Unable to find files on windows after use “live CD” Photorec Topic is solved
raviv
#1 Post by raviv »
I have dropped my laptop accidentally. Its OS is Windows. So I try to learn how to restore the data - I took its damaged hdd(1), and connect it to my computer which has a normal hdd(2) with Win7 (x64 processor), and external hdd(3) with no OS (simply NTFS hdd). Then, when I tried to start my computer, it's been stuck (because of the damaged hdd(1)).
I burned the "Ultimate Boot CD", which contain the program "Photorec" version 7. I define in BIOS to boot the computer with CD, so the CD is starting firstly.
When Photorec is start (on "Ultimate Boot CD"), a Linux OS is loaded to RAM and under this OS the Photorec is working. I execute all the levels according to the Photorec "step-by-step" guide. I defined the external hdd(3) to be the place the whole data will be restored to. and it's work - I can see the images from the damaged hdd(1).
The problem is comming after that: when turning off the computer and disconnecting the damaged hdd(1) to allow the computer to work as regular, while running my win7, I can't see the restored data and images in the external hdd(3). moreover, when connecting the damaged hdd(1) again and start the "Ultimate Boot CD", I found that the data had gone. seems like never restored anything (I guess it's because the linux was exist on the RAM, not in hdd...) So, what should I do? how can I get the files (that I saw them under the linux on restoring) in extrnal hdd(3) while operating the win7 and keep it forever and not just temporary?
Thanks for your help.
Re: Unable to find files on windows after use “live CD” Phot
Double-check that the external disk is mounted as read-write using the "mount" command in a terminal...
raviv
#3 Post by raviv »
Thanks! I really missed it...
