2TB external: partition found, MFT match, can't list files.
Maxell
#1 Post by Maxell »
I have a 2TB external HDD, use it to store various content on a single partition. Yesterday while starting a torrent I got a popup saying "The file or directory L:\$Mft is corrupt and unreadable. Please run the Chkdsk utility." I tried accessing a random file on the disk but couldn't. Torrents were still seeding from this drive. I stopped the torrent client, unmounted the disk and shut it off. Then I turned it back on and once Windows mounted it, I had a notification saying I should format if I want to use the drive.
I ran TestDisk, checked the MFT and got "MFT and MFT mirror matches perfectly". Then I ran it again to find the partition. It analyzed and recognized my partition, with the right label and all. However, when I tried to list the files on the partition, all I got was a "Can't open filesystem. Filesystem seems damaged."
Then, just to test whether the files were still there, I ran PhotoRec, which started recovering files straight away. But this is a last resort, as it doesn't recover file structure, names and dates.
Now, I know I should probably make a sector-by-sector image copy of the entire disc, but unfortunately I don't have another such big (or bigger disk) to play around with, I would have to go and literally buy one, which I don't find too tempting right now.
What should I do now? Help would be much appreciated.
P.S. Attaching a log, hope it's of any help :)
Wed Nov 18 14:19:36 2015
OS: Windows 7 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=640130801152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=2000394706432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=640130801152
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000394706432
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=32210164224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=607920572928
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000392552448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=8537767936
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=7553908736
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=2000398901760
Disk /dev/sda - 640 GB / 596 GiB - CHS 77824 255 63, sector size=512
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 258400 240 63, sector size=512
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive C: - 32 GB / 29 GiB - CHS 3915 255 63, sector size=512
Drive D: - 607 GB / 566 GiB - CHS 73908 255 63, sector size=512
Drive E: - 2000 GB / 1863 GiB - CHS 258400 240 63, sector size=512
Drive F: - 8537 MB / 8142 MiB - CHS 2035 64 32, sector size=2048
Drive G: - 7553 MB / 7203 MiB - CHS 1800 64 32, sector size=2048
Drive L: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
NTFS at 0/1/1
sect/track 32 (NTFS) != 63 (HD)
Warning: number of sectors per track mismatches 32 (NTFS) != 63 (HD)
 1 P HPFS - NTFS              0   1  1 243201  80 63 3907029105 [EXTERNAL]
Failed to load the complete runlist for $MFT/$DATA. Bug or corrupt $MFT. Run chkdsk.
 highest_vcn = 0xec7ff, last_vcn - 1 = 0xec1ff
ntfs_mft_load(): Failed.
NTFS at 0/1/1
filesystem size           3907029105
sectors_per_cluster       1
mft_lcn                   679391488
mftmirr_lcn               679522593
clusters_per_mft_record   2
clusters_per_index_record 8
     NTFS, blocksize=512, 2000 GB / 1863 GiB
file_pread(6,16,buffer,3907029168(243201/81/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,1,buffer,3907029168(243201/81/1)) ReadFile Data error (cyclic redundancy check).
file_pread(6,8,buffer,3907029176(243201/81/9)) lseek err Invalid argument
file_pread(6,3,buffer,3907029184(243201/81/17)) lseek err Invalid argument
file_pread(6,3,buffer,3907029231(243201/82/1)) lseek err Invalid argument
file_pread(6,8,buffer,3907029247(243201/82/17)) lseek err Invalid argument
file_pread(6,11,buffer,3907029294(243201/83/1)) lseek err Invalid argument
file_pread(6,2,buffer,3907031216(243201/113/33)) lseek err Invalid argument
Warning: the current number of heads per cylinder is 255 but the correct value may be 16.
   * HPFS - NTFS              0   1  1 243201 254 63 3907040067 [EXTERNAL]
Not an exFAT boot sector.
 1 * HPFS - NTFS              0   1  1 243201 254 63 3907040067 [EXTERNAL]
NTFS at 0/1/1
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mft_lcn                   679391488
Status: OK
Status: OK
Sectors are identical.
repair_MFT
NTFS at 0/1/1
MFT and MFT mirror matches perfectly.
ntfs_boot_sector
NTFS at 0/1/1
NTFS at 0/1/1
mft_lcn                   679391488
Status: OK
Status: OK
Re: 2TB external: partition found, MFT match, can't list fil
I confirm, you should do a sector by sector copy of your disk due to the bad sectors.
Maxell
#3 Post by Maxell »
Naturally, but do you think I can restore the original file system, the structure, names, dates, etc. relatively easy and fast?
