photorec not extracting png image Topic is solved
ricksimpson
#1 Post by ricksimpson »
Im feeding photorec an exe file with this command line:
photorec_win.exe /debug /log /cmd "file.exe" partition_none,fileopt,search /d "rec"
or
photorec_win.exe /debug /log /cmd "file.exe" fileopt,everything,enable,search /d "rec"
and it only outputs the exe file, no png, i then extracted the png manually and checked with
fidentify_win.exe "00004815.png"
00004815.png: png
so it seems the signature matches, i believe it could be due to the search mode in use, i will keep fiddling around but if anyone notices what could be going on please let me know!
-r1ck
Re: photorec not extracting png image
The png inside the exe file isn't aligned to 512 byte boundary.
Try
photorec_win.exe /debug /log /cmd "file.exe" partition_none,blocksize,1,search /d "rec"
ricksimpson
#3 Post by ricksimpson »
thank you!
