My mobo recently died and I replaced it. I have a primary hdd (2TB Hitachi) running my OS, windows 10 (upgraded from 8.1 in September) and a secondary drive (1TB WD Black) that contains family videos.
Following the move the primary drive is operational but the secondary data drive became inaccessible. It was showing as RAW in virtual disk manager which led me to you.
Initial Testdisk runs showed the disk as RAW. I got to "Analyze" and I waited over a day and stopped the function. I began again and now the drive is showing as NFTS. What to do now?
Below is the latest log
________________________________________
Wed Nov 25 09:39:12 2015
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1983317540864
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1000201757184
Disk /dev/sda - 1000 GB / 931 GiB - CHS 129201 240 63, sector size=512
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Drive C: - 1983 GB / 1847 GiB - CHS 241124 255 63, sector size=512
Drive F: - 1000 GB / 931 GiB - CHS 129200 240 63, sector size=512
Analyse Disk /dev/sda - 1000 GB / 931 GiB - CHS 129201 240 63
Geometry from i386 MBR: head=240 sector=63
NTFS at 0/1/1
 1 P HPFS - NTFS              0   1  1 129200 239 63 1953519057
__________________________________________________________
						New Motherboard Issue
Re: New Motherboard Issue
UPDATE
In Windows I get a "Drive not accessible. The parameter is incorrect." Error.
I am able to see all the files in testdisk. I am presently copying the files to another drive. Will advise. Any insight in the meantime is appreciated.
Best,
C
Best,
C
Can you copy and paste the content of your testdisk.log?
You'll find it within your testdisk folder.
I assume that your file system is damaged.
After copying files, you can consider to run chkdsk driveletter: /r (it already implies /f) to have a try to repair your file system.
When you have any read errors, please let me know!
The italicized text above in the original post is the most current version of the testdisk log.
The disk contained about 900GB of files, how long to you expect the copy action to take?
Best,
C
Best,
C
Copying should take only few hours.
I assume at a max 3-4 hours?
A damaged file system can slow down scan speed.
Copying large files is faster than a huge amount of small files.
The copy took almost a week, but it is done. What is the best course to diagnose and repair the drive?
Ran CHKDSK and drive is operational now. There were several bad sectors.Took 8 days to get through the drive but scan completed and drive now shows in explorer.
Ran Crystaldiskinfo. Drive in question shows "caution". Report below. Any advice on a 4 year old drive (other than replace it!)?
CrystalDiskInfo 6.5.2 Shizuku Edition x64 (C) 2008-2015 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 10 Professional [10.0 Build 10240] (x64)
Date : 2015/12/07 21:23:51
-- Controller Map ----------------------------------------------------------
+ Intel(R) 9 Series Chipset Family SATA AHCI Controller [ATA]
- WDC WD1002FAEX-00Z3A0
- Hitachi HDS723020BLA642
- hp BDDVDRW CH30L
- Microsoft Storage Spaces Controller [SCSI]
-- Disk List ---------------------------------------------------------------
(1) WDC WD1002FAEX-00Z3A0 : 1000.2 GB [0/0/0, pd1] - wd
(2) Hitachi HDS723020BLA642 : 2000.3 GB [1/0/0, pd1]
Model : WDC WD1002FAEX-00Z3A0
Firmware : 05.01D05
Serial Number : ***************
Disk Size : 1000.2 GB (8.4/137.4/1000.2/1000.2)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : Unknown
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ----
Transfer Mode : ---- | SATA/600
Power On Hours : 38622 hours
Power On Count : 395 count
Temperature : 35 C (95 F)
Health Status : Caution
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : 80FEh [OFF]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 183 183 _51 0000000092E5 Read Error Rate
03 169 167 _21 0000000011C6 Spin-Up Time
04 100 100 __0 0000000003BF Start/Stop Count
05 199 199 140 000000000002 Reallocated Sectors Count
07 200 199 __0 000000000000 Seek Error Rate
09 _48 _48 __0 0000000096DE Power-On Hours
0A 100 100 __0 000000000000 Spin Retry Count
0B 100 100 __0 000000000000 Recalibration Retries
0C 100 100 __0 00000000018B Power Cycle Count
C0 200 200 __0 000000000073 Power-off Retract Count
C1 200 200 __0 00000000034B Load/Unload Cycle Count
C2 112 _85 __0 000000000023 Temperature
C4 198 198 __0 000000000002 Reallocation Event Count
C5 200 200 __0 00000000001C Current Pending Sector Count
C6 200 200 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
C8 200 183 __0 00000000000F Write Error Rate
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 427A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 3838
020: 0000 0000 0032 3035 2E30 3144 3035 5744 4320 5744
030: 3130 3032 4641 4558 2D30 305A 3341 3020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4001 0000 0000 0007 3FFF 0010 003F FC10 00FB 0110
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 170E 0000 0044 0044
080: 01FE 0000 746B 7F61 4123 7469 BC41 4123 407F 005A
090: 005A 0000 FFFE 0000 80FE 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 0000 0000 5001 4EE2
110: 051C 5FE2 0000 0000 0000 0000 0000 0000 0000 4018
120: 4018 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 16E2 0000 0000 0000 0000 0000 0000
140: 0000 0000 0004 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 3037 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 101E 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 1000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 63A5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 10 00 01 2F 00 B7 B7 E5 92 00 00 00 00 00 03 27
010: 00 A9 A7 C6 11 00 00 00 00 00 04 32 00 64 64 BF
020: 03 00 00 00 00 00 05 33 00 C7 C7 02 00 00 00 00
030: 00 00 07 2E 00 C8 C7 00 00 00 00 00 00 00 09 32
040: 00 30 30 DE 96 00 00 00 00 00 0A 32 00 64 64 00
050: 00 00 00 00 00 00 0B 32 00 64 64 00 00 00 00 00
060: 00 00 0C 32 00 64 64 8B 01 00 00 00 00 00 C0 32
070: 00 C8 C8 73 00 00 00 00 00 00 C1 32 00 C8 C8 4B
080: 03 00 00 00 00 00 C2 22 00 70 55 23 00 00 00 00
090: 00 00 C4 32 00 C6 C6 02 00 00 00 00 00 00 C5 32
0A0: 00 C8 C8 1C 00 00 00 00 00 00 C6 30 00 C8 C8 00
0B0: 00 00 00 00 00 00 C7 32 00 C8 C8 00 00 00 00 00
0C0: 00 00 C8 08 00 C8 B7 0F 00 00 00 00 00 00 00 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 84 00 24 45 01 7B
170: 03 00 01 00 02 CC 05 00 00 00 00 00 00 00 00 00
180: 00 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 10 00 01 33 C0 C8 B7 C5 00 00 00 00 00 00 03 15
010: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
020: 00 00 00 00 00 00 05 8C 00 00 00 00 00 00 00 00
030: 00 00 07 00 C8 C8 C8 C8 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 00 00 00 00 00
050: 00 00 00 00 00 00 0B 00 00 00 00 00 00 00 00 00
060: 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 C0 00
070: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
080: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
090: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
0A0: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
0B0: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
0C0: 00 00 C8 00 C8 C8 C8 C8 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 79
Model : Hitachi HDS723020BLA642
Firmware : MN6OA5Q0
Disk Size : 2000.3 GB (8.4/137.4/2000.3/2000.3)
Queue Depth : 32
# of Sectors : 3907029168
Rotation Rate : 7200 RPM
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 7244 hours
Power On Count : 625 count
Temperature : 32 C (89 F)
Health Status : Good
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : 0080h [ON]
AAM Level : ----
01 100 _95 _16 000000000000 Read Error Rate
02 134 100 _54 000000000057 Throughput Performance
03 140 100 _24 00060193019F Spin-Up Time
04 100 100 __0 0000000002F4 Start/Stop Count
05 100 100 __5 000000000000 Reallocated Sectors Count
07 100 100 _67 000000000000 Seek Error Rate
08 135 100 _20 00000000001A Seek Time Performance
09 _99 _99 __0 000000001C4C Power-On Hours
0A 100 100 _60 000000000000 Spin Retry Count
0C 100 100 __0 000000000271 Power Cycle Count
B7 100 100 __0 000000000000 Vendor Specific
B8 100 100 _97 000000000000 End-to-End Error
B9 100 100 __0 00000000FFFF Vendor Specific
BB 100 100 __0 000000000000 Reported Uncorrectable Errors
BC 100 _97 __0 000000380011 Command Timeout
BD 100 100 __0 000000000000 High Fly Writes
BE _68 _52 __0 000017210020 Airflow Temperature
C0 100 100 __0 000000000315 Power-off Retract Count
C1 100 100 __0 000000000315 Load/Unload Cycle Count
C2 187 127 __0 003000100020 Temperature
C4 100 100 __0 000000000000 Reallocation Event Count
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 198 __0 000000000020 UltraDMA CRC Error Count
0 1 2 3 4 5 6 7 8 9
000: 045A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 3744
020: 0003 0000 0004 4D4E 364F 4135 5130 4869 7461 6368
030: 6920 4844 5337 3233 3032 3042 4C41 3634 3220 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 4000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0110
070: 0000 0000 0000 0000 0000 001F 050E 0006 004C 004C
080: 01FC 0029 706B 7C09 4123 7069 BC09 4123 407F 00CC
090: 00CD 0080 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 88B0 E8E0 0000 0000 0000 0000 4000 5A87 5000 CCA3
110: 69E4 F8D6 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 000B
130: 0000 0000 2182 0CF1 3A20 0001 4000 2804 0033 0000
140: 0000 0505 0506 0305 0604 0306 0603 0000 0000 0000
150: 0000 0006 3648 4235 0000 0806 0000 5DBD FFFF 8000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0002 0000
200: 0000 0000 0000 0000 0000 0000 003D 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 103F 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0080 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 AEA5
000: 10 00 01 2F 00 64 5F 00 00 00 00 00 00 00 02 27
010: 00 86 64 57 00 00 00 00 00 00 03 23 00 8C 64 9F
020: 01 93 01 06 00 00 04 32 00 64 64 F4 02 00 00 00
030: 00 00 05 33 00 64 64 00 00 00 00 00 00 00 07 2F
040: 00 64 64 00 00 00 00 00 00 00 08 25 00 87 64 1A
050: 00 00 00 00 00 00 09 32 00 63 63 4C 1C 00 00 00
060: 00 00 0A 33 00 64 64 00 00 00 00 00 00 00 0C 32
070: 00 64 64 71 02 00 00 00 00 00 B7 32 00 64 64 00
080: 00 00 00 00 00 00 B8 33 00 64 64 00 00 00 00 00
090: 00 00 B9 32 00 64 64 FF FF 00 00 00 00 00 BB 32
0A0: 00 64 64 00 00 00 00 00 00 00 BC 32 00 64 61 11
0B0: 00 38 00 00 00 00 BD 3A 00 64 64 00 00 00 00 00
0C0: 00 00 BE 22 00 44 34 20 00 21 17 00 00 00 C0 32
0D0: 00 64 64 15 03 00 00 00 00 00 C1 32 00 64 64 15
0E0: 03 00 00 00 00 00 C2 22 00 BB 7F 20 00 10 00 30
0F0: 00 00 C4 32 00 64 64 00 00 00 00 00 00 00 C5 32
100: 00 64 64 00 00 00 00 00 00 00 C6 30 00 64 64 00
110: 00 00 00 00 00 00 C7 36 00 C8 C6 20 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 84 00 3E 47 01 5B
170: 03 00 01 00 02 FF 00 30 01 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 5F
000: 10 00 01 10 00 00 00 00 00 00 00 00 00 00 02 36
010: 00 00 00 00 00 00 00 00 00 00 03 18 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 05 00 00 00 00 00 00 00 00 00 00 07 43
040: 00 00 00 00 00 00 00 00 00 00 08 14 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 3C 00 00 00 00 00 00 00 00 00 00 0C 00
070: 00 00 00 00 00 00 00 00 00 00 B7 00 00 00 00 00
080: 00 00 00 00 00 00 B8 61 00 00 00 00 00 00 00 00
090: 00 00 B9 00 00 00 00 00 00 00 00 00 00 00 BB 00
0A0: 00 00 00 00 00 00 00 00 00 00 BC 00 00 00 00 00
0B0: 00 00 00 00 00 00 BD 00 00 00 00 00 00 00 00 00
0C0: 00 00 BE 00 00 00 00 00 00 00 00 00 00 00 C0 00
0D0: 00 00 00 00 00 00 00 00 00 00 C1 00 00 00 00 00
0E0: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
0F0: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C5 00
100: 00 00 00 00 00 00 00 00 00 00 C6 00 00 00 00 00
110: 00 00 00 00 00 00 C7 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 E9
- hp BDDVDRW CH30L
Firmware : 05.01D05
Queue Depth : 32
APM Level : ----
0 1 2 3 4 5 6 7 8 9
Firmware : MN6OA5Q0
Queue Depth : 32
AAM Level : ----
0 1 2 3 4 5 6 7 8 9
You can run the diagnose utility from your disk manufacturer and have a try to low level format your disk.
Data should be recovered and you should have a backup too.
It's not a real low level format but all sectors will be overriden by zeros.
Afterwards you can check your disk again!
So it might be possible that the status of your disk appears as OK again?
If not:
In case a scan with hdtune free and an error scan can help too.
If you see any red blocks, disk should be replaced.
Caution always mean that you should keep an eye on your disk.
You can use the windows eventviewer and under system look for entries like disk.
Most important will be always backup!
It's a kind of sitting on a fence and is your disk still reliable or not?
If not:
