Recover a NTFS partition overwritten with XFS
JJMidday
#1 Post by JJMidday »
Hi everybody! I've done a really huge error using dd on Linux because i didn't specified a file of output and it started to write on my partition sdb2, which is my NTFS partition, my root directory in XFS. I stopped in a few seconds the process.
I'm sure of photorec works but it cannot retrieve filenames so i'm trying with testdisk but it list partitions as they are Linux partitions. There is an hope?
Re: Recover a NTFS partition overwritten with XFS
Did you run a complete Deeper Search (not Quick Search), searching for a backup of your boot sector?
Only Deeper Search searches additional for a backup of the boot sector.
On NTFS, the last sector of your partition is the backup of the boot sector.
If your NTFS-partition used the whole space of your disk, you must run a complete scan.
Watch the result of Deeper Search, when your NTFS-Partition was found, please select it and press p to have a try to list your files.
JJMidday
#3 Post by JJMidday »
I did a deeper search and it gave me a list of partition stated as "D" and "Linux". I tried one by one setting their type as "NTFS" and looking for the list of files but I always obtained a "damaged filesystem". I'll insert log file in next post
#4 Post by Fiona »
For me it's important to watch your logfile of the complete Deeper Search and the reusults.
Using Type to change partition types, is probably not helpful.
TestDisk should recognize the file system by the boot sector or it's backup automatically.
Linux can list lots of partitions through the found backup of the superblock.
JJMidday
#5 Post by JJMidday »
Hi Fiona,
This is my log of deeper search. (It is the right one hopefully)
Tue Dec 1 16:21:49 2015
OS: Windows 8 (9200)
filewin32_getfilesize(\\.\E:) GetFileSize err Funzione non corretta.
filewin32_setfilepointer(\\.\E:) SetFilePointer err Funzione non corretta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=300101999616
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=2202000384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=925085204480
Drive F: - 300 GB / 279 GiB - CHS 36485 255 63, sector size=512
Drive G: - 2202 MB / 2099 MiB - CHS 2099 64 32, sector size=512
Drive H: - 925 GB / 861 GiB - CHS 882230 64 32, sector size=512
Analyse Drive H: - 925 GB / 861 GiB - CHS 882230 64 32
file_win32_pread(512,2,buffer,1806807039(882229/63/32)) read err: read after end of file
NTFS at 882229/63/32
heads/cylinder 255 (NTFS) != 64 (HD)
sect/track 63 (NTFS) != 32 (HD)
filesystem size 1806807040
mft_lcn 4
mftmirr_lcn 112925439
HPFS - NTFS 0 0 1 882229 63 32 1806807040
NTFS found using backup sector, blocksize=4096, 925 GB / 861 GiB
Partition not added.
Store new MBR code
recover_EXT2: s_block_group_nr=0/234, s_mnt_count=21/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 7680000
recover_EXT2: part_size 61440000
Linux 114327 0 1 144326 63 32 61440000
ext4 blocksize=4096 Large_file Sparse_SB Recover, 31 GB / 29 GiB
block_group_nr 243
recover_EXT2: "e2fsck -b 7962624 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=243/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 195312896
recover_EXT2: part_size 1562503168
Linux 119289 0 1 882229 63 32 1562503168
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 800 GB / 745 GiB
get_geometry_from_list_part_aux head=64 nbr=4
get_geometry_from_list_part_aux head=16 nbr=4
get_geometry_from_list_part_aux head=32 nbr=4
Change partition type:
P HPFS - NTFS 119289 0 1 882229 63 32 1562503168
Not an exFAT boot sector.
dir_partition inode=2
ext2fs_dir_iterate failed with error 1.
1 P HPFS - NTFS 119289 0 1 882229 63 32 1562503168
recover_EXT2: s_block_group_nr=0/234, s_mnt_count=23/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 114315 2 1 144315 1 32 61440000
Linux 114362 2 1 144362 1 32 61440000
Linux 114363 0 1 144362 63 32 61440000
Linux 114367 2 1 144367 1 32 61440000
block_group_nr 7
recover_EXT2: "e2fsck -b 229376 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=7/234, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 119289 0 1 149288 63 32 61440000
ext4 blocksize=4096 Large_file Sparse_SB Backup_SB, 31 GB / 29 GiB
recover_EXT2: s_block_group_nr=0/5960, s_mnt_count=2/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 120958 0 1 883898 63 32 1562503168
ext4 blocksize=4096 Large_file Sparse_SB Recover, 800 GB / 745 GiB
This partition ends after the disk limits. (start=247721984, size=1562503168, end=1810225151, disk end=1806807040)
recover_EXT2: s_block_group_nr=0/5960, s_mnt_count=1/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 121029 1 1 883970 0 32 1562503168
This partition ends after the disk limits. (start=247867424, size=1562503168, end=1810370591, disk end=1806807040)
block_group_nr 125
recover_EXT2: "e2fsck -b 4096000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=125/234, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 243
block_group_nr 343
recover_EXT2: "e2fsck -b 11239424 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=343/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 625
recover_EXT2: "e2fsck -b 20480000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=625/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 729
recover_EXT2: "e2fsck -b 23887872 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=729/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2187
recover_EXT2: "e2fsck -b 71663616 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2187/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
block_group_nr 2401
recover_EXT2: "e2fsck -b 78675968 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=2401/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
Linux 500354 1 1 1263295 0 32 1562503168
This partition ends after the disk limits. (start=1024725024, size=1562503168, end=2587228191, disk end=1806807040)
Linux 500374 1 1 1263315 0 32 1562503168
This partition ends after the disk limits. (start=1024765984, size=1562503168, end=2587269151, disk end=1806807040)
Linux 500386 0 1 1263326 63 32 1562503168
This partition ends after the disk limits. (start=1024790528, size=1562503168, end=2587293695, disk end=1806807040)
Linux 500387 1 1 1263328 0 32 1562503168
This partition ends after the disk limits. (start=1024792608, size=1562503168, end=2587295775, disk end=1806807040)
Linux 500426 0 1 1263366 63 32 1562503168
This partition ends after the disk limits. (start=1024872448, size=1562503168, end=2587375615, disk end=1806807040)
Linux 500457 2 1 1263398 1 32 1562503168
This partition ends after the disk limits. (start=1024936000, size=1562503168, end=2587439167, disk end=1806807040)
Linux 500458 0 1 1263398 63 32 1562503168
This partition ends after the disk limits. (start=1024937984, size=1562503168, end=2587441151, disk end=1806807040)
Linux 500465 1 1 1263406 0 32 1562503168
This partition ends after the disk limits. (start=1024952352, size=1562503168, end=2587455519, disk end=1806807040)
Linux 500466 1 1 1263407 0 32 1562503168
This partition ends after the disk limits. (start=1024954400, size=1562503168, end=2587457567, disk end=1806807040)
Linux 500469 0 1 1263409 63 32 1562503168
This partition ends after the disk limits. (start=1024960512, size=1562503168, end=2587463679, disk end=1806807040)
Linux 500471 2 1 1263412 1 32 1562503168
This partition ends after the disk limits. (start=1024964672, size=1562503168, end=2587467839, disk end=1806807040)
block_group_nr 3125
recover_EXT2: "e2fsck -b 102400000 -B 4096 device" may be needed
recover_EXT2: s_block_group_nr=3125/5960, s_mnt_count=0/4294967295, s_blocks_per_group=32768, s_inodes_per_group=8192
mft_lcn 4
The harddisk (925 GB / 861 GiB) seems too small! (< 1324 GB / 1233 GiB)
get_geometry_from_list_part_aux head=64 nbr=8
get_geometry_from_list_part_aux head=8 nbr=8
get_geometry_from_list_part_aux head=16 nbr=8
get_geometry_from_list_part_aux head=32 nbr=8
ext2fs_dir_iterate failed with error 2133571387.
P Linux 119289 0 1 882229 63 32 1562503168
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : No
mft_lcn 4
Store new MBR code
mft_lcn 4
Store new MBR code
JJMidday
#6 Post by JJMidday »
I'm sorry. That wasn't the right log. This is the correct log after a deeper search. I tried to Load a Backup but TestDisk cannot find a backup..
Wed Dec 9 09:12:15 2015
Drive G: - 2202 MB / 2099 MiB - CHS 267 255 63, sector size=512
Drive H: - 925 GB / 861 GiB - CHS 112468 255 63, sector size=512
New options :
Dump : No
Expert mode : Yes
Analyse Drive H: - 925 GB / 861 GiB - CHS 112468 255 63
Linux 14574 164 55 18399 27 60 61440000
block_group_nr 243
Linux 15207 54 16 112468 136 52 1562503168
P Linux 15207 54 16 112468 136 52 1562503168
1 P Linux 15207 54 16 112468 136 52 1562503168
Linux 14579 60 10 18403 178 15 61440000
block_group_nr 7
Linux 15207 54 16 19031 172 21 61440000
Linux 15419 249 63 112681 77 36 1562503168
block_group_nr 125
block_group_nr 243
block_group_nr 343
block_group_nr 625
block_group_nr 729
block_group_nr 2187
block_group_nr 2401
Linux 63790 66 21 161051 148 57 1562503168
Linux 63795 91 41 161056 174 14 1562503168
Linux 63799 111 57 161060 194 30 1562503168
Linux 63800 214 31 161062 42 4 1562503168
block_group_nr 3125
NTFS at 112468/136/52
mft_lcn 4
HPFS - NTFS 0 0 1 112468 136 52 1806807040
interface_load
interface_load
interface_load
interface_load
Store new MBR code
