(164/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,335919(164/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,335923(164/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,335935(164/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,336416(164/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,336384(164/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,336388(164/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,336399(164/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,336403(164/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,336415(164/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,336896(164/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,336896(164/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,336900(164/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,336911(164/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,336915(164/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,336927(164/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,337408(164/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,337408(164/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,337412(164/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,337423(164/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,337427(164/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,337439(164/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,337920(165/0/1)) read err: read after end of file
file_win32_pread(544,4,buffer,337920(165/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,337924(165/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,337935(165/0/16)) read err: read after end of file
file_win32_pread(544,3,buffer,337939(165/0/20)) read err: read after end of file
file_win32_pread(544,4,buffer,337951(165/0/32)) read err: read after end of file
file_win32_pread(544,1,buffer,338432(165/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,337954(165/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,337956(165/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,337967(165/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,337971(165/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,337983(165/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,338464(165/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,338432(165/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,338436(165/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,338447(165/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,338451(165/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,338463(165/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,338944(165/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,338944(165/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,338948(165/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,338959(165/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,338963(165/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,338975(165/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,339456(165/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,339456(165/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,339460(165/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,339471(165/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,339475(165/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,339487(165/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,339968(166/0/1)) read err: read after end of file
file_win32_pread(544,1,buffer,339967(165/63/32)) read err: read after end of file
file_win32_pread(544,4,buffer,339967(165/63/32)) read err: read after end of file
file_win32_pread(544,1,buffer,339971(166/0/4)) read err: read after end of file
file_win32_pread(544,2,buffer,339982(166/0/15)) read err: read after end of file
file_win32_pread(544,3,buffer,339986(166/0/19)) read err: read after end of file
file_win32_pread(544,4,buffer,339998(166/0/31)) read err: read after end of file
file_win32_pread(544,1,buffer,340479(166/15/32)) read err: read after end of file
file_win32_pread(544,1,buffer,339972(166/0/5)) read err: read after end of file
file_win32_pread(544,2,buffer,339983(166/0/16)) read err: read after end of file
file_win32_pread(544,2,buffer,339988(166/0/21)) read err: read after end of file
file_win32_pread(544,2,buffer,340001(166/1/2)) read err: read after end of file
file_win32_pread(544,1,buffer,340480(166/16/1)) read err: read after end of file
file_win32_pread(544,2,buffer,340002(166/1/3)) read err: read after end of file
file_win32_pread(544,1,buffer,340004(166/1/5)) read err: read after end of file
file_win32_pread(544,2,buffer,340015(166/1/16)) read err: read after end of file
file_win32_pread(544,3,buffer,340019(166/1/20)) read err: read after end of file
file_win32_pread(544,4,buffer,340031(166/1/32)) read err: read after end of file
file_win32_pread(544,1,buffer,340512(166/17/1)) read err: read after end of file
file_win32_pread(544,4,buffer,340480(166/16/1)) read err: read after end of file
file_win32_pread(544,1,buffer,340484(166/16/5)) read err: read after end of file
file_win32_pread(544,2,buffer,340495(166/16/16)) read err: read after end of file
file_win32_pread(544,3,buffer,340499(166/16/20)) read err: read after end of file
file_win32_pread(544,4,buffer,340511(166/16/32)) read err: read after end of file
file_win32_pread(544,1,buffer,340992(166/32/1)) read err: read after end of file
file_win32_pread(544,4,buffer,340992(166/32/1)) read err: read after end of file
file_win32_pread(544,1,buffer,340996(166/32/5)) read err: read after end of file
file_win32_pread(544,2,buffer,341007(166/32/16)) read err: read after end of file
file_win32_pread(544,3,buffer,341011(166/32/20)) read err: read after end of file
file_win32_pread(544,4,buffer,341023(166/32/32)) read err: read after end of file
file_win32_pread(544,1,buffer,341504(166/48/1)) read err: read after end of file
file_win32_pread(544,4,buffer,341504(166/48/1)) read err: read after end of file
file_win32_pread(544,1,buffer,341508(166/48/5)) read err: read after end of file
file_win32_pread(544,2,buffer,341519(166/48/16)) read err: read after end of file
file_win32_pread(544,3,buffer,341523(166/48/20)) read err: read after end of file
file_win32_pread(544,4,buffer,341535(166/48/32)) read err: read after end of file
file_win32_pread(544,1,buffer,342015(166/63/32)) read err: read after end of file
file_win32_pread(544,4,buffer,342015(166/63/32)) read err: read after end of file
Store new MBR code
