Unallocated 3TB GPT drive
adilibe
#1 Post by adilibe »
I did a fresh windows install a few days ago only to find out that my Seagate 3TB external hard drive which I used to back everything up wasn't showing up under windows. I checked the disk manager and it's now showing up as unallocated :shock:. Quick search doesn't do anything and then it goes into deep search but It seems like its going to take a LOOOOOOOOOOONG time, do I have any hope? :|
Here are some screenshots...
adilibe
Re: Unallocated 3TB GPT drive
#2 Post by adilibe »
For some more background information. Once I turned on the computer after the Windows install, the first time I checked the disk manager I saw that it my 3TB was now being listed as an unallocated Intel MBR drive which was split into 2.2TB and .7TB rather than a single 3TB GPT. So i converted to GPT and did nothing else.
EDIT: Looked around on the boards some more and I switched to the 32-bit version. One more thing is that on the "select media" screen...I see my 3TB drive listed twice
Once as /dev/sde/
Once as \\.\PhysicalDrive4
Also when I select Advanced this is what I see :|
#3 Post by Fiona »
Would it be possible to use TestDisk6.14 -32bit?
The 64bit-version is only intended on systems lacking wow64 as some features are not available.
Windows doesn't display the disk type like GPT or basic correctly.
Because at the moment I'm testing it.
To exclude anything wrong, would it be possible to right click in your disk management console in the left square called basic and Disk 5?
Please upload a screen.
If your disk type is GPT you could immediately diagnose your boot sector.
Infos will follow.
Even my disk is converted as GPT and still displayed as basic.
adilibe
#4 Post by adilibe »
Thanks for the quick reply Fiona, check my updated second post I updated to 32 bit and reposted screenshots and more information probably the same time you posted
#5 Post by Fiona »
Same situation like in my test.
Your disk is displayed as basic but if you right click it, it displays that you can convert it to MBR.
So you know exactly that you have a GPT disk.
Would it be possible to run in TestDisk Quick Search?
Your found partition should be MSData!
If your partition is found, you can check it and press p to have a try to list your data.
Your current partition is a MS Reserved partition.
This partition doesn't contain your data.
adilibe
#6 Post by adilibe »
The Quick Search screen looks like that first screen shot that I posted
I ran a quick search and it didn't do anything. It never found a MSData partition, so then it automatically goes into a deeper search. Currently it has been running for 6.5 hours and only 2%........................... :(
Should I just wait and let this continue to run?
adilibe
#7 Post by adilibe »
Update: Here is where I'm at after about 42hours of running deep search. :|
Should I keep running this deep search? Does anyone have a suggestion for my problem?
adilibe
#8 Post by adilibe »
Ok So after a LOOOOONG time of running deep search this is the message that I've gotten
Then I click continue and I get this screen
Help!!!
#9 Post by Fiona »
Did you use the 64bit-version again?
http://i48.tinypic.com/34y199u.png
I recommend to use the 32-bit version!
Please could you repeat your diagnose using the 32-bit version?
At least, to recover a partition, your partition should be found.
If not, you should recreate the same situation like before without to format something.
Probably it requires to recover your MSReserved partition first. to get the start from you previous MSData-partition.
But Infos will follow only if you didn't find your MS Data partition
adilibe
#10 Post by adilibe »
Let me try to explain better. I'm not using the 64-bit version anymore. I just got finished running a deep search which took a little less than 2 weeks time and I got the following screen which says "Drive too small".
That didn't work so just now, I quickly started testdisk and ran as admin. selected my 3TB hard drive. Clicked EFI GPT partition. Clicked Analyze (the same as i did before) Then I get this screen again which says No FAT, NTFS, ext2, JFS, Reiser, cramfs or XFS marker.
Now once I select [quick search] nothing shows up for about 10 seconds then It immediately goes into this screen which would take almost 2 weeks to run again so I quit Test Disk. Here is the screen and here is the logfile.
Tue Jun  5 18:11:27 2012
Compilation date: 2012-05-21T08:46:51
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=3000592977920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=300069052416
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=3000592977920
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=256053870592
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000397795328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500107805184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=300068864512
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - OCZ-VERT EX4, S/N:CO-Z978EA1839003ZX3H, FW:1.4R
Disk /dev/sdb - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - Hitachi HDS723020BLA, S/N:NM21043FR3LHD0, FW:MN6O
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HDT725050VLA, S/N:FV4D104RV1GBCZ, FW:V56O
Disk /dev/sdd - 300 GB / 279 GiB - CHS 36481 255 63, sector size=512 - WDC WD30 00HLFS-01G6U, S/N:W -DXW0E7CC92013, FW:04.0
Disk /dev/sde - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Seagate GoFlex Desk, S/N:NA0LSNV2, FW:0D19
Disk \\.\PhysicalDrive4 - 3000 GB / 2794 GiB - CHS 45600 255 63, sector size=4096 - Seagate GoFlex Desk, S/N:NA0LSNV2, FW:0D19
Disk /dev/sde - 3000 GB / 2794 GiB - Seagate GoFlex Desk
Partition table type: EFI GPT
Analyse Disk /dev/sde - 3000 GB / 2794 GiB - CHS 45600 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=732566644 (expected 732566644)
hdr_lba_start=6
hdr_lba_end=732566639
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                    6      32773      32768 [Microsoft reserved partition]
What I'm saying is that I don't understand what you mean by recovering the MSReserved partition to get the start from my previous MSData, How do I do that because I'm given no option for this. Sorry, I'm just really frustrated by this...I really do appreciate the help so far.
