Then, the controller died and I am now trying to get the data using another, older enclosure - the drive itself seems ok, but the problem is that the controller apparently did a 4kB sector emulation (i.e. the drive has 512B sectors, but the controller translates this to 4kB sectors and exposes this to the OS to get around the 2.2 TB limitation) - something that the other enclosure does not do, so I see 512B sectors now, so the partition table points to the wrong location.
I did try to get this working with testdisk - testdisk does find the partition with the correct size, but does give a warning about the sector size:
Warning: number of bytes per sector mismatches 4096 (NTFS) != 512 (HD)I did manage to replace the MBR with a GPT table that should now be correct for 512B sectors, but I still get the same errors about the file system.
Is there any way to get around the sector size problem and at least read the files on the disk, without having to get another enclosure that does 4k emulation?
Any help is appreciated.
1 P MS Data 2048 5860511999 5860509952 [MediaHDD]
