Recover 2 partition from RAID 0
Pepinen
#1 Post by Pepinen »
Hello i think cloud be anyone can help me. i Have 2 Raids 2x3.5 sata 2TB raid 0 and 2x3.5 3TB Raid 0.
Mi mobo have a problem and they reset the fractory defaults, the 3 of 4 hard disk says non raid disk.
I have this problem before and then erease the raid or raids create the same raids and execute testdisk, they do a quick scan and detect de partition, write the partition and reboot.
The both raids recover all data.
Now y have the same problem but the testdisk not recononice the gpt partition, on 6TB raid says that que hard drive is small because they detect a partiton with more capacity.
¿anyone can help me please?, i need to recover one of 2 rais because 4TB raid is a backup from 6TB raids and both have problems with testdisk.
i tried to use a getdataback or reclaime fire recovery. Both detect the data but only recover corrupts files.
Here is the log from 6TB raid:
Sun Nov 29 22:05:49 2015
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=6001180803072
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=4000792444928
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255533776896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=2000388458496
filewin32_getfilesize(\\.\G:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\G:) SetFilePointer err Función incorrecta.
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 6001 GB / 5589 GiB - CHS 729602 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 4000 GB / 3726 GiB - CHS 486401 255 63, sector size=512
Drive C: - 255 GB / 237 GiB - CHS 31066 255 63, sector size=512
Drive D: - 2000 GB / 1863 GiB - CHS 243200 255 63, sector size=512
Partition table type: EFI GPT
Analyse Disk \\.\PhysicalDrive1 - 6001 GB / 5589 GiB - CHS 729602 255 63
hdr_size=92
hdr_lba_self=11721056255
hdr_lba_alt=1 (expected 1)
hdr_lba_start=34
hdr_lba_end=11721056222
hdr_lba_table=11721056223
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 11721054207 11721052160 [Basic data partition]
Trying alternate GPT
NTFS at 0/36/37
filesystem size 11721052160
sectors_per_cluster 128
mft_lcn 49152
mftmirr_lcn 1
clusters_per_index_record -12
NTFS part_offset=1179648, part_size=6001178705920, sector_size=512
NTFS at 0/36/37
mft_lcn 49152
mftmirr_lcn 1
MS Data 2304 11721054463 11721052160
NTFS, blocksize=65536, 6001 GB / 5589 GiB
NTFS at 729601/232/39
mftmirr_lcn 2
MS Data 2560 11721054719 11721052160
NTFS found using backup sector, blocksize=4096, 6001 GB / 5589 GiB
mftmirr_lcn 2
NTFS: Can't read MFT
MS Data 11721054719 23442106878 11721052160
NTFS, blocksize=4096, 6001 GB / 5589 GiB
This partition ends after the disk limits. (start=11721054719, size=11721052160, end=23442106878, disk end=11721056256)
file_win32_pread(200,11,buffer,3131121656(729602/1/56)) read err: read after end of file
file_win32_pread(200,11,buffer,3131121660(729602/1/60)) read err: read after end of file
file_win32_pread(200,8,buffer,3131121659(729602/1/59)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121652(729602/1/52)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121653(729602/1/53)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121654(729602/1/54)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121655(729602/1/55)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121656(729602/1/56)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121658(729602/1/58)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121660(729602/1/60)) read err: read after end of file
file_win32_pread(200,14,buffer,3131121662(729602/1/62)) read err: read after end of file
The harddisk (6001 GB / 5589 GiB) seems too small! (< 12 TB / 10 TiB)
Re: Recover 2 partition from RAID 0
Did you use TestDisk 64bit?
TestDisk 7.1WIP 32bit is recommended.
Under disk selection select Disk /dev/sd' (a,b,c, etc..) instead of PhysicalDrive.
TestDisk 64bit is only recommended on genuine 64bit environment like Itanium.
There is also a note:
Windows 64-bit Use only on systems lacking WoW64 as some features are missing
Can you repeat your diagnose and copy and paste the content of your testdisk.log into your next post?
