Broke Raid 1 after upgrade to Win10
tkaldridge
I recently upgraded to Win10. I have four hard drives with two Raid 1. My OS is not on the Raid drives. I recovered back Win7 but all of my data is still gone. I used PhotoRec to recover hundred of gigs of raw pictures but would like to fix the hard drive. I ran testdisk and deep scan. Nothing was found. I tried drive and physical drive. Nothing. The only information testdisk shows is four lines with *Sys= and different numbers. I will add to post the specifics in a few hours. Any suggestions?
Re: Broke Raid 1 after upgrade to Win10
please copy/paste the testdisk.log file content
tkaldridge
Mon Jan 25 17:53:01 2016
Compiler: GCC 4.9, MinGW 3.11
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=2000381018112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=128035676160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive6)=15931539456
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255953559552
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=2000377872384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=128033226752
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=1000202657792
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=15927345152
Disk \\.\PhysicalDrive0 - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Disk \\.\PhysicalDrive1 - 2000 GB / 1863 GiB - CHS 243199 255 63, sector size=512
Disk \\.\PhysicalDrive2 - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512
Disk \\.\PhysicalDrive3 - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Disk \\.\PhysicalDrive6 - 15 GB / 14 GiB - CHS 1936 255 63, sector size=512
Drive C: - 255 GB / 238 GiB - CHS 31117 255 63, sector size=512
Drive E: - 2000 GB / 1862 GiB - CHS 243198 255 63, sector size=512
Drive F: - 128 GB / 119 GiB - CHS 15565 255 63, sector size=512
Drive G: - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512
Drive I: - 15 GB / 14 GiB - CHS 1936 255 63, sector size=512
Partition table type: None
P Unknown 0 0 1 243199 35 36 3906994176
NTFS at 0/32/33
1 * HPFS - NTFS 0 32 33 243198 225 35 3906988032
NTFS, blocksize=4096, 2000 GB / 1862 GiB
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
filesystem size 3906988032
mftmirr_lcn 2
Status: OK
Status: OK
Sectors are identical.
NTFS at 0/32/33
ntfs_boot_sector
NTFS at 0/32/33
NTFS at 0/32/33
mftmirr_lcn 2
Status: OK
Status: OK
tkaldridge
From PhotoRec,
Disk \\.\PhysicalDrive6 - 2000 GB / 1863 GiB (RO)
No partition 0 0 1 243201 80 63 3907029168 [Whole disk]
1 P HPFS - NTFS 0 32 33 243198 225 35 3906988032
NTFS Volume is dirty.
ntfs_remove_used_space
4 first-level signatures enabled
blocksize=4096, offset=0
