Hello
the other day i installed new cooler for VGA and my 2nd disk is from then recognized as RAW disk 33mb big(should be 1TB) and only 1 partition is seen, and to use that partition it must be formated
i tried some software to recover lost data/partitions but it only sees that one partition, but where are the other 6 gone? I need to recover all those partitions with all the data that was on them...
Can you help me please?
RAW disk; only 1 partition of 6 seen... Topic is solved
Re: RAW disk; only 1 partition of 6 seen...
Probably DCO corruption. Check here :
http://forum.cgsecurity.org/phpBB3/post ... size#p2106
Hello...
Thank you for your fast reply
I installed the program you recommended and when i start it it says "Error opening driver" and all I can see master and slave channels 0 bytes big but no drives
I have Windows 7 64bit
EDIT: Should I update my BIOS and delete all the SATA and drive drivers and restart so Win7 can install it's own new drivers?
A similar case like you have would be this topic;
http://forum.cgsecurity.org/phpBB3/mism ... n-t32.html
Yes, I have read that topic but i don't know how to use hdat :/Fiona wrote:A similar case like you have would be this topic;
I tried the other thing and i have written it in post above what message i get....
I'm gonna update my bios and then try that program again
Do You need my info's from TestDisk? and can you please answer whether i have to delete my sata and drive drivers and install new ones?
I ttried plugging this disk to other PC and the same thing happens...
EDIT: My problem disk is Western digital cavier green 1TB aka WD10EARX and Motherboard: Gigabyte P35C-DS3R
An easy way to use hdat2 would be;
Connect your disk internally.
Create a hdat2-boot cd and boot from.
For you is only one thing interesting.
It's SetMAX to have a try to get your disk size back.
If it worked and your data are not available a TestDisk diagnose will follow.
Internally would be just in the case? in the main board like it is?Fiona wrote:An easy way to use hdat2 would be;
Please have a try to use hdat2 and setMAX.
Is your BIOS up to date?
If not, please update it!
I have a little problem that my PC wont read CD/DVD -.- I don't know if the problem is in CD/DVD ROM or something else -.- can I boot that program from an USB drive?
You must create a bootable usb drive.
You can have a look at this tool;
http://files.extremeoverclocking.com/file.php?f=197
Use the hdat2 single version.
