Data recovery from transcend 320GB (storejet 24 mobile).
Ironmaniac
#1 Post by Ironmaniac »
Hello Forum
I have an external HDD, with two partitions. The problem is I can not access the data. But the data is important. Please advise how to use testdisk on linux to retrieve the data.
Re: Data recovery from transcend 320GB (storejet 24 mobile).
Pleas epost the testdisk.log file content
Ironmaniac
#3 Post by Ironmaniac »
cgrenier wrote:Pleas epost the testdisk.log file content
Sat Nov 21 18:02:45 2015
OS: Linux, kernel 3.13.0-67-generic (#110~precise1-Ubuntu SMP Mon Oct 26 11:56:17 UTC 2015) i686
Compiler: GCC 4.6
Compilation date: 2012-02-05T07:16:54
ext2fs lib: 1.42, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size 312581808 sectors
/dev/sda: user_max 312581808 sectors
/dev/sda: native_max 312581808 sectors
/dev/sda: dco 312581808 sectors
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - Hitachi HTS541616J9SA00, S/N:SB244CHJJAS12D, FW:SB4OC70P
Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - StoreJet Transcend
Disk /dev/sdc - 320 GB / 298 GiB - StoreJet Transcend
Analyse Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63
NTFS at 0/1/1
file_pread(5,4096,buffer,6291519(391/160/25)) read err: Partial read
file_pread(5,1,buffer,6292968(391/183/25)) read err: Input/output error
NTFS: Can't read MFT
NTFS at 19122/0/1
file_pread(5,4096,buffer,313486386(19513/159/25)) read err: Input/output error
file_pread(5,1,buffer,313486386(19513/159/25)) read err: Input/output error
1 P HPFS - NTFS 0 1 1 19121 254 63 307194867
2 P HPFS - NTFS 19122 0 1 38912 254 63 317942415
There are bad sectors. You should clone the disk to a new empty one using gnu ddrescue.
An old tutorial can be found at http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
Once it's done, remove the original disk and try to recover your data from the clone.
Ironmaniac
#5 Post by Ironmaniac »
Mr Grenier
Thank you for your insight.
I am not experienced in using command line linux.
The situation is like
Disk /dev/sda - 160 GB / 149 GiB - Hitachi HTS541616J9SA00
Disk /dev/sdb - 1000 GB / 931 GiB - WD My Passport 0820
The Storejet Transcend 320GB has bad sectors, which is needed to be cloned into WD Passport.
Now moving to http://www.cgsecurity.org/wiki/Damaged_ ... _rescue.27 and looking into the instructions to use dd rescue,
# download ddrescue
wget http://download.savannah.gnu.org/releas ... .8.tar.bz2
# extract the source code
tar xjf ddrescue-1.8.tar.bz2
# compile ddrescue
cd ddrescue-1.8
./configure && make
# first, grab most of the error-free areas in a hurry:
./ddrescue -n /dev/old_disk /dev/new_disk rescued.log
# then try to recover as much of the dicy areas as possible:
./ddrescue -r 1 /dev/old_disk /dev/new_disk rescued.log
I could understand and reach the end of the green part of the commands. But not the red part. Please guide me mentioning how to type the commands with the Transcend storejet being cloned into the WD My Passport.
Thank you
