Disk not readable after Swapping
Heuchi95
#1 Post by Heuchi95 »
I build myself a new PC and used the HDD's from my old one, so long everything worked except one drive which contains the backup of my old C drive :oops:
I tried analyzing it with Testdisk and after I got the
warning: number of heads/cylinders 240 (NTFS) != 255 (HD)
while scanning I'm now at the state where its telling me the harddisk is to small. I tried listing the files of the found partition but they won't show.
This is the current state of TestDisk
Any ideas what to do next?
Re: Disk not readable after Swapping
Can you copy and paste the testdisk.log file content ?
Heuchi95
#3 Post by Heuchi95 »
Fri Jan 08 16:40:14 2016
OS: Windows 8 (9200)
Compiler: GCC 4.9, MinGW 3.11
ext2fs lib: none, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20120504, curses lib: pdcurses build  3401
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=63496519680
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=375703732224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=624497262592
Disk \\.\PhysicalDrive0 - 64 GB / 59 GiB - CHS 124053 16 63, sector size=512
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Drive C: - 63 GB / 59 GiB - CHS 123032 16 63, sector size=512
Drive H: - 375 GB / 349 GiB - CHS 45676 255 63, sector size=512
Drive I: - 624 GB / 581 GiB - CHS 75924 255 63, sector size=512
Analyse Disk \\.\PhysicalDrive2 - 500 GB / 465 GiB - CHS 60801 255 63
Geometry from i386 MBR: head=240 sector=63
check_part_i386 1 type 42: no test
 1 P W2K Dynamic/SFS          0   1  1 60801  48 31  976771057
NTFS at 31870/166/41
heads/cylinder 240 (NTFS) != 255 (HD)
filesystem size           976766976
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     HPFS - NTFS          31870 166 41 92671 149 22  976766976
This partition ends after the disk limits. (start=512002048, size=976766976, end=1488769023, disk end=976773168)
The harddisk (500 GB / 465 GiB) seems too small! (< 762 GB / 709 GiB)
interface_load
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Here is the Log
#4 Post by Fiona »
Did you use TestDisk 64bit?
TestDisk 64bit is only intended on genuine 64bit computer like Itanium, as some features are missing.
As long as you've a normal computer and you can run 32bit programs, TestDisk 7.1WIP 32bit is recommended.
Can you in case repeat your diagnose and under disk selection, can you select Disk /dev/sd* (*= a, b, c, etc..) instead of your PhysicalDrive and copy and paste the content of your log again?
Currently your disk is diplayed as dynamically and testdisk can convert it back to Intel MBR.
Run another diagnose through Analyse, Quick Search and if your partition is not found Deeper Search also.
Heuchi95
#5 Post by Heuchi95 »
Ok, I used the 7.0 32 Bit version and it found the partition through deeper search. I'm now where I was before.
What should be the next move?
Here is the Log:
Mon Jan 11 12:24:56 2016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=64023257088
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sde)=2002780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive4)=2002780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000204845056
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2002780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=1000200994816
Disk /dev/sda - 64 GB / 59 GiB - CHS 124053 16 63, sector size=512
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512
Disk /dev/sdd - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk /dev/sde - 2002 MB / 1910 MiB - CHS 243 255 63, sector size=512
Drive E: - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive I: - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
mftmirr_lcn               2
file_pread(6,3,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(6,1,buffer,976773183(60801/81/16)) lseek err Invalid argument
file_pread(6,8,buffer,976773199(60801/81/32)) lseek err Invalid argument
file_pread(6,11,buffer,976773246(60801/82/16)) lseek err Invalid argument
file_pread(6,2,buffer,976775168(60801/112/48)) lseek err Invalid argument
file_pread(6,1,buffer,976775167(60801/112/47)) lseek err Invalid argument
file_pread(6,13,buffer,976775170(60801/112/50)) lseek err Invalid argument
file_pread(6,3,buffer,976775183(60801/112/63)) lseek err Invalid argument
file_pread(6,3,buffer,976775230(60801/113/47)) lseek err Invalid argument
file_pread(6,8,buffer,976775246(60801/113/63)) lseek err Invalid argument
file_pread(6,11,buffer,976775293(60801/114/47)) lseek err Invalid argument
file_pread(6,2,buffer,976777215(60801/145/16)) lseek err Invalid argument
