No files after MFT Repair
Spegs21
#1 Post by Spegs21 »
I have an external drive in a usb enclosure that windows was asking to format. I booted a live cd and ran testdisk. It recognized the disk as NTFS and found the partition and I was able to view the files. I repaired it as a primary partition and try tried to get Windows to recognize it but it still would not. I fired the live cd back up and looked at the NTFS boot sector. The backup was bad so I repaired it. No problem there. The problem occured when I noticed the MFT were different. I recovered the primary from the backup and now none of the files appear in the partition. I realize I probably should not have done that considering the files were accessible before but I did not think it would have that effect.
I'm running through ZAR X now and will try GetMyDataBack. Is there any hope here or is it hosed?
Re: No files after MFT Repair
I don't recommend to fix a backup of the boot sector.
It modifies your file system.
Something to try would be to run a RebuildBS and have another try to list your files.
Please let me know, did it work for you?
Don't use RepairMFT either!
