Looks like that your partition table ist still intact?
http://s15.postimg.org/d0ggre397/Screen ... _39_05.png
At the left side, you can watch which partition is P (primary), * as active and L are your logical partitions.
After Quick and Deeper Search, there is no reason to set an extended partition, because if you have logical partitions, testdisk will recognize it and sets the extended partition at the write display automatically.
Unfortunately after Quick Search, the status of your partitions, are they're primary, active and logical, is not displayed.
Might be possible that you've to select it and set the status using the right or left arrow key on your keyboard.
You can watch it at the left side.
When no partition is set for recovery, at the Write menu you you can get such message:
http://s11.postimg.org/enogrjnkj/Screen ... _41_22.png
After running Deep Search, all partitions appear as deleted:
http://s11.postimg.org/s6zdkh74z/Screen ... _45_42.png
You should select each partition and press p to have a try to list your files.
You must set it as * (Star is primary and active) bootable, P for primary and L for logical.
An example is your current partition structure here:
In your case, your second partition is bootable!
It's important otherwise your computer won't boot.
In TestDisk it's important to write all required partitions into the partition table.
If any required partition is not set for recovery or forgotten, it will be missing after recovery.
Always, the complete number of partitions must be written into the partition table.
Currently it looks like that you already have all partitions in your partition table?
To "Write" your partitions, would only make sense, when TestDisk found your affected partition with all data on it.
After Deeper Search, you should select each partition and press p to have a try to list your files.
Otherwise there is no necessity to write your partition table again.
Somehow your affected partition after Quick- and Deeper Search appears than an ext4-partition but it's empty.
The end and the size of your partition after Quick- and Deeper Search differ slightly from your partition in your partition table-
You can watch the values here:
15553...83...19...38913...
70...5
http://s30.postimg.org/jrz7n7bsx/Screen ... _40_58.png
It's the result after Quick and Deeper Search.
The current partition in your partition table (current partition structure) is:
66..33
Datarecovery software would be a safe solution.
If you'd like to keep file names and folder you can try commercial datarecovery software.
Otherwise you can run TestDisk / Advanced (select your affected partition) and Superblock to have a try to repair your file system using fsck.
Procedure is explained here:
http://www.cgsecurity.org/wiki/Advanced ... SuperBlock
I'm not as much a Linux tech savvy but I've seen that it works on ext4-partitions too!
Red listed files are deleted ones.
You can hide them by pressing h for hide.
Pressing h again, they will reappear.
Should only be used if you accidentally deleted any files and you'd like to recover them.
Info here:
http://www.cgsecurity.org/wiki/TestDisk ... e_for_ext2
