First, thank you so much for the program.  I was able to recover files from my hard drive so I'm ecstatic at this point.
Though I knew how to use computers about 30 years ago, technology has passed me by and I don't have a clue what I'm doing anymore.  When I read the threads in this forum giving advice to people with similar situations, I didn't have confidence to follow the advice because I didn't understand it enough to know if my situation is the same.  I'm afraid of doing more damage.
Background:  I have an Asus Transformer TX 300 CA running Windows 10.  The C drive is the boot drive.  It has a 500gb SSD that is partitioned into Drives E and Z.  The computer was no longer able to access drive Z for some reason.  The tablet half of the Transformer doesn't seem to have a good connection to the hard drive/keyboard half.  So it disconnects/reconnects to it frequently.  I suspect that it disconnected during a shutdown before the computer completed the shutdown process.  I've also noticed files disappear and reappear later.  It's very annoying (especially since I'm a teacher who uses this for student files and lessons every day).
I was trying to restore the Z drive and this is the message I got:
Drive Z: - 239 GB / 222 GiB - CHS 29094 255 63, sector size=512
 1 P Sys=72               119528  74  3 232582  38 44 1816210284
 2 * Sys=6C               120512  46 15 242121 118  1 1953653108
Can you direct me to the next step to resolve this conflict?
Thank you,
Marcus
						partition conflict
Re: partition conflict
Under disk selection you should select your disk instead of a drive.
It looks like Disk /dev/sd* (*=a, b, c, etc..).
A drive is similar to a partition and doesn't contain a partition table.
A partition table is stored on your disk in your MBR or GUID partition table.
Can you repeat your diagnose and under disk selection selct your disk instead of a drive?
TestDisk 7.1WIP 32bit is recommended.
Thank you so much for your response, Fiona.  I followed your suggestion of using 7.1 32 bit (note:  I believe my computer is a 64bit computer).  The contents of the log are rather long - too  long for a single post(max: 60,000 characters).  I'll split it up over multiple posts.  I hope they prove helpful.
Mon Jan 11 19:18:44 2016
TestDisk 7.1-WIP, Data Recovery Utility, January 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, Cygwin32 2002.0
Compilation date: 2016-01-07T18:42:01
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=500107853824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=500107853824
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=125772832256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=197366120448
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\Z:)=239311257600
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - SanDisk SSD U100 128GB, S/N:125002400262, FW:10.56.02
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HTS545050A7E380, S/N:TE851449H01TVW, FW:AD04
Disk /dev/sdb - 500 GB / 465 GiB - Hitachi HTS545050A7E380
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=976773151 (expected 976773151)
hdr_lba_start=34
hdr_lba_end=976773118
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 385482751 385480704 [Basic data partition]
2 P MS Data 467402752 934807551 467404800 [Basic data partition]
3 P Unknown 934807552 976771071 41963520 [Basic data partition]
NTFS at 0/32/33
filesystem size 385480704
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=197366120448, sector_size=512
NTFS at 0/32/33
mftmirr_lcn 2
NTFS, blocksize=4096, 197 GB / 183 GiB
NTFS at 29094/121/19
filesystem size 467400704
mftmirr_lcn 2
MS Data 2048 467402751 467400704
NTFS found using backup sector, blocksize=4096, 239 GB / 222 GiB
mftmirr_lcn 2
MS Data 467402751 934803454 467400704
NTFS, blocksize=4096, 239 GB / 222 GiB
NTFS at 58189/20/7
filesystem size 467404800
mftmirr_lcn 2
NTFS at 58189/20/7
mftmirr_lcn 2
MS Data 934807551 1402212350 467404800
This partition ends after the disk limits. (start=934807551, size=467404800, end=1402212350, disk end=976773152)
NTFS at 58189/20/8
filesystem size 41963520
mftmirr_lcn 2
MS Data 892844033 934807552 41963520
NTFS found using backup sector, blocksize=4096, 21 GB / 20 GiB
NTFS at 58189/20/8
mftmirr_lcn 2
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
NTFS at 0/32/33
mftmirr_lcn 2
NTFS at 0/32/33
mftmirr_lcn 2
mftmirr_lcn 2
mftmirr_lcn 2
NTFS at 58189/20/7
mftmirr_lcn 2
NTFS at 58189/20/7
mftmirr_lcn 2
NTFS at 58189/20/8
mftmirr_lcn 2
NTFS at 58189/20/8
mftmirr_lcn 2
Part 2:
MS Data 934807552 976771071 41963520
NTFS, blocksize=4096, 21 GB / 20 GiB
file_pread(5,1,buffer,976773152(60801/80/48)) ReadFile ??????????????????
file_pread(5,1,buffer,976773153(60801/80/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773154(60801/80/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773155(60801/80/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773156(60801/80/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773157(60801/80/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773158(60801/80/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773159(60801/80/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773160(60801/80/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773161(60801/80/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773162(60801/80/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773163(60801/80/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773164(60801/80/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773165(60801/80/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773166(60801/80/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773167(60801/80/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773168(60801/81/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773169(60801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773170(60801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773171(60801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773172(60801/81/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773173(60801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773174(60801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773175(60801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773176(60801/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773177(60801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773178(60801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773179(60801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773180(60801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773181(60801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773184(60801/81/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773185(60801/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773186(60801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773187(60801/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773188(60801/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773189(60801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773190(60801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773191(60801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773192(60801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773193(60801/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773194(60801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773195(60801/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773196(60801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773197(60801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773198(60801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773201(60801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773202(60801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773203(60801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773204(60801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773205(60801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773206(60801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773207(60801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773208(60801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773209(60801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773210(60801/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773211(60801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773212(60801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773213(60801/81/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773214(60801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773215(60801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773216(60801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773217(60801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773218(60801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773219(60801/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773220(60801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773221(60801/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773222(60801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773223(60801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773224(60801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773225(60801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773226(60801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773227(60801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773228(60801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773229(60801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773230(60801/81/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773231(60801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773232(60801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773233(60801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773234(60801/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773235(60801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773236(60801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773237(60801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773238(60801/82/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773239(60801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773240(60801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773241(60801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773242(60801/82/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773243(60801/82/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773244(60801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773245(60801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773247(60801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773248(60801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773249(60801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773250(60801/82/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773251(60801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773252(60801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773253(60801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773254(60801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773255(60801/82/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773256(60801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773257(60801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773258(60801/82/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773259(60801/82/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773260(60801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773261(60801/82/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773262(60801/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773263(60801/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773264(60801/82/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773265(60801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773266(60801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773267(60801/82/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773268(60801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773269(60801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773270(60801/82/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773271(60801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773272(60801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773273(60801/82/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773274(60801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773275(60801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773276(60801/82/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773277(60801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773278(60801/82/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773279(60801/82/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773280(60801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773281(60801/82/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773282(60801/82/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773283(60801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773284(60801/82/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773285(60801/82/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773286(60801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773287(60801/82/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773288(60801/82/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773289(60801/82/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773290(60801/82/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773291(60801/82/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773292(60801/82/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773293(60801/82/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773294(60801/83/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773295(60801/83/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773296(60801/83/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773297(60801/83/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773298(60801/83/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773299(60801/83/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773300(60801/83/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773301(60801/83/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773302(60801/83/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773303(60801/83/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773304(60801/83/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773305(60801/83/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773306(60801/83/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773307(60801/83/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773308(60801/83/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773309(60801/83/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773310(60801/83/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773311(60801/83/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773312(60801/83/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773313(60801/83/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773314(60801/83/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773315(60801/83/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773316(60801/83/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773317(60801/83/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773318(60801/83/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773319(60801/83/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773320(60801/83/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773321(60801/83/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773322(60801/83/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773323(60801/83/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773324(60801/83/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773325(60801/83/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773326(60801/83/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773327(60801/83/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773328(60801/83/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773329(60801/83/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773330(60801/83/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773331(60801/83/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773332(60801/83/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773333(60801/83/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773334(60801/83/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773335(60801/83/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773336(60801/83/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773337(60801/83/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773338(60801/83/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773339(60801/83/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773340(60801/83/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773341(60801/83/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773342(60801/83/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773343(60801/83/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773344(60801/83/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773345(60801/83/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773346(60801/83/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773347(60801/83/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773348(60801/83/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773349(60801/83/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773350(60801/83/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773351(60801/83/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773352(60801/83/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773353(60801/83/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773354(60801/83/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773355(60801/83/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773356(60801/83/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773357(60801/84/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773358(60801/84/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773359(60801/84/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773360(60801/84/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773361(60801/84/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773362(60801/84/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773363(60801/84/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773364(60801/84/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773365(60801/84/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773366(60801/84/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773367(60801/84/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773368(60801/84/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773369(60801/84/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773370(60801/84/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773371(60801/84/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773372(60801/84/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773373(60801/84/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773374(60801/84/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773375(60801/84/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773376(60801/84/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773377(60801/84/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773378(60801/84/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773379(60801/84/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773380(60801/84/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773381(60801/84/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773382(60801/84/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773383(60801/84/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773384(60801/84/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773385(60801/84/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773386(60801/84/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773387(60801/84/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773388(60801/84/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773389(60801/84/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773390(60801/84/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773391(60801/84/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773392(60801/84/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773393(60801/84/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773394(60801/84/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773395(60801/84/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773396(60801/84/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773397(60801/84/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773398(60801/84/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773399(60801/84/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773400(60801/84/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773401(60801/84/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773402(60801/84/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773403(60801/84/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773404(60801/84/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773405(60801/84/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773406(60801/84/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773407(60801/84/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773408(60801/84/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773409(60801/84/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773410(60801/84/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773411(60801/84/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773412(60801/84/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773413(60801/84/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773414(60801/84/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773415(60801/84/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773416(60801/84/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773417(60801/84/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773418(60801/84/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773419(60801/84/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773420(60801/85/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773421(60801/85/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773422(60801/85/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773423(60801/85/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773424(60801/85/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773425(60801/85/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773426(60801/85/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773427(60801/85/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773428(60801/85/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773429(60801/85/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773430(60801/85/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773431(60801/85/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773432(60801/85/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773433(60801/85/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773434(60801/85/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773435(60801/85/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773436(60801/85/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773437(60801/85/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773438(60801/85/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773439(60801/85/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773440(60801/85/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773441(60801/85/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773442(60801/85/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773443(60801/85/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773444(60801/85/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773445(60801/85/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773446(60801/85/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773447(60801/85/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773448(60801/85/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773449(60801/85/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773450(60801/85/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773451(60801/85/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773452(60801/85/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773453(60801/85/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773454(60801/85/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773455(60801/85/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773456(60801/85/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773457(60801/85/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773458(60801/85/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773459(60801/85/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773460(60801/85/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773461(60801/85/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773462(60801/85/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773463(60801/85/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773464(60801/85/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773465(60801/85/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773466(60801/85/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773467(60801/85/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773468(60801/85/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773469(60801/85/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773470(60801/85/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773471(60801/85/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773472(60801/85/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773473(60801/85/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773474(60801/85/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773475(60801/85/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773476(60801/85/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773477(60801/85/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773478(60801/85/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773479(60801/85/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773480(60801/85/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773481(60801/85/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773482(60801/85/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773483(60801/86/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773484(60801/86/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773485(60801/86/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773486(60801/86/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773487(60801/86/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773488(60801/86/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773489(60801/86/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773490(60801/86/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773491(60801/86/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773492(60801/86/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773493(60801/86/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773494(60801/86/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773495(60801/86/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773496(60801/86/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773497(60801/86/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773498(60801/86/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773499(60801/86/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773500(60801/86/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773501(60801/86/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773502(60801/86/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773503(60801/86/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773504(60801/86/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773505(60801/86/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773506(60801/86/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773507(60801/86/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773508(60801/86/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773509(60801/86/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773510(60801/86/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773511(60801/86/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773512(60801/86/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773513(60801/86/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773514(60801/86/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773515(60801/86/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773516(60801/86/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773517(60801/86/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773518(60801/86/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773519(60801/86/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773520(60801/86/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773521(60801/86/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773522(60801/86/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773523(60801/86/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773524(60801/86/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773525(60801/86/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773526(60801/86/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773527(60801/86/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773528(60801/86/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773529(60801/86/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773530(60801/86/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773531(60801/86/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773532(60801/86/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773533(60801/86/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773534(60801/86/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773535(60801/86/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773536(60801/86/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773537(60801/86/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773538(60801/86/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773539(60801/86/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773540(60801/86/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773541(60801/86/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773542(60801/86/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773543(60801/86/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773544(60801/86/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773545(60801/86/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773546(60801/87/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773547(60801/87/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773548(60801/87/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773549(60801/87/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773550(60801/87/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773551(60801/87/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773552(60801/87/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773553(60801/87/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773554(60801/87/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773555(60801/87/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773556(60801/87/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773557(60801/87/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773558(60801/87/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773559(60801/87/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773560(60801/87/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773561(60801/87/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773562(60801/87/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773563(60801/87/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773564(60801/87/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773565(60801/87/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773566(60801/87/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773567(60801/87/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773568(60801/87/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773569(60801/87/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773570(60801/87/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773571(60801/87/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773572(60801/87/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773573(60801/87/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773574(60801/87/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773575(60801/87/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773576(60801/87/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773577(60801/87/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773578(60801/87/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773579(60801/87/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773580(60801/87/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773581(60801/87/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773582(60801/87/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773583(60801/87/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773584(60801/87/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773585(60801/87/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773586(60801/87/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773587(60801/87/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773588(60801/87/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773589(60801/87/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773590(60801/87/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773591(60801/87/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773592(60801/87/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773593(60801/87/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773594(60801/87/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773595(60801/87/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773596(60801/87/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773597(60801/87/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773598(60801/87/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773599(60801/87/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773600(60801/87/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773601(60801/87/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773602(60801/87/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773603(60801/87/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773604(60801/87/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773605(60801/87/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773606(60801/87/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773607(60801/87/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773608(60801/87/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773609(60801/88/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773610(60801/88/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773611(60801/88/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773612(60801/88/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773613(60801/88/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773614(60801/88/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773615(60801/88/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773616(60801/88/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773617(60801/88/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773618(60801/88/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773619(60801/88/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773620(60801/88/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773621(60801/88/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773622(60801/88/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773623(60801/88/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773624(60801/88/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773625(60801/88/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773626(60801/88/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773627(60801/88/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773628(60801/88/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773629(60801/88/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773630(60801/88/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773631(60801/88/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773632(60801/88/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773633(60801/88/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773634(60801/88/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773635(60801/88/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773636(60801/88/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773637(60801/88/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773638(60801/88/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773639(60801/88/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773640(60801/88/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773641(60801/88/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773642(60801/88/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773643(60801/88/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773644(60801/88/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773645(60801/88/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773646(60801/88/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773647(60801/88/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773648(60801/88/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773649(60801/88/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773650(60801/88/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773651(60801/88/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773652(60801/88/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773653(60801/88/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773654(60801/88/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773655(60801/88/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773656(60801/88/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773657(60801/88/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773658(60801/88/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773659(60801/88/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773660(60801/88/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773661(60801/88/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773662(60801/88/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773663(60801/88/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773664(60801/88/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773665(60801/88/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773666(60801/88/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773667(60801/88/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773668(60801/88/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773669(60801/88/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773670(60801/88/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773671(60801/88/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773672(60801/89/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773673(60801/89/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773674(60801/89/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773675(60801/89/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773676(60801/89/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773677(60801/89/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773678(60801/89/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773679(60801/89/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773680(60801/89/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773681(60801/89/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773682(60801/89/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773683(60801/89/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773684(60801/89/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773685(60801/89/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773686(60801/89/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773687(60801/89/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773688(60801/89/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773689(60801/89/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773690(60801/89/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773691(60801/89/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773692(60801/89/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773693(60801/89/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773694(60801/89/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773695(60801/89/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773696(60801/89/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773697(60801/89/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773698(60801/89/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773699(60801/89/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773700(60801/89/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773701(60801/89/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773702(60801/89/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773703(60801/89/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773704(60801/89/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773705(60801/89/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773706(60801/89/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773707(60801/89/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773708(60801/89/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773709(60801/89/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773710(60801/89/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773711(60801/89/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773712(60801/89/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773713(60801/89/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773714(60801/89/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773715(60801/89/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773716(60801/89/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773717(60801/89/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773718(60801/89/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773719(60801/89/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773720(60801/89/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773721(60801/89/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773722(60801/89/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773723(60801/89/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773724(60801/89/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773725(60801/89/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773726(60801/89/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773727(60801/89/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773728(60801/89/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773729(60801/89/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773730(60801/89/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773731(60801/89/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773732(60801/89/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773733(60801/89/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773734(60801/89/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773735(60801/90/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773736(60801/90/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773737(60801/90/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773738(60801/90/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773739(60801/90/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773740(60801/90/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773741(60801/90/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773742(60801/90/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773743(60801/90/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773744(60801/90/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773745(60801/90/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773746(60801/90/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773747(60801/90/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773748(60801/90/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773749(60801/90/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773750(60801/90/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773751(60801/90/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773752(60801/90/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773753(60801/90/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773754(60801/90/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773755(60801/90/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773756(60801/90/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773757(60801/90/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773758(60801/90/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773759(60801/90/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773760(60801/90/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773761(60801/90/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773762(60801/90/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773763(60801/90/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773764(60801/90/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773765(60801/90/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773766(60801/90/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773767(60801/90/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773768(60801/90/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773769(60801/90/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773770(60801/90/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773771(60801/90/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773772(60801/90/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773773(60801/90/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773774(60801/90/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773775(60801/90/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773776(60801/90/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773777(60801/90/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773778(60801/90/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773779(60801/90/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773780(60801/90/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773781(60801/90/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773782(60801/90/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773783(60801/90/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773784(60801/90/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773785(60801/90/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773786(60801/90/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773787(60801/90/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773788(60801/90/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773789(60801/90/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773790(60801/90/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773791(60801/90/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773792(60801/90/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773793(60801/90/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773794(60801/90/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773795(60801/90/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773796(60801/90/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773797(60801/90/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773798(60801/91/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773799(60801/91/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773800(60801/91/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773801(60801/91/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773802(60801/91/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773803(60801/91/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773804(60801/91/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773805(60801/91/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773806(60801/91/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773807(60801/91/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773808(60801/91/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773809(60801/91/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773810(60801/91/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773811(60801/91/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773812(60801/91/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773813(60801/91/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773814(60801/91/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773815(60801/91/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773816(60801/91/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773817(60801/91/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773818(60801/91/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773819(60801/91/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773820(60801/91/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773821(60801/91/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773822(60801/91/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773823(60801/91/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773824(60801/91/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773825(60801/91/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773826(60801/91/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773827(60801/91/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773828(60801/91/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773829(60801/91/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773830(60801/91/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773831(60801/91/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773832(60801/91/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773833(60801/91/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773834(60801/91/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773835(60801/91/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773836(60801/91/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773837(60801/91/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773838(60801/91/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773839(60801/91/42)) lseek err Invalid argument
part 3:
file_pread(5,1,buffer,976773840(60801/91/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773841(60801/91/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773842(60801/91/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773843(60801/91/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773844(60801/91/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773845(60801/91/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773846(60801/91/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773847(60801/91/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773848(60801/91/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773849(60801/91/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773850(60801/91/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773851(60801/91/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773852(60801/91/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773853(60801/91/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773854(60801/91/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773855(60801/91/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773856(60801/91/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773857(60801/91/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773858(60801/91/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773859(60801/91/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773860(60801/91/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773861(60801/92/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773862(60801/92/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773863(60801/92/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773864(60801/92/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773865(60801/92/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773866(60801/92/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773867(60801/92/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773868(60801/92/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773869(60801/92/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773870(60801/92/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773871(60801/92/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773872(60801/92/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773873(60801/92/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773874(60801/92/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773875(60801/92/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773876(60801/92/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773877(60801/92/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773878(60801/92/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773879(60801/92/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773880(60801/92/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773881(60801/92/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773882(60801/92/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773883(60801/92/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773884(60801/92/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773885(60801/92/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773886(60801/92/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773887(60801/92/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773888(60801/92/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773889(60801/92/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773890(60801/92/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773891(60801/92/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773892(60801/92/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773893(60801/92/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773894(60801/92/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773895(60801/92/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773896(60801/92/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773897(60801/92/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773898(60801/92/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773899(60801/92/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773900(60801/92/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773901(60801/92/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773902(60801/92/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773903(60801/92/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773904(60801/92/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773905(60801/92/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773906(60801/92/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773907(60801/92/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773908(60801/92/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773909(60801/92/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773910(60801/92/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773911(60801/92/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773912(60801/92/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773913(60801/92/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773914(60801/92/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773915(60801/92/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773916(60801/92/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773917(60801/92/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773918(60801/92/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773919(60801/92/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773920(60801/92/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773921(60801/92/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773922(60801/92/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773923(60801/92/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773924(60801/93/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773925(60801/93/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773926(60801/93/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773927(60801/93/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773928(60801/93/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773929(60801/93/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773930(60801/93/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773931(60801/93/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773932(60801/93/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773933(60801/93/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773934(60801/93/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773935(60801/93/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773936(60801/93/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773937(60801/93/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773938(60801/93/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773939(60801/93/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773940(60801/93/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773941(60801/93/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773942(60801/93/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773943(60801/93/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773944(60801/93/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773945(60801/93/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773946(60801/93/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773947(60801/93/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773948(60801/93/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773949(60801/93/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773950(60801/93/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773951(60801/93/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773952(60801/93/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773953(60801/93/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773954(60801/93/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773955(60801/93/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773956(60801/93/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773957(60801/93/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773958(60801/93/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773959(60801/93/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773960(60801/93/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773961(60801/93/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773962(60801/93/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773963(60801/93/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773964(60801/93/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773965(60801/93/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773966(60801/93/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773967(60801/93/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773968(60801/93/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773969(60801/93/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773970(60801/93/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773971(60801/93/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773972(60801/93/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773973(60801/93/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773974(60801/93/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773975(60801/93/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773976(60801/93/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773977(60801/93/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773978(60801/93/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773979(60801/93/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773980(60801/93/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773981(60801/93/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773982(60801/93/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773983(60801/93/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773984(60801/93/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773985(60801/93/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773986(60801/93/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773987(60801/94/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773988(60801/94/2)) lseek err Invalid argument
file_pread(5,1,buffer,976773989(60801/94/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773990(60801/94/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773991(60801/94/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773992(60801/94/6)) lseek err Invalid argument
file_pread(5,1,buffer,976773993(60801/94/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773994(60801/94/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773995(60801/94/9)) lseek err Invalid argument
file_pread(5,1,buffer,976773996(60801/94/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773997(60801/94/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773998(60801/94/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773999(60801/94/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774000(60801/94/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774001(60801/94/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774002(60801/94/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774003(60801/94/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774004(60801/94/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774005(60801/94/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774006(60801/94/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774007(60801/94/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774008(60801/94/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774009(60801/94/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774010(60801/94/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774011(60801/94/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774012(60801/94/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774013(60801/94/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774014(60801/94/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774015(60801/94/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774016(60801/94/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774017(60801/94/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774018(60801/94/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774019(60801/94/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774020(60801/94/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774021(60801/94/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774022(60801/94/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774023(60801/94/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774024(60801/94/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774025(60801/94/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774026(60801/94/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774027(60801/94/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774028(60801/94/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774029(60801/94/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774030(60801/94/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774031(60801/94/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774032(60801/94/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774033(60801/94/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774034(60801/94/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774035(60801/94/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774036(60801/94/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774037(60801/94/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774038(60801/94/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774039(60801/94/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774040(60801/94/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774041(60801/94/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774042(60801/94/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774043(60801/94/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774044(60801/94/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774045(60801/94/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774046(60801/94/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774047(60801/94/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774048(60801/94/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774049(60801/94/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774050(60801/95/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774051(60801/95/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774052(60801/95/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774053(60801/95/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774054(60801/95/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774055(60801/95/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774056(60801/95/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774057(60801/95/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774058(60801/95/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774059(60801/95/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774060(60801/95/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774061(60801/95/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774062(60801/95/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774063(60801/95/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774064(60801/95/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774065(60801/95/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774066(60801/95/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774067(60801/95/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774068(60801/95/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774069(60801/95/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774070(60801/95/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774071(60801/95/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774072(60801/95/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774073(60801/95/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774074(60801/95/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774075(60801/95/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774076(60801/95/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774077(60801/95/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774078(60801/95/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774079(60801/95/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774080(60801/95/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774081(60801/95/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774082(60801/95/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774083(60801/95/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774084(60801/95/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774085(60801/95/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774086(60801/95/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774087(60801/95/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774088(60801/95/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774089(60801/95/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774090(60801/95/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774091(60801/95/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774092(60801/95/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774093(60801/95/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774094(60801/95/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774095(60801/95/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774096(60801/95/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774097(60801/95/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774098(60801/95/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774099(60801/95/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774100(60801/95/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774101(60801/95/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774102(60801/95/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774103(60801/95/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774104(60801/95/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774105(60801/95/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774106(60801/95/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774107(60801/95/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774108(60801/95/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774109(60801/95/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774110(60801/95/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774111(60801/95/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774112(60801/95/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774113(60801/96/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774114(60801/96/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774115(60801/96/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774116(60801/96/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774117(60801/96/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774118(60801/96/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774119(60801/96/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774120(60801/96/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774121(60801/96/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774122(60801/96/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774123(60801/96/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774124(60801/96/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774125(60801/96/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774126(60801/96/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774127(60801/96/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774128(60801/96/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774129(60801/96/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774130(60801/96/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774131(60801/96/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774132(60801/96/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774133(60801/96/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774134(60801/96/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774135(60801/96/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774136(60801/96/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774137(60801/96/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774138(60801/96/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774139(60801/96/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774140(60801/96/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774141(60801/96/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774142(60801/96/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774143(60801/96/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774144(60801/96/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774145(60801/96/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774146(60801/96/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774147(60801/96/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774148(60801/96/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774149(60801/96/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774150(60801/96/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774151(60801/96/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774152(60801/96/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774153(60801/96/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774154(60801/96/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774155(60801/96/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774156(60801/96/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774157(60801/96/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774158(60801/96/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774159(60801/96/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774160(60801/96/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774161(60801/96/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774162(60801/96/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774163(60801/96/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774164(60801/96/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774165(60801/96/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774166(60801/96/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774167(60801/96/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774168(60801/96/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774169(60801/96/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774170(60801/96/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774171(60801/96/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774172(60801/96/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774173(60801/96/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774174(60801/96/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774175(60801/96/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774176(60801/97/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774177(60801/97/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774178(60801/97/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774179(60801/97/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774180(60801/97/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774181(60801/97/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774182(60801/97/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774183(60801/97/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774184(60801/97/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774185(60801/97/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774186(60801/97/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774187(60801/97/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774188(60801/97/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774189(60801/97/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774190(60801/97/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774191(60801/97/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774192(60801/97/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774193(60801/97/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774194(60801/97/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774195(60801/97/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774196(60801/97/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774197(60801/97/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774198(60801/97/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774199(60801/97/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774200(60801/97/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774201(60801/97/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774202(60801/97/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774203(60801/97/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774204(60801/97/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774205(60801/97/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774206(60801/97/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774207(60801/97/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774208(60801/97/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774209(60801/97/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774210(60801/97/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774211(60801/97/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774212(60801/97/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774213(60801/97/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774214(60801/97/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774215(60801/97/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774216(60801/97/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774217(60801/97/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774218(60801/97/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774219(60801/97/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774220(60801/97/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774221(60801/97/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774222(60801/97/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774223(60801/97/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774224(60801/97/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774225(60801/97/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774226(60801/97/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774227(60801/97/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774228(60801/97/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774229(60801/97/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774230(60801/97/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774231(60801/97/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774232(60801/97/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774233(60801/97/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774234(60801/97/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774235(60801/97/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774236(60801/97/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774237(60801/97/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774238(60801/97/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774239(60801/98/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774240(60801/98/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774241(60801/98/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774242(60801/98/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774243(60801/98/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774244(60801/98/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774245(60801/98/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774246(60801/98/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774247(60801/98/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774248(60801/98/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774249(60801/98/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774250(60801/98/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774251(60801/98/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774252(60801/98/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774253(60801/98/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774254(60801/98/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774255(60801/98/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774256(60801/98/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774257(60801/98/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774258(60801/98/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774259(60801/98/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774260(60801/98/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774261(60801/98/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774262(60801/98/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774263(60801/98/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774264(60801/98/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774265(60801/98/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774266(60801/98/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774267(60801/98/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774268(60801/98/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774269(60801/98/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774270(60801/98/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774271(60801/98/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774272(60801/98/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774273(60801/98/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774274(60801/98/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774275(60801/98/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774276(60801/98/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774277(60801/98/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774278(60801/98/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774279(60801/98/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774280(60801/98/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774281(60801/98/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774282(60801/98/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774283(60801/98/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774284(60801/98/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774285(60801/98/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774286(60801/98/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774287(60801/98/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774288(60801/98/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774289(60801/98/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774290(60801/98/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774291(60801/98/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774292(60801/98/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774293(60801/98/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774294(60801/98/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774295(60801/98/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774296(60801/98/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774297(60801/98/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774298(60801/98/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774299(60801/98/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774300(60801/98/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774301(60801/98/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774302(60801/99/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774303(60801/99/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774304(60801/99/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774305(60801/99/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774306(60801/99/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774307(60801/99/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774308(60801/99/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774309(60801/99/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774310(60801/99/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774311(60801/99/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774312(60801/99/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774313(60801/99/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774314(60801/99/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774315(60801/99/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774316(60801/99/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774317(60801/99/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774318(60801/99/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774319(60801/99/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774320(60801/99/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774321(60801/99/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774322(60801/99/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774323(60801/99/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774324(60801/99/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774325(60801/99/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774326(60801/99/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774327(60801/99/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774328(60801/99/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774329(60801/99/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774330(60801/99/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774331(60801/99/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774332(60801/99/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774333(60801/99/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774334(60801/99/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774335(60801/99/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774336(60801/99/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774337(60801/99/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774338(60801/99/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774339(60801/99/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774340(60801/99/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774341(60801/99/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774342(60801/99/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774343(60801/99/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774344(60801/99/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774345(60801/99/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774346(60801/99/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774347(60801/99/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774348(60801/99/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774349(60801/99/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774350(60801/99/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774351(60801/99/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774352(60801/99/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774353(60801/99/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774354(60801/99/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774355(60801/99/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774356(60801/99/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774357(60801/99/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774358(60801/99/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774359(60801/99/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774360(60801/99/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774361(60801/99/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774362(60801/99/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774363(60801/99/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774364(60801/99/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774365(60801/100/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774366(60801/100/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774367(60801/100/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774368(60801/100/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774369(60801/100/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774370(60801/100/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774371(60801/100/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774372(60801/100/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774373(60801/100/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774374(60801/100/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774375(60801/100/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774376(60801/100/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774377(60801/100/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774378(60801/100/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774379(60801/100/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774380(60801/100/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774381(60801/100/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774382(60801/100/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774383(60801/100/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774384(60801/100/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774385(60801/100/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774386(60801/100/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774387(60801/100/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774388(60801/100/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774389(60801/100/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774390(60801/100/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774391(60801/100/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774392(60801/100/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774393(60801/100/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774394(60801/100/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774395(60801/100/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774396(60801/100/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774397(60801/100/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774398(60801/100/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774399(60801/100/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774400(60801/100/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774401(60801/100/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774402(60801/100/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774403(60801/100/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774404(60801/100/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774405(60801/100/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774406(60801/100/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774407(60801/100/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774408(60801/100/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774409(60801/100/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774410(60801/100/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774411(60801/100/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774412(60801/100/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774413(60801/100/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774414(60801/100/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774415(60801/100/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774416(60801/100/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774417(60801/100/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774418(60801/100/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774419(60801/100/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774420(60801/100/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774421(60801/100/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774422(60801/100/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774423(60801/100/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774424(60801/100/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774425(60801/100/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774426(60801/100/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774427(60801/100/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774428(60801/101/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774429(60801/101/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774430(60801/101/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774431(60801/101/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774432(60801/101/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774433(60801/101/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774434(60801/101/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774435(60801/101/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774436(60801/101/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774437(60801/101/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774438(60801/101/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774439(60801/101/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774440(60801/101/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774441(60801/101/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774442(60801/101/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774443(60801/101/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774444(60801/101/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774445(60801/101/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774446(60801/101/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774447(60801/101/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774448(60801/101/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774449(60801/101/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774450(60801/101/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774451(60801/101/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774452(60801/101/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774453(60801/101/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774454(60801/101/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774455(60801/101/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774456(60801/101/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774457(60801/101/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774458(60801/101/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774459(60801/101/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774460(60801/101/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774461(60801/101/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774462(60801/101/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774463(60801/101/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774464(60801/101/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774465(60801/101/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774466(60801/101/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774467(60801/101/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774468(60801/101/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774469(60801/101/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774470(60801/101/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774471(60801/101/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774472(60801/101/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774473(60801/101/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774474(60801/101/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774475(60801/101/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774476(60801/101/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774477(60801/101/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774478(60801/101/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774479(60801/101/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774480(60801/101/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774481(60801/101/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774482(60801/101/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774483(60801/101/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774484(60801/101/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774485(60801/101/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774486(60801/101/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774487(60801/101/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774488(60801/101/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774489(60801/101/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774490(60801/101/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774491(60801/102/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774492(60801/102/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774493(60801/102/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774494(60801/102/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774495(60801/102/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774496(60801/102/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774497(60801/102/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774498(60801/102/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774499(60801/102/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774500(60801/102/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774501(60801/102/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774502(60801/102/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774503(60801/102/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774504(60801/102/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774505(60801/102/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774506(60801/102/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774507(60801/102/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774508(60801/102/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774509(60801/102/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774510(60801/102/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774511(60801/102/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774512(60801/102/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774513(60801/102/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774514(60801/102/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774515(60801/102/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774516(60801/102/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774517(60801/102/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774518(60801/102/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774519(60801/102/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774520(60801/102/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774521(60801/102/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774522(60801/102/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774523(60801/102/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774524(60801/102/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774525(60801/102/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774526(60801/102/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774527(60801/102/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774528(60801/102/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774529(60801/102/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774530(60801/102/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774531(60801/102/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774532(60801/102/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774533(60801/102/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774534(60801/102/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774535(60801/102/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774536(60801/102/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774537(60801/102/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774538(60801/102/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774539(60801/102/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774540(60801/102/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774541(60801/102/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774542(60801/102/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774543(60801/102/53)) lseek err Invalid argument
Re: partition conflict
part 4:
file_pread(5,1,buffer,976774544(60801/102/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774545(60801/102/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774546(60801/102/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774547(60801/102/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774548(60801/102/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774549(60801/102/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774550(60801/102/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774551(60801/102/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774552(60801/102/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774553(60801/102/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774554(60801/103/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774555(60801/103/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774556(60801/103/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774557(60801/103/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774558(60801/103/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774559(60801/103/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774560(60801/103/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774561(60801/103/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774562(60801/103/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774563(60801/103/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774564(60801/103/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774565(60801/103/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774566(60801/103/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774567(60801/103/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774568(60801/103/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774569(60801/103/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774570(60801/103/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774571(60801/103/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774572(60801/103/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774573(60801/103/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774574(60801/103/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774575(60801/103/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774576(60801/103/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774577(60801/103/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774578(60801/103/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774579(60801/103/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774580(60801/103/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774581(60801/103/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774582(60801/103/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774583(60801/103/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774584(60801/103/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774585(60801/103/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774586(60801/103/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774587(60801/103/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774588(60801/103/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774589(60801/103/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774590(60801/103/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774591(60801/103/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774592(60801/103/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774593(60801/103/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774594(60801/103/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774595(60801/103/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774596(60801/103/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774597(60801/103/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774598(60801/103/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774599(60801/103/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774600(60801/103/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774601(60801/103/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774602(60801/103/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774603(60801/103/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774604(60801/103/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774605(60801/103/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774606(60801/103/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774607(60801/103/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774608(60801/103/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774609(60801/103/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774610(60801/103/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774611(60801/103/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774612(60801/103/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774613(60801/103/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774614(60801/103/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774615(60801/103/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774616(60801/103/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774617(60801/104/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774618(60801/104/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774619(60801/104/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774620(60801/104/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774621(60801/104/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774622(60801/104/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774623(60801/104/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774624(60801/104/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774625(60801/104/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774626(60801/104/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774627(60801/104/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774628(60801/104/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774629(60801/104/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774630(60801/104/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774631(60801/104/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774632(60801/104/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774633(60801/104/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774634(60801/104/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774635(60801/104/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774636(60801/104/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774637(60801/104/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774638(60801/104/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774639(60801/104/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774640(60801/104/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774641(60801/104/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774642(60801/104/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774643(60801/104/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774644(60801/104/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774645(60801/104/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774646(60801/104/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774647(60801/104/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774648(60801/104/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774649(60801/104/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774650(60801/104/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774651(60801/104/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774652(60801/104/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774653(60801/104/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774654(60801/104/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774655(60801/104/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774656(60801/104/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774657(60801/104/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774658(60801/104/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774659(60801/104/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774660(60801/104/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774661(60801/104/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774662(60801/104/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774663(60801/104/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774664(60801/104/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774665(60801/104/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774666(60801/104/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774667(60801/104/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774668(60801/104/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774669(60801/104/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774670(60801/104/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774671(60801/104/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774672(60801/104/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774673(60801/104/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774674(60801/104/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774675(60801/104/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774676(60801/104/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774677(60801/104/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774678(60801/104/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774679(60801/104/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774680(60801/105/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774681(60801/105/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774682(60801/105/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774683(60801/105/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774684(60801/105/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774685(60801/105/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774686(60801/105/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774687(60801/105/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774688(60801/105/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774689(60801/105/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774690(60801/105/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774691(60801/105/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774692(60801/105/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774693(60801/105/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774694(60801/105/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774695(60801/105/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774696(60801/105/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774697(60801/105/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774698(60801/105/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774699(60801/105/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774700(60801/105/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774701(60801/105/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774702(60801/105/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774703(60801/105/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774704(60801/105/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774705(60801/105/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774706(60801/105/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774707(60801/105/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774708(60801/105/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774709(60801/105/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774710(60801/105/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774711(60801/105/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774712(60801/105/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774713(60801/105/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774714(60801/105/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774715(60801/105/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774716(60801/105/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774717(60801/105/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774718(60801/105/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774719(60801/105/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774720(60801/105/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774721(60801/105/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774722(60801/105/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774723(60801/105/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774724(60801/105/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774725(60801/105/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774726(60801/105/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774727(60801/105/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774728(60801/105/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774729(60801/105/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774730(60801/105/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774731(60801/105/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774732(60801/105/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774733(60801/105/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774734(60801/105/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774735(60801/105/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774736(60801/105/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774737(60801/105/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774738(60801/105/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774739(60801/105/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774740(60801/105/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774741(60801/105/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774742(60801/105/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774743(60801/106/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774744(60801/106/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774745(60801/106/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774746(60801/106/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774747(60801/106/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774748(60801/106/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774749(60801/106/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774750(60801/106/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774751(60801/106/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774752(60801/106/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774753(60801/106/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774754(60801/106/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774755(60801/106/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774756(60801/106/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774757(60801/106/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774758(60801/106/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774759(60801/106/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774760(60801/106/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774761(60801/106/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774762(60801/106/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774763(60801/106/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774764(60801/106/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774765(60801/106/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774766(60801/106/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774767(60801/106/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774768(60801/106/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774769(60801/106/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774770(60801/106/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774771(60801/106/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774772(60801/106/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774773(60801/106/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774774(60801/106/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774775(60801/106/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774776(60801/106/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774777(60801/106/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774778(60801/106/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774779(60801/106/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774780(60801/106/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774781(60801/106/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774782(60801/106/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774783(60801/106/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774784(60801/106/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774785(60801/106/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774786(60801/106/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774787(60801/106/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774788(60801/106/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774789(60801/106/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774790(60801/106/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774791(60801/106/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774792(60801/106/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774793(60801/106/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774794(60801/106/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774795(60801/106/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774796(60801/106/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774797(60801/106/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774798(60801/106/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774799(60801/106/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774800(60801/106/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774801(60801/106/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774802(60801/106/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774803(60801/106/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774804(60801/106/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774805(60801/106/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774806(60801/107/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774807(60801/107/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774808(60801/107/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774809(60801/107/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774810(60801/107/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774811(60801/107/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774812(60801/107/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774813(60801/107/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774814(60801/107/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774815(60801/107/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774816(60801/107/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774817(60801/107/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774818(60801/107/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774819(60801/107/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774820(60801/107/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774821(60801/107/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774822(60801/107/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774823(60801/107/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774824(60801/107/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774825(60801/107/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774826(60801/107/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774827(60801/107/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774828(60801/107/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774829(60801/107/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774830(60801/107/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774831(60801/107/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774832(60801/107/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774833(60801/107/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774834(60801/107/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774835(60801/107/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774836(60801/107/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774837(60801/107/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774838(60801/107/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774839(60801/107/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774840(60801/107/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774841(60801/107/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774842(60801/107/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774843(60801/107/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774844(60801/107/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774845(60801/107/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774846(60801/107/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774847(60801/107/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774848(60801/107/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774849(60801/107/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774850(60801/107/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774851(60801/107/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774852(60801/107/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774853(60801/107/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774854(60801/107/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774855(60801/107/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774856(60801/107/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774857(60801/107/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774858(60801/107/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774859(60801/107/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774860(60801/107/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774861(60801/107/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774862(60801/107/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774863(60801/107/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774864(60801/107/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774865(60801/107/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774866(60801/107/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774867(60801/107/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774868(60801/107/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774869(60801/108/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774870(60801/108/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774871(60801/108/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774872(60801/108/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774873(60801/108/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774874(60801/108/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774875(60801/108/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774876(60801/108/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774877(60801/108/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774878(60801/108/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774879(60801/108/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774880(60801/108/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774881(60801/108/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774882(60801/108/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774883(60801/108/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774884(60801/108/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774885(60801/108/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774886(60801/108/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774887(60801/108/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774888(60801/108/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774889(60801/108/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774890(60801/108/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774891(60801/108/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774892(60801/108/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774893(60801/108/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774894(60801/108/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774895(60801/108/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774896(60801/108/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774897(60801/108/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774898(60801/108/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774899(60801/108/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774900(60801/108/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774901(60801/108/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774902(60801/108/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774903(60801/108/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774904(60801/108/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774905(60801/108/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774906(60801/108/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774907(60801/108/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774908(60801/108/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774909(60801/108/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774910(60801/108/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774911(60801/108/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774912(60801/108/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774913(60801/108/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774914(60801/108/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774915(60801/108/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774916(60801/108/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774917(60801/108/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774918(60801/108/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774919(60801/108/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774920(60801/108/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774921(60801/108/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774922(60801/108/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774923(60801/108/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774924(60801/108/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774925(60801/108/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774926(60801/108/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774927(60801/108/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774928(60801/108/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774929(60801/108/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774930(60801/108/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774931(60801/108/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774932(60801/109/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774933(60801/109/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774934(60801/109/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774935(60801/109/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774936(60801/109/5)) lseek err Invalid argument
file_pread(5,1,buffer,976774937(60801/109/6)) lseek err Invalid argument
file_pread(5,1,buffer,976774938(60801/109/7)) lseek err Invalid argument
file_pread(5,1,buffer,976774939(60801/109/8)) lseek err Invalid argument
file_pread(5,1,buffer,976774940(60801/109/9)) lseek err Invalid argument
file_pread(5,1,buffer,976774941(60801/109/10)) lseek err Invalid argument
file_pread(5,1,buffer,976774942(60801/109/11)) lseek err Invalid argument
file_pread(5,1,buffer,976774943(60801/109/12)) lseek err Invalid argument
file_pread(5,1,buffer,976774944(60801/109/13)) lseek err Invalid argument
file_pread(5,1,buffer,976774945(60801/109/14)) lseek err Invalid argument
file_pread(5,1,buffer,976774946(60801/109/15)) lseek err Invalid argument
file_pread(5,1,buffer,976774947(60801/109/16)) lseek err Invalid argument
file_pread(5,1,buffer,976774948(60801/109/17)) lseek err Invalid argument
file_pread(5,1,buffer,976774949(60801/109/18)) lseek err Invalid argument
file_pread(5,1,buffer,976774950(60801/109/19)) lseek err Invalid argument
file_pread(5,1,buffer,976774951(60801/109/20)) lseek err Invalid argument
file_pread(5,1,buffer,976774952(60801/109/21)) lseek err Invalid argument
file_pread(5,1,buffer,976774953(60801/109/22)) lseek err Invalid argument
file_pread(5,1,buffer,976774954(60801/109/23)) lseek err Invalid argument
file_pread(5,1,buffer,976774955(60801/109/24)) lseek err Invalid argument
file_pread(5,1,buffer,976774956(60801/109/25)) lseek err Invalid argument
file_pread(5,1,buffer,976774957(60801/109/26)) lseek err Invalid argument
file_pread(5,1,buffer,976774958(60801/109/27)) lseek err Invalid argument
file_pread(5,1,buffer,976774959(60801/109/28)) lseek err Invalid argument
file_pread(5,1,buffer,976774960(60801/109/29)) lseek err Invalid argument
file_pread(5,1,buffer,976774961(60801/109/30)) lseek err Invalid argument
file_pread(5,1,buffer,976774962(60801/109/31)) lseek err Invalid argument
file_pread(5,1,buffer,976774963(60801/109/32)) lseek err Invalid argument
file_pread(5,1,buffer,976774964(60801/109/33)) lseek err Invalid argument
file_pread(5,1,buffer,976774965(60801/109/34)) lseek err Invalid argument
file_pread(5,1,buffer,976774966(60801/109/35)) lseek err Invalid argument
file_pread(5,1,buffer,976774967(60801/109/36)) lseek err Invalid argument
file_pread(5,1,buffer,976774968(60801/109/37)) lseek err Invalid argument
file_pread(5,1,buffer,976774969(60801/109/38)) lseek err Invalid argument
file_pread(5,1,buffer,976774970(60801/109/39)) lseek err Invalid argument
file_pread(5,1,buffer,976774971(60801/109/40)) lseek err Invalid argument
file_pread(5,1,buffer,976774972(60801/109/41)) lseek err Invalid argument
file_pread(5,1,buffer,976774973(60801/109/42)) lseek err Invalid argument
file_pread(5,1,buffer,976774974(60801/109/43)) lseek err Invalid argument
file_pread(5,1,buffer,976774975(60801/109/44)) lseek err Invalid argument
file_pread(5,1,buffer,976774976(60801/109/45)) lseek err Invalid argument
file_pread(5,1,buffer,976774977(60801/109/46)) lseek err Invalid argument
file_pread(5,1,buffer,976774978(60801/109/47)) lseek err Invalid argument
file_pread(5,1,buffer,976774979(60801/109/48)) lseek err Invalid argument
file_pread(5,1,buffer,976774980(60801/109/49)) lseek err Invalid argument
file_pread(5,1,buffer,976774981(60801/109/50)) lseek err Invalid argument
file_pread(5,1,buffer,976774982(60801/109/51)) lseek err Invalid argument
file_pread(5,1,buffer,976774983(60801/109/52)) lseek err Invalid argument
file_pread(5,1,buffer,976774984(60801/109/53)) lseek err Invalid argument
file_pread(5,1,buffer,976774985(60801/109/54)) lseek err Invalid argument
file_pread(5,1,buffer,976774986(60801/109/55)) lseek err Invalid argument
file_pread(5,1,buffer,976774987(60801/109/56)) lseek err Invalid argument
file_pread(5,1,buffer,976774988(60801/109/57)) lseek err Invalid argument
file_pread(5,1,buffer,976774989(60801/109/58)) lseek err Invalid argument
file_pread(5,1,buffer,976774990(60801/109/59)) lseek err Invalid argument
file_pread(5,1,buffer,976774991(60801/109/60)) lseek err Invalid argument
file_pread(5,1,buffer,976774992(60801/109/61)) lseek err Invalid argument
file_pread(5,1,buffer,976774993(60801/109/62)) lseek err Invalid argument
file_pread(5,1,buffer,976774994(60801/109/63)) lseek err Invalid argument
file_pread(5,1,buffer,976774995(60801/110/1)) lseek err Invalid argument
file_pread(5,1,buffer,976774996(60801/110/2)) lseek err Invalid argument
file_pread(5,1,buffer,976774997(60801/110/3)) lseek err Invalid argument
file_pread(5,1,buffer,976774998(60801/110/4)) lseek err Invalid argument
file_pread(5,1,buffer,976774999(60801/110/5)) lseek err Invalid argument
file_pread(5,1,buffer,976775000(60801/110/6)) lseek err Invalid argument
file_pread(5,1,buffer,976775001(60801/110/7)) lseek err Invalid argument
file_pread(5,1,buffer,976775002(60801/110/8)) lseek err Invalid argument
file_pread(5,1,buffer,976775003(60801/110/9)) lseek err Invalid argument
file_pread(5,1,buffer,976775004(60801/110/10)) lseek err Invalid argument
file_pread(5,1,buffer,976775005(60801/110/11)) lseek err Invalid argument
file_pread(5,1,buffer,976775006(60801/110/12)) lseek err Invalid argument
file_pread(5,1,buffer,976775007(60801/110/13)) lseek err Invalid argument
file_pread(5,1,buffer,976775008(60801/110/14)) lseek err Invalid argument
file_pread(5,1,buffer,976775009(60801/110/15)) lseek err Invalid argument
file_pread(5,1,buffer,976775010(60801/110/16)) lseek err Invalid argument
file_pread(5,1,buffer,976775011(60801/110/17)) lseek err Invalid argument
file_pread(5,1,buffer,976775012(60801/110/18)) lseek err Invalid argument
file_pread(5,1,buffer,976775013(60801/110/19)) lseek err Invalid argument
file_pread(5,1,buffer,976775014(60801/110/20)) lseek err Invalid argument
file_pread(5,1,buffer,976775015(60801/110/21)) lseek err Invalid argument
file_pread(5,1,buffer,976775016(60801/110/22)) lseek err Invalid argument
file_pread(5,1,buffer,976775017(60801/110/23)) lseek err Invalid argument
file_pread(5,1,buffer,976775018(60801/110/24)) lseek err Invalid argument
file_pread(5,1,buffer,976775019(60801/110/25)) lseek err Invalid argument
file_pread(5,1,buffer,976775020(60801/110/26)) lseek err Invalid argument
file_pread(5,1,buffer,976775021(60801/110/27)) lseek err Invalid argument
file_pread(5,1,buffer,976775022(60801/110/28)) lseek err Invalid argument
file_pread(5,1,buffer,976775023(60801/110/29)) lseek err Invalid argument
file_pread(5,1,buffer,976775024(60801/110/30)) lseek err Invalid argument
file_pread(5,1,buffer,976775025(60801/110/31)) lseek err Invalid argument
file_pread(5,1,buffer,976775026(60801/110/32)) lseek err Invalid argument
file_pread(5,1,buffer,976775027(60801/110/33)) lseek err Invalid argument
file_pread(5,1,buffer,976775028(60801/110/34)) lseek err Invalid argument
file_pread(5,1,buffer,976775029(60801/110/35)) lseek err Invalid argument
file_pread(5,1,buffer,976775030(60801/110/36)) lseek err Invalid argument
file_pread(5,1,buffer,976775031(60801/110/37)) lseek err Invalid argument
file_pread(5,1,buffer,976775032(60801/110/38)) lseek err Invalid argument
file_pread(5,1,buffer,976775033(60801/110/39)) lseek err Invalid argument
file_pread(5,1,buffer,976775034(60801/110/40)) lseek err Invalid argument
file_pread(5,1,buffer,976775035(60801/110/41)) lseek err Invalid argument
file_pread(5,1,buffer,976775036(60801/110/42)) lseek err Invalid argument
file_pread(5,1,buffer,976775037(60801/110/43)) lseek err Invalid argument
file_pread(5,1,buffer,976775038(60801/110/44)) lseek err Invalid argument
file_pread(5,1,buffer,976775039(60801/110/45)) lseek err Invalid argument
file_pread(5,1,buffer,976775040(60801/110/46)) lseek err Invalid argument
file_pread(5,1,buffer,976775041(60801/110/47)) lseek err Invalid argument
file_pread(5,1,buffer,976775042(60801/110/48)) lseek err Invalid argument
file_pread(5,1,buffer,976775043(60801/110/49)) lseek err Invalid argument
file_pread(5,1,buffer,976775044(60801/110/50)) lseek err Invalid argument
file_pread(5,1,buffer,976775045(60801/110/51)) lseek err Invalid argument
file_pread(5,1,buffer,976775046(60801/110/52)) lseek err Invalid argument
file_pread(5,1,buffer,976775047(60801/110/53)) lseek err Invalid argument
file_pread(5,1,buffer,976775048(60801/110/54)) lseek err Invalid argument
file_pread(5,1,buffer,976775049(60801/110/55)) lseek err Invalid argument
file_pread(5,1,buffer,976775050(60801/110/56)) lseek err Invalid argument
file_pread(5,1,buffer,976775051(60801/110/57)) lseek err Invalid argument
file_pread(5,1,buffer,976775052(60801/110/58)) lseek err Invalid argument
file_pread(5,1,buffer,976775053(60801/110/59)) lseek err Invalid argument
file_pread(5,1,buffer,976775054(60801/110/60)) lseek err Invalid argument
file_pread(5,1,buffer,976775055(60801/110/61)) lseek err Invalid argument
file_pread(5,1,buffer,976775056(60801/110/62)) lseek err Invalid argument
file_pread(5,1,buffer,976775057(60801/110/63)) lseek err Invalid argument
file_pread(5,1,buffer,976775058(60801/111/1)) lseek err Invalid argument
file_pread(5,1,buffer,976775059(60801/111/2)) lseek err Invalid argument
file_pread(5,1,buffer,976775060(60801/111/3)) lseek err Invalid argument
file_pread(5,1,buffer,976775061(60801/111/4)) lseek err Invalid argument
file_pread(5,1,buffer,976775062(60801/111/5)) lseek err Invalid argument
file_pread(5,1,buffer,976775063(60801/111/6)) lseek err Invalid argument
file_pread(5,1,buffer,976775064(60801/111/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773152(60801/80/48)) ReadFile ??????????????????
file_pread(5,1,buffer,976775065(60801/111/8)) lseek err Invalid argument
file_pread(5,1,buffer,976773153(60801/80/49)) lseek err Invalid argument
file_pread(5,1,buffer,976775066(60801/111/9)) lseek err Invalid argument
file_pread(5,1,buffer,976775067(60801/111/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773155(60801/80/51)) lseek err Invalid argument
file_pread(5,1,buffer,976775068(60801/111/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773156(60801/80/52)) lseek err Invalid argument
file_pread(5,1,buffer,976775069(60801/111/12)) lseek err Invalid argument
file_pread(5,1,buffer,976773157(60801/80/53)) lseek err Invalid argument
file_pread(5,1,buffer,976775070(60801/111/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773158(60801/80/54)) lseek err Invalid argument
file_pread(5,1,buffer,976775071(60801/111/14)) lseek err Invalid argument
file_pread(5,1,buffer,976773159(60801/80/55)) lseek err Invalid argument
file_pread(5,1,buffer,976775072(60801/111/15)) lseek err Invalid argument
file_pread(5,1,buffer,976775073(60801/111/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773161(60801/80/57)) lseek err Invalid argument
file_pread(5,1,buffer,976775074(60801/111/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773162(60801/80/58)) lseek err Invalid argument
file_pread(5,1,buffer,976775075(60801/111/18)) lseek err Invalid argument
file_pread(5,1,buffer,976773163(60801/80/59)) lseek err Invalid argument
file_pread(5,1,buffer,976775076(60801/111/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773164(60801/80/60)) lseek err Invalid argument
file_pread(5,1,buffer,976775077(60801/111/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773165(60801/80/61)) lseek err Invalid argument
file_pread(5,1,buffer,976775078(60801/111/21)) lseek err Invalid argument
file_pread(5,11,buffer,976773156(60801/80/52)) lseek err Invalid argument
file_pread(5,1,buffer,976775079(60801/111/22)) lseek err Invalid argument
file_pread(5,1,buffer,976773167(60801/80/63)) lseek err Invalid argument
file_pread(5,1,buffer,976775080(60801/111/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773168(60801/81/1)) lseek err Invalid argument
file_pread(5,1,buffer,976775081(60801/111/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773169(60801/81/2)) lseek err Invalid argument
file_pread(5,1,buffer,976775082(60801/111/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773170(60801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,976775083(60801/111/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773171(60801/81/4)) lseek err Invalid argument
file_pread(5,1,buffer,976775084(60801/111/27)) lseek err Invalid argument
file_pread(5,11,buffer,976773162(60801/80/58)) lseek err Invalid argument
file_pread(5,1,buffer,976775085(60801/111/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773173(60801/81/6)) lseek err Invalid argument
file_pread(5,1,buffer,976775086(60801/111/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773174(60801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,976775087(60801/111/30)) lseek err Invalid argument
file_pread(5,1,buffer,976773175(60801/81/8)) lseek err Invalid argument
file_pread(5,1,buffer,976775088(60801/111/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773176(60801/81/9)) lseek err Invalid argument
file_pread(5,1,buffer,976775089(60801/111/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773177(60801/81/10)) lseek err Invalid argument
file_pread(5,1,buffer,976775090(60801/111/33)) lseek err Invalid argument
file_pread(5,11,buffer,976773168(60801/81/1)) lseek err Invalid argument
file_pread(5,1,buffer,976775091(60801/111/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773179(60801/81/12)) lseek err Invalid argument
file_pread(5,1,buffer,976775092(60801/111/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773180(60801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,976775093(60801/111/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773181(60801/81/14)) lseek err Invalid argument
file_pread(5,1,buffer,976775094(60801/111/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,976775095(60801/111/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(5,1,buffer,976775096(60801/111/39)) lseek err Invalid argument
file_pread(5,11,buffer,976773174(60801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,976775097(60801/111/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773185(60801/81/18)) lseek err Invalid argument
file_pread(5,1,buffer,976775098(60801/111/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773186(60801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,976775099(60801/111/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773187(60801/81/20)) lseek err Invalid argument
file_pread(5,1,buffer,976775100(60801/111/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773188(60801/81/21)) lseek err Invalid argument
file_pread(5,1,buffer,976775101(60801/111/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773189(60801/81/22)) lseek err Invalid argument
file_pread(5,1,buffer,976775102(60801/111/45)) lseek err Invalid argument
file_pread(5,11,buffer,976773180(60801/81/13)) lseek err Invalid argument
file_pread(5,1,buffer,976775103(60801/111/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773191(60801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,976775104(60801/111/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773192(60801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,976775105(60801/111/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773193(60801/81/26)) lseek err Invalid argument
file_pread(5,1,buffer,976775106(60801/111/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773194(60801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,976775107(60801/111/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773195(60801/81/28)) lseek err Invalid argument
file_pread(5,1,buffer,976775108(60801/111/51)) lseek err Invalid argument
file_pread(5,11,buffer,976773186(60801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,976775109(60801/111/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773197(60801/81/30)) lseek err Invalid argument
file_pread(5,1,buffer,976775110(60801/111/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773198(60801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,976775111(60801/111/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(5,1,buffer,976775112(60801/111/55)) lseek err Invalid argument
file_pread(5,11,buffer,976773190(60801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773190(60801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,976775113(60801/111/56)) lseek err Invalid argument
file_pread(5,11,buffer,976773191(60801/81/24)) lseek err Invalid argument
file_pread(5,1,buffer,976775114(60801/111/57)) lseek err Invalid argument
file_pread(5,11,buffer,976773192(60801/81/25)) lseek err Invalid argument
file_pread(5,1,buffer,976775115(60801/111/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773203(60801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,976775116(60801/111/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773154(60801/80/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773204(60801/81/37)) lseek err Invalid argument
file_pread(5,1,buffer,976775117(60801/111/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773205(60801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,976775118(60801/111/61)) lseek err Invalid argument
file_pread(5,11,buffer,976773196(60801/81/29)) lseek err Invalid argument
file_pread(5,1,buffer,976775119(60801/111/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773207(60801/81/40)) lseek err Invalid argument
file_pread(5,1,buffer,976775120(60801/111/63)) lseek err Invalid argument
file_pread(5,1,buffer,976773208(60801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,976775121(60801/112/1)) lseek err Invalid argument
file_pread(5,8,buffer,976773152(60801/80/48)) ReadFile ??????????????????
file_pread(5,1,buffer,976773209(60801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,976775122(60801/112/2)) lseek err Invalid argument
file_pread(5,8,buffer,976773153(60801/80/49)) lseek err Invalid argument
file_pread(5,11,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,1,buffer,976775123(60801/112/3)) lseek err Invalid argument
file_pread(5,8,buffer,976773154(60801/80/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773211(60801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,976775124(60801/112/4)) lseek err Invalid argument
file_pread(5,8,buffer,976773155(60801/80/51)) lseek err Invalid argument
file_pread(5,1,buffer,976773212(60801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,976775125(60801/112/5)) lseek err Invalid argument
file_pread(5,8,buffer,976773156(60801/80/52)) lseek err Invalid argument
file_pread(5,11,buffer,976773203(60801/81/36)) lseek err Invalid argument
file_pread(5,1,buffer,976775126(60801/112/6)) lseek err Invalid argument
file_pread(5,8,buffer,976773157(60801/80/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773214(60801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,976775127(60801/112/7)) lseek err Invalid argument
file_pread(5,8,buffer,976773158(60801/80/54)) lseek err Invalid argument
file_pread(5,1,buffer,976773215(60801/81/48)) lseek err Invalid argument
file_pread(5,1,buffer,976775128(60801/112/8)) lseek err Invalid argument
file_pread(5,8,buffer,976773159(60801/80/55)) lseek err Invalid argument
file_pread(5,11,buffer,976773206(60801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,976775129(60801/112/9)) lseek err Invalid argument
file_pread(5,8,buffer,976773160(60801/80/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773160(60801/80/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773217(60801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,976775130(60801/112/10)) lseek err Invalid argument
file_pread(5,8,buffer,976773161(60801/80/57)) lseek err Invalid argument
file_pread(5,1,buffer,976773218(60801/81/51)) lseek err Invalid argument
file_pread(5,1,buffer,976775131(60801/112/11)) lseek err Invalid argument
file_pread(5,8,buffer,976773162(60801/80/58)) lseek err Invalid argument
file_pread(5,11,buffer,976773209(60801/81/42)) lseek err Invalid argument
file_pread(5,1,buffer,976775132(60801/112/12)) lseek err Invalid argument
and part 5:
file_pread(5,8,buffer,976773163(60801/80/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773220(60801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,976775133(60801/112/13)) lseek err Invalid argument
file_pread(5,8,buffer,976773164(60801/80/60)) lseek err Invalid argument
file_pread(5,1,buffer,976773221(60801/81/54)) lseek err Invalid argument
file_pread(5,1,buffer,976775134(60801/112/14)) lseek err Invalid argument
file_pread(5,8,buffer,976773165(60801/80/61)) lseek err Invalid argument
file_pread(5,11,buffer,976773212(60801/81/45)) lseek err Invalid argument
file_pread(5,1,buffer,976775135(60801/112/15)) lseek err Invalid argument
file_pread(5,8,buffer,976773166(60801/80/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773223(60801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,976775136(60801/112/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773224(60801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,976775137(60801/112/17)) lseek err Invalid argument
file_pread(5,1,buffer,976773225(60801/81/58)) lseek err Invalid argument
file_pread(5,1,buffer,976775138(60801/112/18)) lseek err Invalid argument
file_pread(5,11,buffer,976773216(60801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,976775139(60801/112/19)) lseek err Invalid argument
file_pread(5,8,buffer,976773170(60801/81/3)) lseek err Invalid argument
file_pread(5,1,buffer,976773227(60801/81/60)) lseek err Invalid argument
file_pread(5,1,buffer,976775140(60801/112/20)) lseek err Invalid argument
file_pread(5,1,buffer,976773178(60801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773228(60801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,976775141(60801/112/21)) lseek err Invalid argument
file_pread(5,1,buffer,976773229(60801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,976775142(60801/112/22)) lseek err Invalid argument
file_pread(5,11,buffer,976773220(60801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,976775143(60801/112/23)) lseek err Invalid argument
file_pread(5,8,buffer,976773174(60801/81/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773231(60801/82/1)) lseek err Invalid argument
file_pread(5,1,buffer,976775144(60801/112/24)) lseek err Invalid argument
file_pread(5,1,buffer,976773232(60801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,976775145(60801/112/25)) lseek err Invalid argument
file_pread(5,1,buffer,976773233(60801/82/3)) lseek err Invalid argument
file_pread(5,1,buffer,976775146(60801/112/26)) lseek err Invalid argument
file_pread(5,1,buffer,976773184(60801/81/17)) lseek err Invalid argument
file_pread(5,11,buffer,976773224(60801/81/57)) lseek err Invalid argument
file_pread(5,1,buffer,976775147(60801/112/27)) lseek err Invalid argument
file_pread(5,8,buffer,976773178(60801/81/11)) lseek err Invalid argument
file_pread(5,1,buffer,976773235(60801/82/5)) lseek err Invalid argument
file_pread(5,1,buffer,976775148(60801/112/28)) lseek err Invalid argument
file_pread(5,1,buffer,976773236(60801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,976775149(60801/112/29)) lseek err Invalid argument
file_pread(5,1,buffer,976773166(60801/80/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773237(60801/82/7)) lseek err Invalid argument
file_pread(5,1,buffer,976775150(60801/112/30)) lseek err Invalid argument
file_pread(5,11,buffer,976773228(60801/81/61)) lseek err Invalid argument
file_pread(5,1,buffer,976775151(60801/112/31)) lseek err Invalid argument
file_pread(5,8,buffer,976773182(60801/81/15)) lseek err Invalid argument
file_pread(5,1,buffer,976773239(60801/82/9)) lseek err Invalid argument
file_pread(5,1,buffer,976775152(60801/112/32)) lseek err Invalid argument
file_pread(5,1,buffer,976773240(60801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,976775153(60801/112/33)) lseek err Invalid argument
file_pread(5,1,buffer,976773241(60801/82/11)) lseek err Invalid argument
file_pread(5,1,buffer,976775154(60801/112/34)) lseek err Invalid argument
file_pread(5,11,buffer,976773232(60801/82/2)) lseek err Invalid argument
file_pread(5,1,buffer,976775155(60801/112/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773172(60801/81/5)) lseek err Invalid argument
file_pread(5,8,buffer,976773186(60801/81/19)) lseek err Invalid argument
file_pread(5,1,buffer,976773243(60801/82/13)) lseek err Invalid argument
file_pread(5,1,buffer,976775156(60801/112/36)) lseek err Invalid argument
file_pread(5,1,buffer,976773244(60801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,976775157(60801/112/37)) lseek err Invalid argument
file_pread(5,1,buffer,976773245(60801/82/15)) lseek err Invalid argument
file_pread(5,1,buffer,976775158(60801/112/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773196(60801/81/29)) lseek err Invalid argument
file_pread(5,11,buffer,976773236(60801/82/6)) lseek err Invalid argument
file_pread(5,1,buffer,976775159(60801/112/39)) lseek err Invalid argument
file_pread(5,8,buffer,976773190(60801/81/23)) lseek err Invalid argument
file_pread(5,1,buffer,976773247(60801/82/17)) lseek err Invalid argument
file_pread(5,1,buffer,976775160(60801/112/40)) lseek err Invalid argument
file_pread(5,1,buffer,976773248(60801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,976775161(60801/112/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773249(60801/82/19)) lseek err Invalid argument
file_pread(5,1,buffer,976775162(60801/112/42)) lseek err Invalid argument
file_pread(5,1,buffer,976773200(60801/81/33)) lseek err Invalid argument
file_pread(5,11,buffer,976773240(60801/82/10)) lseek err Invalid argument
file_pread(5,1,buffer,976775163(60801/112/43)) lseek err Invalid argument
file_pread(5,8,buffer,976773194(60801/81/27)) lseek err Invalid argument
file_pread(5,1,buffer,976773251(60801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,976775164(60801/112/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773202(60801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773252(60801/82/22)) lseek err Invalid argument
file_pread(5,1,buffer,976775165(60801/112/45)) lseek err Invalid argument
file_pread(5,1,buffer,976773253(60801/82/23)) lseek err Invalid argument
file_pread(5,1,buffer,976775166(60801/112/46)) lseek err Invalid argument
file_pread(5,11,buffer,976773244(60801/82/14)) lseek err Invalid argument
file_pread(5,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(5,8,buffer,976773198(60801/81/31)) lseek err Invalid argument
file_pread(5,1,buffer,976773255(60801/82/25)) lseek err Invalid argument
file_pread(5,1,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(5,1,buffer,976773206(60801/81/39)) lseek err Invalid argument
file_pread(5,1,buffer,976773256(60801/82/26)) lseek err Invalid argument
file_pread(5,1,buffer,976775169(60801/112/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773257(60801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(5,11,buffer,976773248(60801/82/18)) lseek err Invalid argument
file_pread(5,1,buffer,976775171(60801/112/51)) lseek err Invalid argument
file_pread(5,8,buffer,976773202(60801/81/35)) lseek err Invalid argument
file_pread(5,1,buffer,976773259(60801/82/29)) lseek err Invalid argument
file_pread(5,1,buffer,976775172(60801/112/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773210(60801/81/43)) lseek err Invalid argument
file_pread(5,1,buffer,976773260(60801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,976775173(60801/112/53)) lseek err Invalid argument
file_pread(5,11,buffer,976773251(60801/82/21)) lseek err Invalid argument
file_pread(5,1,buffer,976775174(60801/112/54)) lseek err Invalid argument
file_pread(5,8,buffer,976773205(60801/81/38)) lseek err Invalid argument
file_pread(5,1,buffer,976773262(60801/82/32)) lseek err Invalid argument
file_pread(5,1,buffer,976775175(60801/112/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773213(60801/81/46)) lseek err Invalid argument
file_pread(5,1,buffer,976773263(60801/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,976775176(60801/112/56)) lseek err Invalid argument
file_pread(5,11,buffer,976773254(60801/82/24)) lseek err Invalid argument
file_pread(5,1,buffer,976775177(60801/112/57)) lseek err Invalid argument
file_pread(5,8,buffer,976773208(60801/81/41)) lseek err Invalid argument
file_pread(5,1,buffer,976773265(60801/82/35)) lseek err Invalid argument
file_pread(5,1,buffer,976775178(60801/112/58)) lseek err Invalid argument
file_pread(5,1,buffer,976773216(60801/81/49)) lseek err Invalid argument
file_pread(5,1,buffer,976773266(60801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,976775179(60801/112/59)) lseek err Invalid argument
file_pread(5,11,buffer,976773257(60801/82/27)) lseek err Invalid argument
file_pread(5,1,buffer,976775180(60801/112/60)) lseek err Invalid argument
file_pread(5,8,buffer,976773211(60801/81/44)) lseek err Invalid argument
file_pread(5,1,buffer,976773268(60801/82/38)) lseek err Invalid argument
file_pread(5,1,buffer,976775181(60801/112/61)) lseek err Invalid argument
file_pread(5,1,buffer,976773219(60801/81/52)) lseek err Invalid argument
file_pread(5,1,buffer,976773269(60801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,976775182(60801/112/62)) lseek err Invalid argument
file_pread(5,11,buffer,976773260(60801/82/30)) lseek err Invalid argument
file_pread(5,1,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(5,8,buffer,976773214(60801/81/47)) lseek err Invalid argument
file_pread(5,1,buffer,976773271(60801/82/41)) lseek err Invalid argument
file_pread(5,1,buffer,976775184(60801/113/1)) lseek err Invalid argument
file_pread(5,1,buffer,976773201(60801/81/34)) lseek err Invalid argument
file_pread(5,1,buffer,976773222(60801/81/55)) lseek err Invalid argument
file_pread(5,1,buffer,976773272(60801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,976775185(60801/113/2)) lseek err Invalid argument
file_pread(5,11,buffer,976773263(60801/82/33)) lseek err Invalid argument
file_pread(5,1,buffer,976775186(60801/113/3)) lseek err Invalid argument
file_pread(5,8,buffer,976773217(60801/81/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773274(60801/82/44)) lseek err Invalid argument
file_pread(5,1,buffer,976775187(60801/113/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773275(60801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,976775188(60801/113/5)) lseek err Invalid argument
file_pread(5,1,buffer,976773226(60801/81/59)) lseek err Invalid argument
file_pread(5,11,buffer,976773266(60801/82/36)) lseek err Invalid argument
file_pread(5,1,buffer,976775189(60801/113/6)) lseek err Invalid argument
file_pread(5,8,buffer,976773220(60801/81/53)) lseek err Invalid argument
file_pread(5,1,buffer,976773277(60801/82/47)) lseek err Invalid argument
file_pread(5,1,buffer,976775190(60801/113/7)) lseek err Invalid argument
file_pread(5,1,buffer,976773278(60801/82/48)) lseek err Invalid argument
file_pread(5,1,buffer,976775191(60801/113/8)) lseek err Invalid argument
file_pread(5,11,buffer,976773269(60801/82/39)) lseek err Invalid argument
file_pread(5,1,buffer,976775192(60801/113/9)) lseek err Invalid argument
file_pread(5,8,buffer,976773223(60801/81/56)) lseek err Invalid argument
file_pread(5,1,buffer,976773280(60801/82/50)) lseek err Invalid argument
file_pread(5,1,buffer,976775193(60801/113/10)) lseek err Invalid argument
file_pread(5,1,buffer,976773281(60801/82/51)) lseek err Invalid argument
file_pread(5,1,buffer,976775194(60801/113/11)) lseek err Invalid argument
file_pread(5,11,buffer,976773272(60801/82/42)) lseek err Invalid argument
file_pread(5,1,buffer,976775195(60801/113/12)) lseek err Invalid argument
file_pread(5,8,buffer,976773226(60801/81/59)) lseek err Invalid argument
file_pread(5,1,buffer,976773283(60801/82/53)) lseek err Invalid argument
file_pread(5,1,buffer,976775196(60801/113/13)) lseek err Invalid argument
file_pread(5,1,buffer,976773234(60801/82/4)) lseek err Invalid argument
file_pread(5,1,buffer,976773284(60801/82/54)) lseek err Invalid argument
file_pread(5,1,buffer,976775197(60801/113/14)) lseek err Invalid argument
file_pread(5,11,buffer,976773275(60801/82/45)) lseek err Invalid argument
file_pread(5,1,buffer,976775198(60801/113/15)) lseek err Invalid argument
file_pread(5,8,buffer,976773229(60801/81/62)) lseek err Invalid argument
file_pread(5,1,buffer,976773286(60801/82/56)) lseek err Invalid argument
file_pread(5,1,buffer,976775199(60801/113/16)) lseek err Invalid argument
file_pread(5,1,buffer,976773287(60801/82/57)) lseek err Invalid argument
file_pread(5,1,buffer,976775200(60801/113/17)) lseek err Invalid argument
file_pread(5,14,buffer,976773154(60801/80/50)) lseek err Invalid argument
file_pread(5,1,buffer,976773238(60801/82/8)) lseek err Invalid argument
file_pread(5,11,buffer,976773278(60801/82/48)) lseek err Invalid argument
file_pread(5,1,buffer,976775201(60801/113/18)) lseek err Invalid argument
The harddisk (500 GB / 465 GiB) seems too small! (< 717 GB / 668 GiB)
MS Data 934807551 1402212350 467404800
NTFS, blocksize=4096, 239 GB / 222 GiB
MS Data 2048 385482751 385480704
NTFS, blocksize=4096, 197 GB / 183 GiB
MS Data 2048 467402751 467400704
NTFS found using backup sector, blocksize=4096, 239 GB / 222 GiB
MS Data 467402751 934803454 467400704
MS Data 467402752 934807551 467404800
MS Data 892844033 934807552 41963520
NTFS found using backup sector, blocksize=4096, 21 GB / 20 GiB
MS Data 934807552 976771071 41963520
NTFS, blocksize=4096, 21 GB / 20 GiB
Re: partition conflict
After running that, I followed the software's guidance.  Here is a copy of the screens showing what I did. Currently, it's running a deeper search.
TestDisk 7.1-WIP, Data Recovery Utility, January 2016
[ Continue ]
>D MS Data 2048 385482751 385480704
D MS Data 2048 467402751 467400704
D MS Data 467402751 934803454 467400704
D MS Data 467402752 934807551 467404800
D MS Data 892844033 934807552 41963520
D MS Data 934807552 976771071 41963520
P=Primary D=Deleted
Enter: to continue
[ Quit ] >[Deeper Search]
Try to find more partitions
[ Continue ]
P=Primary D=Deleted
Enter: to continue
Did you select each partition and were you pressing p to have a try to list your files?
It's very important to locate your partitions which contain your data.
Here is the screen that I was in when I began the search.  At this point, I hit the enter button (Quick Search was highlighted).  I didn't hit P.  I'm sorry, but can you tell me what screen I should be in to do that?
1 P MS Data 2048 385482751 385480704 [Basic data partitio 2 P MS Data 467402752 934807551 467404800 [Basic data partitio 3 P Unknown 934807552 976771071 41963520 [Basic data partition]
P=Primary D=Deleted
>[Quick Search] [ Backup ]
Try to locate partition
P=Primary D=Deleted
