USB drive issue
stefanhp
USB drive issue
#1 Post by stefanhp »
I have a 16GB USB flash drive (FAT) that has a missing partition table. Unfortunately I'm not able to write back the corrected table, probably a hardware defect of the flash memory at this location.
Is there a way to temporarily mount the partition on OS X to recover the data ?
Thanks
Re: USB drive issue
Try PhotoRec. Does it work ?
stefanhp
Re: USB drive issue
#3 Post by stefanhp »
Actually I used the copy feature from TestDisk (see topic How to save a partition from a drive to file) and was able to recover all data.
