Search for just "1" ext.
ducklip
#1 Post by ducklip »
Hello, is is possible to search for only "1" ext. at a time in Photorec - Is there away to opt out of the ones you don't want searched?
Thank you,
ducklip :D
ducklip
Re: Search for just "1" ext.
#2 Post by ducklip »
Hello, the reason I ask this strange question is because I have many ".flv" that I would like photorec to concentrate on while ignoring all other extensions. Is that possible to do?
Thank you for your help and guidance,
ducklip, :D
I just read that the ones you don't want searched you can uncheck them, so I will try that - :mrgreen:
