Error's and can't find other examples to learn from
Elmore
#1 Post by Elmore »
I'm a total newb so please forgive me as I'm trying to learn how to use this to recover my hard drive that has all of my kids pictures. Photo_rec does not recover any files from this drive. I've taken screen shot. I've selected a Intel drive as that's what I use. I've chosen to analyse the disk. I then get this once the disk is done analysed.
What do I do from here?
Thank you for your time!
Elmore
Re: Error's and can't find other examples to learn from
TestDisk 7.1WIP 32bit is recommended.
In testdisk under disk selection you should select your disk instead of your Drive L:.
Disk looks like Disk /dev/sd* (*= a, b, c etc..)
Can you repeat your diagnose?
Elmore
#3 Post by Elmore »
Fiona I did what you suggested and was able to get further. Not sure what to do now.
Thank you for your help Fiona.
Elmore
#4 Post by Elmore »
I've made an image with test disk. Not sure what to do with it now. Here's my log file if that helps.
Thanks!
Elmore
Wed Jan 6 13:02:27 2016
OS: Windows 8 (9200)
Failed to open ntfs attribute: No such file or directory.
ntfs_mft_load(): Failed.
Failed to load $MFT: No such file or directory.
Failed to startup volume: No such file or directory.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdh)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive7)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=319493767168
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=602603520
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1500299297280
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\J:)=104857600
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=500096991744
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=1073741824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=1996102828032
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\O:)=1073815040
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512
Disk /dev/sdb - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk /dev/sdh - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 319 GB / 297 GiB - CHS 38842 255 63, sector size=512
Drive D: - 602 MB / 574 MiB - CHS 143 64 32, sector size=2048
Drive E: - 1500 GB / 1397 GiB - CHS 182401 255 63, sector size=512
Drive J: - 104 MB / 100 MiB - CHS 12 255 63, sector size=512
Drive L: - 500 GB / 465 GiB - CHS 60799 255 63, sector size=512
Drive M: - 1073 MB / 1024 MiB - CHS 130 255 63, sector size=512
Drive N: - 1996 GB / 1859 GiB - CHS 242679 255 63, sector size=512
Drive O: - 1073 MB / 1024 MiB - CHS 130 255 63, sector size=512
Geometry from i386 MBR: head=240 sector=63
NTFS at 0/1/1
heads/cylinder 240 (NTFS) != 255 (HD)
1 * HPFS - NTFS 0 1 1 60799 254 63 976751937
Not an exFAT boot sector.
No space left for the file image.
Image created successfully.
wutizup
#5 Post by wutizup »
Elmore wrote:I'm a total newb so please forgive me as I'm trying to learn how to use this to recover my hard drive that has all of my kids pictures. Photo_rec does not recover any files from this drive. I've taken screen shot. I've selected a Intel drive as that's what I use. I've chosen to analyse the disk. I then get this once the disk is done analysed.
Elmore
hey buddy i am in the same boat as you and i got the exact screen you posted. Did you ever find out the solution to your problem? where you able to recover your pictures? I would appreciate any help possible. Thanks
#6 Post by Fiona »
The testdisk menu "Advanced" will only work when your partition in your partition table is correct.
Did you run Quick Search and Deeper Search too?
Might be possible that another partitions would be found too!
Can you try TestDisk 7.1WIP 32bit instead of TestDisk 7.0?
