Need help to make a custom signature
frevab
#1 Post by frevab »
Hi there
I nbeed some help to make a custom signature.
I have tried it but did not work.
The file extention is .CbWgc
The content of the files starts with "CamBFile" (see attach screenprint of the hex editor)
So I use Notepad and typed:
pfi 0 "CamBFile"
and saved the notepad file as photorec.sig as the instructions on http://www.cgsecurity.org/wiki/Add_your ... o_PhotoRec suggested.
What did I do wrong?
I located the file in the same folder as the PhotoRec_Win.exe as I want to recover this file from a external drive.
Re: Need help to make a custom signature
Create a photorec.sig file with
<code>
CbWgc 0 "CamBFile"
</code>
Check that the filename is ok, not photorec.sig.txt.
frevab
#3 Post by frevab »
does not work
c:\testdisk-7.1-WIP>fidentify_win photorec.sig
photorec.sig: unknown
also with other file name:
c:\testdisk-7.1-WIP>fidentify_win test.sig
test.sig: unknown
tried notepad file saved with ANSi code as well as UTF-8 code.
What do I do wrong?
To check the signature, use
c:\testdisk-7.1-WIP>fidentify_win sample_file.CbWgc
frevab
#5 Post by frevab »
Thanks you fo your help but I could recover the files without using PhotoRec in the end (see my other post).
