TestDisk recovery on Asus Zenbook, strange scan results.
mdamusicgroup
#1 Post by mdamusicgroup »
I have an Asus Zenbook which was only booting into the bios, It was dropped and I believe the SSD may have come loose from the fixing.
I made a bootable USB but none of the windows repair options would work (I got messages saying the drive is locked). After some research I decided to plug the drive into my desktop machine and run test disk to try to fix the issue. I already performed data recovery and my files are there but they all come back in small parts/non named/mixed up so its not really that useful. I'm hoping to be able to restore the full machine with its file-system intact.
The test-disk quick analysis shows up nothing so I did the deep scan and I get the below. The first partition lists some files when I hit p, looks like some boot files, all the others say "Cant open filesystem, filesystem seems damages"
I am thinking the fact that the first partition does not start at 0 1 1 could be a problem but I don't know how to fix this?
If I go into advanced settings it says "no partition avaliable" and there are no other options to try. I read something about the "Write MBR code" but I don't really know what this is so I dont want to mess it up!
Thanks for your help :)
Re: TestDisk recovery on Asus Zenbook, strange scan results.
Can you copy and paste the content of your testdisk.log into your next post?
I'd like to check the status of you current partition structure (partition table).
When your partitions are available, it might be an idea to check your boot sector and its backup.
Maybe to run a RebuildBS to have a try to list your data?
Might be possible that your message partition locked is caused by UEFI?
Info:
http://forum.cgsecurity.org/phpBB3/post ... acy#p18366.
When your Asus ZenBook runs on UEFI, and you run a diagnose on another computer, you should consider to repeat your diagnose and selecting EFI GPT instead of Intel MBR.
So you'd be able to achieve best result, even on another computer and testdisk could find more partitions?
Info about boot and locked partitions will follow.
But it's most important to recover important data first.
mdamusicgroup
#3 Post by mdamusicgroup »
Thanks for the response will post the log files when I get home tonight.
mdamusicgroup
#4 Post by mdamusicgroup »
I have rerun the scan with the "EFI GPT" setting, takes a lot longer but it does find some things with the quick scan, I am fairly lost with what this output means however so any help would be much appreciated.
Please note I had to edit out some of the repetitive parts of the log file due to the 6000 character limit.
Fri Jan 29 15:11:29 2016
OS: Windows 7 (7600)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=256060514304
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=1000097185792
Disk /dev/sdb - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512
Drive C: - 1000 GB / 931 GiB - CHS 121588 255 63, sector size=512
Partition table type: EFI GPT
Analyse Disk /dev/sdb - 256 GB / 238 GiB - CHS 31130 255 63
Trying alternate GPT
NTFS at 4/208/21
filesystem size           716800
sectors_per_cluster       8
mft_lcn                   29866
mftmirr_lcn               2
clusters_per_mft_record   -10
NTFS part_offset=39620608, part_size=367001600, sector_size=512
NTFS at 4/208/21
mft_lcn                   29866
mftmirr_lcn               2
     MS Data                    77384     794183     716800
     NTFS, blocksize=4096, 367 MB / 350 MiB
FAT12 at 218/117/60
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
fat_length 9 calculated 9
FAT12 at 218/117/60
     MS Data                  3509600    3512479       2880 [EFISECTOR]
NTFS at 391/9/51
filesystem size           6174
sectors_per_cluster       1
mft_lcn                   2058
mftmirr_lcn               5162
clusters_per_mft_record   2
clusters_per_index_record 8
     MS Data                  6275859    6282032       6174
NTFS at 391/9/51
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                  6282032    6288205       6174 [Boot]
NTFS at 495/153/51
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                  7955691    7961864       6174
NTFS at 495/153/51
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                  7961864    7968037       6174 [Boot]
LVM magic value at 830/59/3
LVM magic value at 937/78/30
NTFS at 2543/60/54
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 40850955   40857128       6174
NTFS at 2543/60/54
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 40857128   40863301       6174 [Boot]
FAT12 at 2697/220/60
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                 43341224   43344103       2880 [EFISECTOR]
NTFS at 2957/41/45
mft_lcn                   29866
mftmirr_lcn               2
     MS Data                 46790033   47506832     716800
     NTFS found using backup sector, blocksize=4096, 367 MB / 350 MiB
NTFS at 2957/41/45
mft_lcn                   29866
mftmirr_lcn               2
     MS Data                 47506832   48223631     716800
FAT12 at 3144/29/54
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
FAT12 at 3144/29/54
     MS Data                 50510240   50513119       2880 [EFISECTOR]
FAT12 at 3654/172/39
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                 58712384   58715263       2880 [EFISECTOR]
FAT12 at 4031/184/58
FAT1 : 1-9
FAT2 : 10-18
start_rootdir : 19
Data : 33-2879
sectors : 2880
cluster_size : 1
     MS Data                 64769664   64772543       2880 [EFISECTOR]
NTFS at 4329/61/37
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 69543091   69549264       6174
NTFS at 4329/61/37
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 69549264   69555437       6174 [Boot]
NTFS at 4396/29/58
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 70617451   70623624       6174
NTFS at 4396/29/58
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 70623624   70629797       6174 [Boot]
NTFS at 4864/69/6
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 78138339   78144512       6174
NTFS at 4864/69/6
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 78144512   78150685       6174 [Boot]
NTFS at 5930/237/4
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 95274211   95280384       6174
NTFS at 5930/237/4
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                 95280384   95286557       6174 [Boot]
LVM magic value at 9202/92/44
LVM magic value at 10133/123/32
NTFS at 13090/112/39
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                210291771  210297944       6174
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                210297944  210304117       6174 [Boot]
LVM magic value at 14783/156/19
NTFS at 16975/84/62
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                272702555  272708728       6174
NTFS at 16975/84/62
mft_lcn                   2058
mftmirr_lcn               5162
     MS Data                272708728  272714901       6174
cramfs Marker at 23640/207/44
recover_cramfs
     MS Data                379789684  379792183       2499 [IÄ†¯f’5VB¤ì›¤]
     cramfs, 1279 KB / 1249 KiB
NTFS at 31073/96/63
filesystem size           498475008
mftmirr_lcn               2
     MS Data                   718848  499193855  498475008
     NTFS found using backup sector, blocksize=4096, 255 GB / 237 GiB
NTFS at 31073/96/63
mftmirr_lcn               2
file_pread(5,1024,buffer,505488383(31465/50/9)) lseek err Invalid argument
file_pread(5,1,buffer,505488383(31465/50/9)) lseek err Invalid argument
NTFS: Can't read MFT
     MS Data                499193855  997668862  498475008
     NTFS, blocksize=4096, 255 GB / 237 GiB
This partition ends after the disk limits. (start=499193855, size=498475008, end=997668862, disk end=500118192)
NTFS at 31130/190/36
filesystem size           921600
mft_lcn                   38400
mftmirr_lcn               2
     MS Data                499193856  500115455     921600
     NTFS found using backup sector, blocksize=4096, 471 MB / 450 MiB
mft_lcn                   38400
mftmirr_lcn               2
file_pread(5,1024,buffer,500425727(31150/15/33)) lseek err Invalid argument
file_pread(5,1,buffer,500425727(31150/15/33)) lseek err Invalid argument
     MS Data                500115455  501037054     921600
     NTFS, blocksize=4096, 471 MB / 450 MiB
This partition ends after the disk limits. (start=500115455, size=921600, end=501037054, disk end=500118192)
file_pread(5,1,buffer,500118192(31130/234/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,1,buffer,500118194(31130/234/3)) lseek err Invalid argument
file_pread(5,1,buffer,500118195(31130/234/4)) lseek err Invalid argument
file_pread(5,1,buffer,500118196(31130/234/5)) lseek err Invalid argument
file_pread(5,1,buffer,500118197(31130/234/6)) lseek err Invalid argument
file_pread(5,1,buffer,500118198(31130/234/7)) lseek err Invalid argument
file_pread(5,1,buffer,500118199(31130/234/8)) lseek err Invalid argument
file_pread(5,1,buffer,500118200(31130/234/9)) lseek err Invalid argument
file_pread(5,1,buffer,500118201(31130/234/10)) lseek err Invalid argument
file_pread(5,1,buffer,500118202(31130/234/11)) lseek err Invalid argument
file_pread(5,1,buffer,500118203(31130/234/12)) lseek err Invalid argument
.......And so on
file_pread(5,1,buffer,500119804(31131/4/38)) lseek err Invalid argument
file_pread(5,1,buffer,500119805(31131/4/39)) lseek err Invalid argument
file_pread(5,1,buffer,500119806(31131/4/40)) lseek err Invalid argument
file_pread(5,1,buffer,500119807(31131/4/41)) lseek err Invalid argument
file_pread(5,1,bu$MFT has invalid magic.
ntfs_mft_load(): Failed.
ffer,500119808(31131/4/42)) lseek err Invalid argument
file_pread(5,1,buffer,500119809(31131/4/43)) lseek err Invalid argument
file_pread(5,1,buffer,500119810(31131/4/44)) lseek err Invalid argument
file_pread(5,1,buffer,500119811(31131/4/45)) lseek err Invalid argument
file_pread(5,1,buffer,500119812(31131/4/46)) lseek err Invalid argument
file_pread(5,1,buffer,500119813(31131/4/47)) lseek err Invalid argument
file_pread(5,1,buffer,500119814(31131/4/48)) lseek err Invalid argument
file_pread(5,1,buffer,500119815(31131/4/49)) lseek err Invalid argument
file_pread(5,1,buffer,500119816(31131/4/50)) lseek err Invalid argument
file_pread(5,1,buffer,500119817(31131/4/51)) lseek err Invalid argument
file_pread(5,1,buffer,500119818(31131/4/52)) lseek err Invalid argument
And so on....
file_pread(5,1,buffer,500120102(31131/9/21)) lseek err Invalid argument
file_pread(5,1,buffer,500120103(31131/9/22)) lseek err Invalid argument
file_pread(5,1,buffer,500120104(31131/9/23)) lseek err Invalid argument
file_pread(5,1,buffer,500120105(31131/9/24)) lseek err Invalid argument
file_pread(5,1,buffer,500120106(31131/9/25)) lseek err Invalid argument
file_pread(5,1,buffer,500120107(31131/9/26)) lseek err Invalid argument
file_pread(5,1,buffer,500120108(31131/9/27)) lseek err Invalid argument
file_pread(5,11,buffer,500118186(31130/233/58)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,500120109(31131/9/28)) lseek err Invalid argument
file_pread(5,5,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,1,buffer,500120110(31131/9/29)) lseek err Invalid argument
file_pread(5,1,buffer,500120111(31131/9/30)) lseek err Invalid argument
file_pread(5,1,buffer,500120112(31131/9/31)) lseek err Invalid argument
file_pread(5,1,buffer,500120113(31131/9/32)) lseek err Invalid argument
file_pread(5,1,buffer,500120114(31131/9/33)) lseek err Invalid argument
file_pread(5,11,buffer,500118192(31130/234/1)) ReadFile The drive cannot find the sector requested.
file_pread(5,1,buffer,500120115(31131/9/34)) lseek err Invalid argument
file_pread(5,1,buffer,500120116(31131/9/35)) lseek err Invalid argument
file_pread(5,1,buffer,500118204(31130/234/13)) lseek err Invalid argument
file_pread(5,1,buffer,500120117(31131/9/36)) lseek err Invalid argument
file_pread(5,1,buffer,500118205(31130/234/14)) lseek err Invalid argument
file_pread(5,1,buffer,500120118(31131/9/37)) lseek err Invalid argument
file_pread(5,1,buffer,500118206(31130/234/15)) lseek err Invalid argument
file_pread(5,1,buffer,500120119(31131/9/38)) lseek err Invalid argument
file_pread(5,1,buffer,500118207(31130/234/16)) lseek err Invalid argument
And so on......
file_pread(5,11,buffer,500118230(31130/234/39)) lseek err Invalid argument
file_pread(5,1,buffer,500118230(31130/234/39)) lseek err Invalid argument
file_pread(5,1,buffer,500120153(31131/10/9)) lseek err Invalid argument
file_pread(5,11,buffer,500118231(31130/234/40)) lseek err Invalid argument
file_pread(5,1,buffer,500118231(31130/234/40)) lseek err Invalid argument
file_pread(5,1,buffer,500120154(31131/10/10)) lseek err Invalid argument
file_pread(5,11,buffer,500118232(31130/234/41)) lseek err Invalid argument
file_pread(5,1,buffer,500120155(31131/10/11)) lseek err Invalid argument
file_pread(5,1,buffer,500118243(31130/234/52)) lseek err Invalid argument
file_pread(5,1,buffer,500120156(31131/10/12)) lseek err Invalid argument
file_pread(5,1,buffer,500118244(31130/234/53)) lseek err Invalid argument
file_pread(5,1,buffer,500120157(31131/10/13)) lseek err Invalid argument
file_pread(5,1,buffer,500118245(31130/234/54)) lseek err Invalid argument
file_pread(5,1,buffer,500120158(31131/10/14)) lseek err Invalid argument
file_pread(5,8,buffer,500118189(31130/233/61)) ReadFile The drive cannot find the sector requested.
file_pread(5,11,buffer,500118236(31130/234/45)) lseek err Invalid argument
file_pread(5,1,buffer,500120159(31131/10/15)) lseek err Invalid argument
file_pread(5,1,buffer,500118247(31130/234/56)) lseek err Invalid argument
And so on.....
file_pread(5,1,buffer,500120174(31131/10/30)) lseek err Invalid argument
file_pread(5,8,buffer,500118205(31130/234/14)) lseek err Invalid argument
file_pread(5,1,buffer,500118262(31130/235/8)) lseek err Invalid argument
file_pread(5,1,buffer,500120175(31131/10/31)) lseek err Invalid argument
file_pread(5,8,buffer,500118206(31130/234/15)) lseek err Invalid argument
file_pread(5,11,buffer,500118253(31130/234/62)) lseek err Invalid argument
file_pread(5,1,buffer,500120176(31131/10/32)) lseek err Invalid argument
And so On....
file_pread(5,8,buffer,500118251(31130/234/60)) lseek err Invalid argument
file_pread(5,11,buffer,500118298(31130/235/44)) lseek err Invalid argument
file_pread(5,1,buffer,500120221(31131/11/14)) lseek err Invalid argument
file_pread(5,1,buffer,500118238(31130/234/47)) lseek err Invalid argument
file_pread(5,1,buffer,500118259(31130/235/5)) lseek err Invalid argument
file_pread(5,1,buffer,500118309(31130/235/55)) lseek err Invalid argument
file_pread(5,1,buffer,500120222(31131/11/15)) lseek err Invalid argument
file_pread(5,1,buffer,500118239(31130/234/48)) lseek err Invalid argument
file_pread(5,1,buffer,500118260(31130/235/6)) lseek err Invalid argument
file_pread(5,1,buffer,500118310(31130/235/56)) lseek err Invalid argument
file_pread(5,1,buffer,500120223(31131/11/16)) lseek err Invalid argument
file_pread(5,1,buffer,500118240(31130/234/49)) lseek err Invalid argument
file_pread(5,8,buffer,500118254(31130/234/63)) lseek err Invalid argument
file_pread(5,11,buffer,500118301(31130/235/47)) lseek err Invalid argument
file_pread(5,1,buffer,500120224(31131/11/17)) lseek err Invalid argument
file_pread(5,1,buffer,500118241(31130/234/50)) lseek err Invalid argument
file_pread(5,1,buffer,500118312(31130/235/58)) lseek err Invalid argument
file_pread(5,1,buffer,500120225(31131/11/18)) lseek err Invalid argument
file_pread(5,1,buffer,500118242(31130/234/51)) lseek err Invalid argument
file_pread(5,1,buffer,500118263(31130/235/9)) lseek err Invalid argument
file_pread(5,1,buffer,500118313(31130/235/59)) lseek err Invalid argument
file_pread(5,1,buffer,500120226(31131/11/19)) lseek err Invalid argument
file_pread(5,14,buffer,500118180(31130/233/52)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,500118194(31130/234/3)) lseek err Invalid argument
file_pread(5,3,buffer,500118241(31130/234/50)) lseek err Invalid argument
file_pread(5,8,buffer,500118257(31130/235/3)) lseek err Invalid argument
file_pread(5,11,buffer,500118304(31130/235/50)) lseek err Invalid argument
file_pread(5,2,buffer,500120226(31131/11/19)) lseek err Invalid argument
file_pread(5,14,buffer,500118181(31130/233/53)) ReadFile The drive cannot find the sector requested.
file_pread(5,2,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,3,buffer,500118195(31130/234/4)) lseek err Invalid argument
file_pread(5,3,buffer,500118242(31130/234/51)) lseek err Invalid argument
file_pread(5,8,buffer,500118258(31130/235/4)) lseek err Invalid argument
file_pread(5,11,buffer,500118305(31130/235/51)) lseek err Invalid argument
file_pread(5,2,buffer,500120227(31131/11/20)) lseek err Invalid argument
file_pread(5,14,buffer,500118182(31130/233/54)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,3,buffer,500118196(31130/234/5)) lseek err Invalid argument
file_pread(5,3,buffer,500118243(31130/234/52)) lseek err Invalid argument
file_pread(5,8,buffer,500118259(31130/235/5)) lseek err Invalid argument
file_pread(5,11,buffer,500118306(31130/235/52)) lseek err Invalid argument
file_pread(5,2,buffer,500120228(31131/11/21)) lseek err Invalid argument
file_pread(5,14,buffer,500118183(31130/233/55)) ReadFile The drive cannot find the sector requested.
file_pread(5,4,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,3,buffer,500118197(31130/234/6)) lseek err Invalid argument
file_pread(5,3,buffer,500118244(31130/234/53)) lseek err Invalid argument
file_pread(5,8,buffer,500118260(31130/235/6)) lseek err Invalid argument
file_pread(5,11,buffer,500118307(31130/235/53)) lseek err Invalid argument
file_pread(5,2,buffer,500120229(31131/11/22)) lseek err Invalid argument
file_pread(5,14,buffer,500118184(31130/233/56)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,500118198(31130/234/7)) lseek err Invalid argument
file_pread(5,3,buffer,500118245(31130/234/54)) lseek err Invalid argument
file_pread(5,8,buffer,500118261(31130/235/7)) lseek err Invalid argument
file_pread(5,11,buffer,500118308(31130/235/54)) lseek err Invalid argument
file_pread(5,2,buffer,500120230(31131/11/23)) lseek err Invalid argument
file_pread(5,1,buffer,500118248(31130/234/57)) lseek err Invalid argument
file_pread(5,1,buffer,500118269(31130/235/15)) lseek err Invalid argument
file_pread(5,1,buffer,500118319(31130/236/2)) lseek err Invalid argument
file_pread(5,1,buffer,500120232(31131/11/25)) lseek err Invalid argument
file_pread(5,14,buffer,500118186(31130/233/58)) ReadFile The drive cannot find the sector requested.
file_pread(5,7,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,3,buffer,500118200(31130/234/9)) lseek err Invalid argument
file_pread(5,3,buffer,500118247(31130/234/56)) lseek err Invalid argument
file_pread(5,8,buffer,500118263(31130/235/9)) lseek err Invalid argument
file_pread(5,11,buffer,500118310(31130/235/56)) lseek err Invalid argument
file_pread(5,1,buffer,500120233(31131/11/26)) lseek err Invalid argument
file_pread(5,1,buffer,500118250(31130/234/59)) lseek err Invalid argument
file_pread(5,1,buffer,500118271(31130/235/17)) lseek err Invalid argument
file_pread(5,1,buffer,500118321(31130/236/4)) lseek err Invalid argument
file_pread(5,1,buffer,500120234(31131/11/27)) lseek err Invalid argument
file_pread(5,14,buffer,500118188(31130/233/60)) ReadFile The drive cannot find the sector requested.
file_pread(5,8,buffer,500118194(31130/234/3)) lseek err Invalid argument
file_pread(5,3,buffer,500118202(31130/234/11)) lseek err Invalid argument
file_pread(5,3,buffer,500118249(31130/234/58)) lseek err Invalid argument
file_pread(5,8,buffer,500118265(31130/235/11)) lseek err Invalid argument
file_pread(5,11,buffer,500118312(31130/235/58)) lseek err Invalid argument
file_pread(5,1,buffer,500120235(31131/11/28)) lseek err Invalid argument
file_pread(5,10,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,1,buffer,500118252(31130/234/61)) lseek err Invalid argument
file_pread(5,1,buffer,500118273(31130/235/19)) lseek err Invalid argument
file_pread(5,1,buffer,500118323(31130/236/6)) lseek err Invalid argument
file_pread(5,1,buffer,500120236(31131/11/29)) lseek err Invalid argument
file_pread(5,14,buffer,500118190(31130/233/62)) ReadFile The drive cannot find the sector requested.
file_pread(5,3,buffer,500118204(31130/234/13)) lseek err Invalid argument
file_pread(5,3,buffer,500118251(31130/234/60)) lseek err Invalid argument
file_pread(5,8,buffer,500118267(31130/235/13)) lseek err Invalid argument
file_pread(5,11,buffer,500118314(31130/235/60)) lseek err Invalid argument
file_pread(5,1,buffer,500120237(31131/11/30)) lseek err Invalid argument
file_pread(5,12,buffer,500118193(31130/234/2)) lseek err Invalid argument
file_pread(5,1,buffer,500118254(31130/234/63)) lseek err Invalid argument
file_pread(5,1,buffer,500118275(31130/235/21)) lseek err Invalid argument
file_pread(5,1,buffer,500118325(31130/236/8)) lseek err Invalid argument
file_pread(5,1,buffer,500120238(31131/11/31)) lseek err Invalid argument
file_pread(5,1,buffer,500118208(31130/234/17)) lseek err Invalid argument
file_pread(5,1,buffer,500118255(31130/235/1)) lseek err Invalid argument
file_pread(5,1,buffer,500118276(31130/235/22)) lseek err Invalid argument
file_pread(5,1,buffer,500118326(31130/236/9)) lseek err Invalid argument
file_pread(5,1,buffer,500120239(31131/11/32)) lseek err Invalid argument
file_pread(5,2,buffer,500118205(31130/234/14)) lseek err Invalid argument
file_pread(5,1,buffer,500118209(31130/234/18)) lseek err Invalid argument
file_pread(5,1,buffer,500118256(31130/235/2)) lseek err Invalid argument
file_pread(5,8,buffer,500118270(31130/235/16)) lseek err Invalid argument
file_pread(5,11,buffer,500118317(31130/235/63)) lseek err Invalid argument
file_pread(5,1,buffer,500120240(31131/11/33)) lseek err Invalid argument
file_pread(5,14,buffer,500118194(31130/234/3)) lseek err Invalid argument
file_pread(5,1,buffer,500118210(31130/234/19)) lseek err Invalid argument
file_pread(5,1,buffer,500118257(31130/235/3)) lseek err Invalid argument
file_pread(5,1,buffer,500118278(31130/235/24)) lseek err Invalid argument
file_pread(5,1,buffer,500118328(31130/236/11)) lseek err Invalid argument
file_pread(5,1,buffer,500120241(31131/11/34)) lseek err Invalid argument
The harddisk (256 GB / 238 GiB) seems too small! (< 510 GB / 475 GiB)
     MS Data                379789684  379792183       2500 [IÄ†¯f’5VB¤ì›¤]
     cramfs, 1280 KB / 1250 KiB
   P MS Data                499193856  500115455     921600
dir_partition inode=0
       2 drwxr-xr-x     0      0         0 29-Oct-2015 13:49 EFI
dir_partition inode=2
FAT: cluster=2(0x2), pos=3509633
Directory /EFI
       2 drwxr-xr-x     0      0         0 29-Oct-2015 13:49 .
       0 drwxr-xr-x     0      0         0 29-Oct-2015 13:49 ..
       3 drwxr-xr-x     0      0         0 29-Oct-2015 13:49 BOOT
Directory /EFI
Directory /EFI
Directory /EFI
Directory /EFI
       0 drwxr-xr-x     0      0         0 29-Oct-2015 13$MFT has invalid magic.
Capture 4.PNG (82.23 KiB) Viewed 11541 times
mdamusicgroup
#5 Post by mdamusicgroup »
Any thoughts on this? many thanks!!
