Hello
when i check CrystalDiskInfo status is caution
when i run test disk tops on analyse cylinder %63 after 5 min I stopped analayse. I can see 2 green partition but can not list files gives error : can't open filesystem. Filesystem seems damaged
what should i do, my disk died?
Thu Dec 24 22:45:01 2015
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000170586112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=107374182400
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=196574445568
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=324010229760
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=314575801344
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=361583308800
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121597 255 63, sector size=512
Drive C: - 107 GB / 100 GiB - CHS 13054 255 63, sector size=512
Drive D: - 196 GB / 183 GiB - CHS 23898 255 63, sector size=512
Drive E: - 324 GB / 301 GiB - CHS 39392 255 63, sector size=512
Drive F: - 314 GB / 292 GiB - CHS 38244 255 63, sector size=512
Drive G: - 361 GB / 336 GiB - CHS 43960 255 63, sector size=512
Analyse Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121597 255 63
NTFS at 0/1/1
file_pread(5,1023,buffer,6294592(391/209/11)) ReadFile Data error (cyclic redundancy check).
NTFS: Can't read MFT
NTFS at 38245/0/1
file_pread(5,1023,buffer,620700454(38636/208/11)) ReadFile Data error (cyclic redundancy check).
1 P HPFS - NTFS 0 1 1 38244 254 63 614405862
2 P HPFS - NTFS 38245 0 1 77636 254 63 632832480
Invalid NTFS or EXFAT boot
3 P HPFS - NTFS 77637 0 1 121596 254 63 706217400
NTFS at 0/1/1
filesystem size 614405862
mftmirr_lcn 38400366
NTFS, blocksize=4096, 314 GB / 292 GiB
NTFS at 38245/0/1
filesystem size 632832480
mftmirr_lcn 39552029
NTFS, blocksize=4096, 324 GB / 301 GiB
file_pread(5,16,buffer,1247238406(77637/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1247238406(77637/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238413(77637/0/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247238421(77637/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247238468(77637/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238484(77637/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247238531(77637/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247240453(77637/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238437(77637/0/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1247238471(77637/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238547(77637/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247238594(77637/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247240516(77637/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238565(77637/2/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238693(77637/4/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238821(77637/6/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247238949(77637/8/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239077(77637/10/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239205(77637/12/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239333(77637/14/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239461(77637/16/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239589(77637/18/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239717(77637/20/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239845(77637/22/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247239973(77637/24/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240101(77637/26/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247240192(77637/28/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247240194(77637/28/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247240208(77637/28/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247240255(77637/29/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240271(77637/29/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247240318(77637/30/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247242240(77637/60/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240229(77637/28/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240357(77637/30/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240485(77637/33/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240613(77637/35/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240741(77637/37/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240869(77637/39/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247240997(77637/41/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241125(77637/43/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241253(77637/45/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241381(77637/47/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241509(77637/49/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241637(77637/51/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241765(77637/53/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247241893(77637/55/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242021(77637/57/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242149(77637/59/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247242242(77637/60/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247242256(77637/61/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247242303(77637/61/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242319(77637/62/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247242366(77637/62/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247244288(77637/93/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242277(77637/61/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242405(77637/63/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242533(77637/65/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242661(77637/67/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242789(77637/69/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247242917(77637/71/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243045(77637/73/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243173(77637/75/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243301(77637/77/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243429(77637/79/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243557(77637/81/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243685(77637/83/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243813(77637/85/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247243941(77637/87/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244069(77637/89/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244197(77637/91/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247244290(77637/93/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247244304(77637/93/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247244351(77637/94/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244367(77637/94/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247244414(77637/95/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247246336(77637/125/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244325(77637/93/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244453(77637/96/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244581(77637/98/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244709(77637/100/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244837(77637/102/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247244965(77637/104/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245093(77637/106/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245221(77637/108/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245349(77637/110/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245477(77637/112/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245605(77637/114/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245733(77637/116/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245861(77637/118/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247245989(77637/120/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246117(77637/122/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246245(77637/124/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247246338(77637/125/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247246352(77637/126/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247246399(77637/126/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246415(77637/127/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247246462(77637/127/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247248384(77637/158/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246373(77637/126/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246501(77637/128/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246629(77637/130/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247246757(77637/132/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247248386(77637/158/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247248400(77637/158/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247248447(77637/159/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247248463(77637/159/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247248510(77637/160/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247250432(77637/190/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247250434(77637/190/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247250448(77637/191/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247250495(77637/191/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247250511(77637/192/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247250558(77637/192/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247252480(77637/223/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247252482(77637/223/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247252496(77637/223/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247252543(77637/224/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247252559(77637/224/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247252606(77637/225/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247254528(77638/0/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1247254470(77638/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247254486(77638/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247254533(77638/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247254549(77638/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247254596(77638/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247256518(77638/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247254530(77638/0/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247254544(77638/1/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247254591(77638/1/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247254607(77638/2/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247254654(77638/2/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247256576(77638/33/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247254547(77638/1/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,5,buffer,1247254615(77638/2/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,5,buffer,1247254665(77638/3/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247256581(77638/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247256578(77638/33/30)) ReadFile Data error (cyclic redundancy checx
afile_pread(5,3,buffer,1247286663(77640/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247286679(77640/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247286726(77640/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247288648(77640/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1247286666(77640/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247286742(77640/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247286789(77640/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247288711(77640/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247287298(77640/11/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247287312(77640/11/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247287359(77640/12/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247287375(77640/12/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247287422(77640/13/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247289344(77640/43/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247289346(77640/43/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247289360(77640/43/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247289407(77640/44/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247289423(77640/44/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247289470(77640/45/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247291392(77640/76/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247291394(77640/76/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247291408(77640/76/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247291455(77640/77/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247291471(77640/77/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247291518(77640/78/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247293440(77640/108/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247293442(77640/108/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247293456(77640/108/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247293503(77640/109/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247293519(77640/109/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247293566(77640/110/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247295488(77640/141/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247295490(77640/141/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247295504(77640/141/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247295551(77640/142/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247295567(77640/142/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247295614(77640/143/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247297536(77640/173/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247297538(77640/173/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247297552(77640/173/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247297599(77640/174/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247297615(77640/174/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247297662(77640/175/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247299584(77640/206/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247299586(77640/206/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247299600(77640/206/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247299647(77640/207/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247299663(77640/207/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247299710(77640/208/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247301632(77640/238/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247301634(77640/238/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247301648(77640/238/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247301695(77640/239/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247301711(77640/239/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247301758(77640/240/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247303680(77641/16/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1247302665(77641/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247302681(77641/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247302728(77641/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247302744(77641/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247302791(77641/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247304713(77641/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1247302731(77641/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247302807(77641/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247302854(77641/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247304776(77641/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247303682(77641/16/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247303696(77641/16/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247303743(77641/17/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247303759(77641/17/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247303806(77641/18/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247305728(77641/48/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247305730(77641/48/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247305744(77641/48/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247305791(77641/49/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247305807(77641/49/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247305854(77641/50/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247307776(77641/81/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247307778(77641/81/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247307792(77641/81/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247307839(77641/82/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247307855(77641/82/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247307902(77641/83/9)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247309824(77641/113/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247309826(77641/113/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247309840(77641/113/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247309887(77641/114/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247309903(77641/114/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247309950(77641/115/41)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247311872(77641/146/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247311874(77641/146/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247311888(77641/146/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247311935(77641/147/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247311951(77641/147/26)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247311998(77641/148/10)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247313920(77641/178/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247313922(77641/178/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247313936(77641/178/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247313983(77641/179/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247313999(77641/179/58)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247314046(77641/180/42)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247315968(77641/211/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247315970(77641/211/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247315984(77641/211/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247316031(77641/212/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247316047(77641/212/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247316094(77641/213/11)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247318016(77641/243/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247318018(77641/243/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247318032(77641/243/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247318079(77641/244/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247318095(77641/244/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247318142(77641/245/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247320064(77642/21/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1247318730(77642/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247318746(77642/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247318793(77642/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247318809(77642/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247318856(77642/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247320778(77642/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1247318796(77642/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247318872(77642/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247318919(77642/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247320841(77642/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247320066(77642/21/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247320080(77642/21/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247320127(77642/22/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247320143(77642/22/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247320190(77642/23/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247322112(77642/53/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247322114(77642/53/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247322128(77642/53/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247322175(77642/54/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247322191(77642/54/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247322238(77642/55/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247324160(77642/86/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247324162(77642/86/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247324176(77642/86/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247324223(77642/87/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247324239(77642/87/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247324286(77642/88/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247326208(77642/118/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247326210(77642/118/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247326224(77642/118/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247326271(77642/119/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247326287(77642/119/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247326334(77642/120/45)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247328256(77642/151/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247328258(77642/151/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247328272(77642/151/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247328319(77642/152/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247328335(77642/152/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247328382(77642/153/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247330304(77642/183/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247330306(77642/183/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247330320(77642/183/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247330367(77642/184/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247330383(77642/184/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247330430(77642/185/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247332352(77642/216/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247332354(77642/216/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247332368(77642/216/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247332415(77642/217/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247332431(77642/217/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247332478(77642/218/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247334400(77642/248/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247334402(77642/248/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247334416(77642/248/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247334463(77642/249/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247334479(77642/249/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247334526(77642/250/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247336448(77643/26/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1247334795(77643/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247334811(77643/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247334858(77643/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247334874(77643/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247334921(77643/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247336843(77643/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1247334861(77643/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247334937(77643/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247334984(77643/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247336906(77643/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247336450(77643/26/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247336464(77643/26/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247336511(77643/27/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247336527(77643/27/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247336574(77643/28/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247338496(77643/58/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247338498(77643/58/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247338512(77643/59/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247338559(77643/59/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247338575(77643/60/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247338622(77643/60/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247340544(77643/91/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247340546(77643/91/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247340560(77643/91/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247340607(77643/92/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247340623(77643/92/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247340670(77643/93/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247342592(77643/123/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247342594(77643/123/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247342608(77643/124/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247342655(77643/124/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247342671(77643/125/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247342718(77643/125/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247344640(77643/156/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247344642(77643/156/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247344656(77643/156/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247344703(77643/157/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247344719(77643/157/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247344766(77643/158/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247346688(77643/188/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1247346690(77643/188/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247346704(77643/189/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1247346751(77643/189/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1247346767(77643/190/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1247346814(77643/190/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1247348736(77643/221/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248102526(77690/201/14)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248104448(77690/231/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248104450(77690/231/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248104464(77690/231/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248104511(77690/232/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248104527(77690/232/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248104574(77690/233/46)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248106496(77691/9/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1248105915(77691/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248105931(77691/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248105978(77691/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248105994(77691/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248106041(77691/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248107963(77691/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1248105981(77691/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248106057(77691/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248106104(77691/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248108026(77691/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248106498(77691/9/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248106512(77691/9/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248106559(77691/10/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248106575(77691/10/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248106622(77691/11/15)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248108544(77691/41/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248108546(77691/41/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248108560(77691/41/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248108607(77691/42/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248108623(77691/42/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248108670(77691/43/47)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248110592(77691/74/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248110594(77691/74/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248110608(77691/74/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248110655(77691/75/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248110671(77691/75/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248110718(77691/76/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248112640(77691/106/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248112642(77691/106/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248112656(77691/107/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248112703(77691/107/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248112719(77691/108/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248112766(77691/108/48)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248114688(77691/139/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248114690(77691/139/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248114704(77691/139/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248114751(77691/140/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248114767(77691/140/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248114814(77691/141/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248116736(77691/171/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248116738(77691/171/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248116752(77691/172/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248116799(77691/172/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248116815(77691/173/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248116862(77691/173/49)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248118784(77691/204/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248118786(77691/204/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248118800(77691/204/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248118847(77691/205/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248118863(77691/205/34)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248118910(77691/206/18)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248120832(77691/236/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248120834(77691/236/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248120848(77691/237/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248120895(77691/237/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248120911(77691/238/3)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248120958(77691/238/50)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248122880(77692/14/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1248121980(77692/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248121996(77692/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248122043(77692/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248122059(77692/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248122106(77692/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248124028(77692/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1248122046(77692/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248122122(77692/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248122169(77692/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248124091(77692/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248122882(77692/14/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248122896(77692/14/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248122943(77692/15/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248122959(77692/15/35)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248123006(77692/16/19)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248124928(77692/46/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248124930(77692/46/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248124944(77692/47/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248124991(77692/47/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248125007(77692/48/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248125054(77692/48/51)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248126976(77692/79/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248126978(77692/79/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248126992(77692/79/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248127039(77692/80/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248127055(77692/80/36)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248127102(77692/81/20)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248129024(77692/111/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248129026(77692/111/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248129040(77692/112/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248129087(77692/112/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248129103(77692/113/5)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248129150(77692/113/52)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248131072(77692/144/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248131074(77692/144/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248131088(77692/144/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248131135(77692/145/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248131151(77692/145/37)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248131198(77692/146/21)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248133120(77692/176/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248133122(77692/176/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248133136(77692/177/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248133183(77692/177/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248133199(77692/178/6)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248133246(77692/178/53)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248135168(77692/209/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248135170(77692/209/24)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248135184(77692/209/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248135231(77692/210/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248135247(77692/210/38)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248135294(77692/211/22)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248137216(77692/241/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248137218(77692/241/56)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248137232(77692/242/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248137279(77692/242/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248137295(77692/243/7)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248137342(77692/243/54)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248139264(77693/19/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,16,buffer,1248138045(77693/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248138061(77693/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248138108(77693/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248138124(77693/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248138171(77693/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248140093(77693/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1248138111(77693/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248138187(77693/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248138234(77693/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248140156(77693/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248139266(77693/19/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248139280(77693/19/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248139327(77693/20/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248139343(77693/20/39)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248139390(77693/21/23)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248141312(77693/51/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248141314(77693/51/57)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248141328(77693/52/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248141375(77693/52/55)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248141391(77693/53/8)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248154126(77694/0/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248154173(77694/1/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248154189(77694/1/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248154236(77694/2/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248156158(77694/32/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,13,buffer,1248154176(77694/1/4)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248154252(77694/2/17)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248154299(77694/3/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248156221(77694/33/33)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248155650(77694/24/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248155664(77694/24/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248155711(77694/25/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248155727(77694/25/43)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248155774(77694/26/27)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248157696(77694/56/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248157698(77694/56/61)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248157712(77694/57/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248157759(77694/57/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248157775(77694/58/12)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248157822(77694/58/59)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248159744(77694/89/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248159746(77694/89/30)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248159760(77694/89/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248159807(77694/90/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248159823(77694/90/44)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248159870(77694/91/28)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248161792(77694/121/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248161794(77694/121/62)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248161808(77694/122/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1248161855(77694/122/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1248161871(77694/123/13)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1248161918(77694/123/60)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1248163840(77694/154/29)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1248163842(77694/154/31)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1953439740(121596/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1953439741(121596/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1953439755(121596/0/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1953439802(121596/0/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1953439818(121596/1/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1953439865(121596/1/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1953441787(121596/32/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1953455804(121596/254/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1953455805(121597/0/1)) ReadFile Data error (cyclic redundancy check).
file_pread(5,14,buffer,1953455806(121597/0/2)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1953455820(121597/0/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,3,buffer,1953455867(121597/0/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,8,buffer,1953455883(121597/1/16)) ReadFile Data error (cyclic redundancy check).
file_pread(5,11,buffer,1953455930(121597/1/63)) ReadFile Data error (cyclic redundancy check).
file_pread(5,2,buffer,1953457852(121597/32/32)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1953458175(121597/37/40)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,1953458176(121597/37/41)) ReadFile Incorrect function.
file_pread(5,14,buffer,1953458177(121597/37/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953458191(121597/37/56)) lseek err Invalid argument
file_pread(5,3,buffer,1953458238(121597/38/4a0)) lseek err Invalid argument
file_pread(5,8,buffer,1953458254(121597/38/56)) lseek err Invalid argument
file_pread(5,11,buffer,1953458301(121597/39/40)) lseek err Invalid argument
file_pread(5,2,buffer,1953460223(121597/70/9)) lseek err Invalid argument
* HPFS - NTFS 0 1 1 38244 254 63 614405862
file_pread(5,16,buffer,6291519(391/160/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6291519(391/160/25)) ReadFile Data error (cyclic redundancy check).
file_pread(5,1,buffer,6291520(391/160/26)) ReadFile Data error (cyclic redundancy check).
Not an exFAT boot sector.
1 * HPFS - NTFS 0 1 1 38244 254 63 614405862
can not reach hdd
Re: can not reach hdd
You should clone your disk to a new empty one (can be bigger) using gnu ddrescue.
Example: http://www.cgsecurity.org/wiki/Damaged_Hard_Disk
Once the copy is done, remove the damaged disk and try to access your data from the clone.
Thnak you for your kind response.
Is there any alternative for ddrescue on windows?
Is acronis true image an alternative ? I tried acronis but 20 min later it was still on "calculating backup time" step.
Under windows I use HDD RAW copy tool:
http://hddguru.com/software/HDD-Raw-Copy-Tool/
It's very fast too!
Please keep an eye on your source and destination disk.
It's very fast too!
